Old 04-30-2013, 08:00 PM   #8079
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
Originally Posted by PolishFrs13 View Post
haha, ive got some cav scout buddies, we dont have too much beef around. but all the deployment money is gonna be an amazing feeling
Deployment and contract money is always a good feeling. Just try to control yourself everyone goes buck wild their first time and than sits back and says wow you really can blow $10k in a month. I prefer the compare and spend method I have enough cash to buy a super charger but with HKS and Innovate ready to start selling any day now and Vortech just releasing a kit that gives 294hp out of the box I'm still shopping around until I'm 100% sure I found the best kit for what I'm looking to do.
Old 04-30-2013, 08:02 PM   #8080
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
If any of you locals want to get in on UEL Group Buy
http://www.ft86club.com/forums/showthread.php?t=35237
JDLAutoDesign is offline   Reply With Quote
Old 04-30-2013, 08:08 PM   #8081
Yruyur
Yruyur's Avatar
How much do we save on shipping
The Following 2 Users Say Thank You to Yruyur For This Useful Post:
BugeyedWagon (04-30-2013), SMOKETREES (04-30-2013)
Old 04-30-2013, 08:18 PM   #8082
mattles
Proud of FR Layout
mattles's Avatar
Drives: 2013 Scion FR-S 6MT
Originally Posted by kos View Post
Hopefully I can get the time off for this event then! My external wastegate setup is pretty damn loud haha.
If its just a straight dump, then you may run into problems. Though I can say there was atleast 2 uncorked imprezas out there @ AMP last time.
--Matt // Flickr \\ Instagram
mattles is offline   Reply With Quote
Old 04-30-2013, 08:32 PM   #8083
redsuns03
is there any group rides being planned any time soon? I'm excited to meet up with fellow ft86 drivers
Old 04-30-2013, 08:34 PM   #8084
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
Doing camber in fronts. Looking at 1° in front. Pain in the ass tho!
SMOKETREES is offline   Reply With Quote
Old 04-30-2013, 08:54 PM   #8085
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
How much would 1°-1.5° of camber affect the life of the tire. Would there be obvious tire wear on the side walls? Thx for your input :-)
Old 04-30-2013, 08:56 PM   #8086
Ninjin
Ninjin's Avatar
Drives: SWP BRZ 6MT
1 deg is probably good for regular or slightly aggressive driving, 1.5 - 2 is better for spirited or track driving. I have about 1 degree now and it's not enough.
Sent from my Nexus S using Tapatalk 2
Old 04-30-2013, 08:57 PM   #8087
JDLAutoDesign
Drives: 13 FRS
$7. We charge a flat rate to all Con US customers
Old 04-30-2013, 09:05 PM   #8088
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
Do you see a lot of tire wear or pretty reasonable?
Old 04-30-2013, 09:06 PM   #8089
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
Ksport said that the Conner plates can do about 1-2° of camber then I can get more on the bottom part of the coil which all together could be around 4-5° of camber
Old 04-30-2013, 09:19 PM   #8090
Accurate Race Shop
Drives: Scion FR-S
I checked out my tires today and they are wearing pretty evenly with 1.5 degrees of camber.
Sent from my SGH-T989 using Tapatalk 2
The Following User Says Thank You to Accurate Race Shop For This Useful Post:
Old 04-30-2013, 09:31 PM   #8091
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
Okay so with camber plates, I went all the way towards the engine. Don't have a measure on it but will check this out and get tires rotated and then see what happens. Most I think I'm at will be at 2° so I shoukdnt see much tire wear. Plus I rotate tires whey 2000 miles. Changing that too 1000 each tire rotation now
Old 04-30-2013, 09:46 PM   #8092
nelsmar
Dont wory about wear at 1-2 degree's. S2000 UK spec was -2 in the rear from the factory which should shed some perspective.
And KSports allow 2 degree in each direction from the center point of mount. This doesn't mean 2 degree's from 0 degree's camber. If you lower the car your wheel tilts in. Which is why the camber plates allow you to camber out 2 degree's as well. All the way in will depend on your ride height for angle. I just had to adjust mine as somehow i managed to push them in at one point and the camber was visually pretty noticeable, and after 1k or so miles i have noticeable inner wear. Its not that much wear but you can see it.
My flickr - Canibeat
Local magazine scout
The Following User Says Thank You to nelsmar For This Useful Post:
