Old 05-02-2013, 10:25 AM   #1
steve87j
steve87j's Avatar
Drives: Scion FR-S RAVEN
Shift Secrets
I drive alot, would it be best on gas if i shift 1st to 3rd?
try doing it, makes the ride smoother and easier since 1st gear we have ZERO torque and 2nd is always a rock unless u hit the gas perfectly.
steve87j is offline   Reply With Quote
Old 05-02-2013, 10:32 AM   #2
Brndn704
Brndn704's Avatar
That just puts more stress on your engine/clutch. There is a reason its a 6 speed and not a 5 speed.
Brndn704 is offline   Reply With Quote
Old 05-02-2013, 10:36 AM   #3
marky
marky's Avatar
Drives: 2020 BRZ tS #54
I do this sometimes.. That is when I'm going down hill and already have momentum going.. I'm always easy on the clutch.. But on normal flat roads in don't skip gears
The Following User Says Thank You to marky For This Useful Post:
TKinWhiteOut (05-03-2013)
Old 05-02-2013, 11:07 AM   #4
edward
edward's Avatar
Drives: 2013 BRZ - Sterling Silver Metallic
Not necessarily true.
It's fine to skip gears on any road surface/incline/etc, as long as the engine stays in it's useable rev range. For example, it's fine to accelerate hard through 1st and 2nd gears, then put the transmission in 5th gear to cruise at 35 mph. As always, it just requires the driver to properly rev match (typically done by timing upshifts properly, rather than the throttle blipping technique used for downshifts.) There is no one rule for how long to wait before letting the clutch back out when upshifting, since it varies with a number of factors, including where the engine is in the rev range, how warm the engine is, etc.
Additionally, becoming good at rev-matching a 6th-3rd gear downshift is vital for passing/accelerating on the highway
TL;DR - Feel free to skip gears in any context/situation as long as your are using proper technique (including rev matching.)
edward is offline   Reply With Quote
The Following User Says Thank You to edward For This Useful Post:
Old 05-02-2013, 11:12 AM   #5
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Please explain.
I often shift right from 3rd to 6th when getting on the freeway and I wait for the revs to mach driveline speed before I put it in 6th. It's pretty much exactly the same as a 5th to 6th shift. Actually wouldn't this be less ware as I'm only using 4 gears (and shifts) over 6?
The Following User Says Thank You to BlaineWasHere For This Useful Post:
edward (05-02-2013)
Old 05-02-2013, 11:20 AM   #6
marky
marky's Avatar
Yes exactly.. I rev match it or down shift if the car feels slow when trying to accelerate .. My friend has rev match auto on his MT FRS lol sissy.. Do it like a man.. Be one with the car
Old 05-02-2013, 11:28 AM   #7
frslee
Just drive it
Drives: 13' FR-S
I believed as long as you match to the engine speed, it's fine if you skip upshift or skip downshift.
frslee is offline   Reply With Quote
Old 05-02-2013, 11:32 AM   #8
CaptainSlow
CaptainSlow's Avatar
It's fine. The GTO actually had a system (skip-shift), that would FORCE you to shift from 1st to 4th if the conditions were right (accelerating at a certain % throttle and within a certain RPM range, for example). Most annoying system ever designed into a car, and one of the first things most people get rid of when they buy one.
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
Old 05-02-2013, 12:02 PM   #9
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Unless the gearbox isn't designed for it like the S2000 it should be fine.
ineedyourdiddly
Old 05-02-2013, 12:07 PM   #10
SkullWorks
Drives: SSM LT MT BRZ
Please quantify this...as the statement stands it makes no sense what-so-ever
BTW the pesky GTO skip shift was a fuel economy trick that (i believe) was first implemented on the 'Vette
Old 05-02-2013, 12:22 PM   #11
strat61caster
Can't access the official bulletin because I don't care enough to figure out how to log into the Honda system it's stored in.
This is from the January 2006 Honda ServiceNews:
"Skip Shifting Is Brutal on Synchronizers"
Gear ratios in 6-speed manual trannies are spaced
close together so you can keep the engine speed
in its optimum range for max power and
acceleration. Shifting to the next higher or lower
gear in a close-ratio tranny causes small changes
in engine speed.
Shifting a close-ratio tranny through its gears by
the numbers puts a very small load on the
synchronizers since they only have to make small
changes to the speed of the mainshaft and the
clutch disc.
Some drivers, though, like to skip shift so they
don’t have to work the clutch pedal and shift lever
as much. They like to accelerate in 1st gear, then
pop it into 3rd gear, then into 5th or 6th. Skip
shifting, though, is really brutal on synchronizers;
it puts a higher demand on them than they were
designed to take. Skip shifting can cause
premature synchronizer wear that can cause the
gears to grind when you shift up or down.
If you’ve got a vehicle in your shop for repeated
damage to the synchronizers, go for a test-drive
with your service customer to see if he or she is
guilty of skip shifting. If that’s the case, remind
him or her skip shifting can be an expensive habit
to break. Any repairs due to skip shifting may be
reviewed and debited by your DPSM."
I got it from this: http://www.standardshift.com/forum/v...hp?f=6&t=13489
But there are a myriad of posts on S2k forums with similar advice.
I thought it was stated explicitly in the owners manual but I'm not finding evidence of it... I'll keep looking.
Edit1: This may be useful:
http://www.s2ki.com/s2000/topic/1967...gear-synchros/
Edit2: Perused the '09 S2000 manual and it says nothing so I guess I was wrong
Thought it was common enough knowledge among sports car enthusiasts (especially 86ers, I can't imagine why you wouldn't cross shop an S2000 at least to get a good idea of what the competition is) to warrant posting without evidence, apologies.
Here's the manual for giggles:
http://owners.honda.com/vehicles/inf.../S2000/manuals
Edit3: In normal day to day driving on the street I don't think it'll be a problem, transmissions wear out eventually and a premature rebuild isn't the end of the world, hell if you're economical enough you might save enough gas money to cover the cost of the rebuild
ineedyourdiddly
SkullWorks (05-02-2013)
Old 05-02-2013, 12:38 PM   #12
SkullWorks
I guess i never thought of the gear split internally, in reference to skip shifting.
When I do skip shift it is not in a spirited manner and I engage the higher gear very slowly...because if was in a hurry i wouldn't be skip shifting. But this is definitely something to think about, and a very good thing for people to read and understand.
Old 05-02-2013, 12:39 PM   #13
SkullWorks
haha you edited while I was Quoting...I got all confused.
Old 05-02-2013, 12:39 PM   #14
BlaineWasHere
Grip>Drift
Drives: FRS
^^^ That's true if you make the syncros do all the work. If you wait for the revs to fall to the correct spot the syncro works no harder than on a normal shift.
I'm not going from 3rd and putting it in 6th right away.
Shift Knob Zoomryder Issues | Warranty | Recalls / TSB 5 04-09-2013 08:39 PM
CF Shift Paddles? FRS_Ken Cosmetic Modification (Interior/Exterior/Lighting) 2 01-23-2013 11:05 PM
How do you shift? Carbon420 Scion FR-S / Toyota 86 GT86 General Forum 27 12-30-2012 01:11 PM
Thoughts and secrets of the FR-S/FT-86 Interior KevinDuMa Scion FR-S / Toyota 86 GT86 General Forum 56 07-21-2011 02:38 PM
Shift Apparel Lexicon101 Other Vehicles & General Automotive Discussions 2 05-02-2010 12:44 AM
