#155 |
Drives: Raven FRS
I'm in for a flowchart after head work. Hope you don't run into any more hiccups man.
#156 |
Drives: 2013 White Out FR-S
no headword just yet just valve train but this might change you never know.
#157 |
Drives: Pile of junk
I'm about done spending money i think. Spent a small fortune already.
Unless there is a need for some head work |
| The Following User Says Thank You to Frs300 For This Useful Post: | EAGLE5 (05-02-2013) |
#158 |
Drives: FRS
hahahah i keep telling myself that im done but idk i keep going lol
#159 |
i want to try out a Forced Performance HTA30R turbo
#160 |
whoa slow down.....LOL
#161 |
i said try not buy.
Guess im going to get head work done after all while we wait on rods!!!! |
| The Following User Says Thank You to Frs300 For This Useful Post: | ftc~brz (09-04-2013) |
#162 |
Curious with the larger intake valves, I'm guessing the exhaust valves require more lift being smaller? I didn't realize the FA20 used this configuration.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#163 |
i think ive only seen 1 motor to date where the exhaust are larger diameter. every motor ive come across intakes are always the larger of the 2
| The Following User Says Thank You to FA20Club.com For This Useful Post: | FirestormFRS (05-02-2013) |
#165 |
should i get a Koyo Radiator and Driveshaft shop axles as well?
Have motor mounts on the way Eibach Sportline springs arrived today Port and polish Studs (hopefully) so I lied about spending more money!!!!! |
#166 |
honestly anything will help with the FBM kit cause the put aftermarket fans on there and the stock fans have shrouds and move way more air. my kit still allows us to keep the stock fans. maybe if there are Spal but i dont remember when i looked at them what brand they are.....
#167 | |
i dont remember either...if you see a radiator show up its mine unless you can get it cheaper. |
#168 |
you know i gotcha covered. i just check not brand specific as far as the fans go....
| Full Blown Stage 1 Short Block | FullBlown | Forced Induction | 116 | 03-22-2019 07:29 PM |
| Full Blown 521hp Stock Motor @ 20psi | FullBlown | Forced Induction | 276 | 08-31-2016 02:05 AM |
| How often to rebuild coilovers or stock shocks? | stockysnail | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 12-24-2012 12:54 PM |
| 2013 FR-S / BRZ (The R&D has Begun) | Cotnoir | CANADA | 10 | 06-26-2012 03:08 PM |
| PM Spammers, it's begun! | Beast | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 01-30-2010 01:13 PM |
