Old 04-30-2013, 04:38 PM   #1
Bg8780
Bg8780's Avatar
Drives: '13 Black Subaru BRZ Limited
Erractic loss of power at low RPM
When I first start driving the car (already warmed up to one bar on the temp gauge) I notice a dramatic loss of power from 2k RPM up to 3k -3500. Anyone else notice this issue? I will say after some time it goes away but this is after about 25 minutes of driving.
I do have the FA20Club intake and ECU tune but this did not start until the weather down here significantly warmed up and it became more humid. Also, the first few tunes (ROM files) did not have this. I am already in touch with FA20club and they are looking at the tune. Just curious if this is causing damage and I should quit driving and whether its been already discussed/noticed.
I had the idea that it just could be the default fuel/air ratio the ECU gives the engine until the thermostat is able to get it's bearing after a few miles. Just my theory.
Bg8780 is offline   Reply With Quote
Old 04-30-2013, 06:52 PM   #2
Fenrir
Drives: Mazdaspeed 3
Are they tuning YOUR car, or just an OTS generic tune? OTS tunes are generally pretty terrible.
Fenrir is offline   Reply With Quote
Old 04-30-2013, 08:25 PM   #3
Bg8780
Bg8780's Avatar
Not sure what OTS stands for. Sorry. It's specific to my car. They emailed me an initial tune and then I log 3rd gear pulls to redline and 1-6 gear normal driving with the ECUtek software and email him the results. He tweaks the tune and then sends me a revised tune. This is the 4th tune.
Old 04-30-2013, 11:08 PM   #4
FirestormFRS
OTS=off the shelf
FirestormFRS is offline   Reply With Quote
The Following User Says Thank You to FirestormFRS For This Useful Post:
Bg8780 (05-01-2013)
Old 05-01-2013, 01:55 PM   #5
Bg8780
Bg8780's Avatar
Originally Posted by Marchy View Post
If you are working on a tune then work with your tuner to rectify the issue.
Already being taken care of. I was just curious if anyone else had this issue with a stock ECU. Just trying to learn through experience and what I find on the forums.
Old 05-01-2013, 03:00 PM   #6
Fenrir
I mean this sincerely and don't mean to come off crass:
Asking to compare a stock ECU to one that is tuned (especially on this car, as the whole thing is voodoo right now) is a waste of everyone's time. Assuming the car is tuned properly, just about everything will be changed.
That said, and if you weren't aware, there is a significant torque dip near the ranges you mention on the stock engine. This is by design from Toyobaru, and is evident here:
Most tunes I've seen will shift this dip down in the power band to alleviate some of the loss under spirited driving.
Hope this helps.
The Following User Says Thank You to Fenrir For This Useful Post:
Bg8780 (05-01-2013)
Old 05-01-2013, 03:42 PM   #7
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
Not to mention one of the most documented aspects to this car.
Hope this helps.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Old 05-01-2013, 04:13 PM   #8
Bg8780
Bg8780's Avatar
Hope this helps.
That's fine, you didn't come off crass. I appreciate the discussion. I am well aware of the torque dip and have always felt in the car. (little less after tune) However, I now only feel the "dip" 2-3k and not where the dip usually is which is 3-4500. That's why it was alarming the first place to me.
I did receive a response from FA20club and they are emailing me a revised tune. He contributed it to the exhaust cam not working until the car temperature is above 90C. He is going to adjust the cam phasing map to see if it will minimize the power loss.
Thanks for the response and information though. We'll see what happens from here.
Loss power after gas fill up HELP! Ad8707 Issues | Warranty | Recalls / TSB 63 08-21-2014 02:01 AM
Hi rev power loss? lbroskee Scion FR-S / Toyota 86 GT86 General Forum 3 09-29-2012 10:47 PM
CEL, Loss of Traction Light, Loss of Power pituala Issues | Warranty | Recalls / TSB 19 09-05-2012 12:23 PM
Loss of power after gassin up HELP!!!! Ad8707 CANADA 26 07-29-2012 07:24 PM
DI and engine power loss over time Sport-Tech Engine, Exhaust, Transmission 7 06-27-2011 06:49 PM
