Old 04-26-2013, 12:24 PM   #29
FReSh
Dirt Trackin'
FReSh's Avatar
Drives: '13 Raven FR-S MT
Anyone know where the best place is to get the K&N drop in filter, money wise?
FReSh is offline   Reply With Quote
Old 04-26-2013, 05:00 PM   #30
Trashed675
Trashed675's Avatar
Drives: 2013 Ultramarine FRS
I've had my typhoon on for a couple thousand miles now. I did get a CEL for "bank 1 running lean", on examination, it turned out that i hadn't screwed the vacuum line in all the way. I think on mine i got it tight(still some threads showing though), then when it heat cycled a few times it loosened up a little so i could make the last couple rotations, now it sits flush.
Trashed675 is offline   Reply With Quote
Old 04-26-2013, 08:14 PM   #31
dokterdewe
dokterdewe's Avatar
Drives: an automatic lightning red 86
Send a message via Yahoo to dokterdewe
then we should check and recheck when installing this particular kit
did you install this by yourself ?
dokterdewe is offline   Reply With Quote
Old 04-26-2013, 09:20 PM   #32
g0lden
Drives: 2013 Scion FR-S Argento
I don't know that any intake is worth $300+. I'd much rather build my own setup.
g0lden is offline   Reply With Quote
Old 04-27-2013, 01:47 PM   #33
tekkenman
Drives: 2013 Scion FRS Whiteout
I've had mine on for a good thousand miles now. I feel like as long as you follow the instructions and make sure everything is secured then you'll never get a CEL. Maybe all intakes run a risk of CEL idk. And in my opinion, I feel like this intake makes the most dramatic sound difference. Seems louder than the others.
tekkenman is offline   Reply With Quote
Old 05-01-2013, 08:06 AM   #34
dokterdewe
dokterdewe's Avatar
what set up are you referring to ?? made your own pipe ?
did you tune yours ? ecutek/unichip?
Old 05-02-2013, 01:15 PM   #35
tekkenman
I have a unichip. However, its not tuned for any mods. I'm still waiting for their k&n intake tune to be released. '
The Following User Says Thank You to tekkenman For This Useful Post:
dokterdewe (05-03-2013)
Old 05-03-2013, 12:28 PM   #36
dokterdewe
dokterdewe's Avatar
i think i will go for Unichip.. only if the Unichip dealer here has the appropriate harness and cabling set for FA20... thanks
Old 05-04-2013, 01:59 AM   #37
tekkenman
You should just order it online lol. They had a special going on to where it was like 300 something? And took less than a week to get to my house. Haha.
Old 05-04-2013, 03:21 AM   #38
dokterdewe
dokterdewe's Avatar
Harness cable cost you 300 usd ? Is it harness only or including the unichip unit ?
Old 05-04-2013, 01:54 PM   #39
ramiram1984
Drives: 2016 STi DGM
Amazon
ramiram1984 is offline   Reply With Quote
The Following User Says Thank You to ramiram1984 For This Useful Post:
dokterdewe (05-05-2013)
Old 05-05-2013, 03:10 AM   #40
tekkenman
Oh you. Only need the harness haha. Sorry, I read that wrong it was 300 something for harness and the unichip. I cant remember the exact price. If I had to guess I would say 347?
Old 05-05-2013, 09:22 AM   #41
dokterdewe
dokterdewe's Avatar
wow.. its really cheap to get parts in US.. i think here it costs 550 USD.. and im not even sure if its include the specially made harness cable or not...
i will ask them tomorrow..
Old 02-15-2017, 11:28 AM   #42
rikixass
rikixass's Avatar
Resurrecting the thread!
Installed K&N Typhoon blah, blah, blah. Ran ok for a while with no CEL. About a few weeks later it appeared. P0171 Bank 1: Too lean, along with some other related codes P1171 P, and P1171. Convinced dealer to replace high pressure fuel pump due to codes and chirping (700.00 USD). Two days later, CEL returned. Took it in for diagnostic once more, was told a sensor is faulty (MAF, High, Low?) and a replacement was ordered (250.00 for MAF) luckily all under warranty. Took MAF off and noticed pink oily build up on the seal, and the plastic housing for the MAF sensor was oily. Blasted it with MAF sensor cleaner (Auto part store). We shall see what happens this afternoon during my bumper to bumper (10/20 mile) commute.
NOTE:
My tuner (I haven't applied the tune yet, 200 miles to go before warranty expires), mechanic, and the dealership have ALL asked me to put the OEM intake hardware back on and just use the K&N drop in, or OEM paper filter instead. I DON"T SEE WHY.
Called K&N. "Thanks for calling with that information, keep us posted." In other words, they could care less.
Will report back!
rikixass is offline   Reply With Quote
Ummmm... When is typhoon season? Slartibartfast Scion FR-S / Toyota 86 GT86 General Forum 5 05-25-2012 09:57 PM
Typhoon buffets Tokyo, heads into tsunami zone Marrk Off-Topic Lounge [WARNING: NO POLITICS] 1 09-21-2011 02:23 PM
