Old 04-26-2013, 07:59 PM   #15
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I am a huge proponent of function>form but occasionally an item will appear that is both functional and aesthetically pleasing. I am suggesting these are one such item.
whataboutbob (11-01-2013)
Old 04-26-2013, 08:21 PM   #16
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Very nice!
kask2_6.0 is offline   Reply With Quote
Old 04-27-2013, 02:55 AM   #17
Supermassive
Supermassive's Avatar
Damn, I am almost inclined to buy these to replace my Vorshlags, just because of how good they look. Now if you could anodize them orange I think I would be completely sold!
Supermassive is offline   Reply With Quote
Old 04-27-2013, 02:01 PM   #18
Shit Luck
Drives: red frs
These are awesome...
integrated tower brace coming?????
Shit Luck is offline   Reply With Quote
Old 04-27-2013, 07:45 PM   #19
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
They are even better looking in person.
I will be testing them at the AutoX soon.
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 04-27-2013, 08:04 PM   #20
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Do these raise the height when installed, or do they allow more shock travel? Parts look good!
JDKane527 is offline   Reply With Quote
Old 04-28-2013, 06:19 PM   #21
xwd
Raceseng can answer definitely but the way the upper portion seems to fit within the opening of the strut tower would mean the perch wouldn't sit quite as low as a perch which fits completely flat under the shock tower.
Old 04-29-2013, 12:26 AM   #22
DrSleepy
DrSleepy's Avatar
Drives: 2013 MT FRS, 2002 MR2
I rarely see something that makes me scream "I need this" like these do.
DrSleepy is offline   Reply With Quote
Old 04-29-2013, 06:24 PM   #23
Raceseng
Raceseng's Avatar
Originally Posted by EarlQHan View Post
Very nice, it's about time these things hit the market. What dampers do you planning on making them compatible for?
We plan on making them work with all the dampers on the market. We can custom machine the upper and lower spherical bearing bushing to fit the strut shaft. We plan on making a simple form that the customer can fill out that will detail the dimensions of their strut shaft and spring. There will be some modularity between the strut shafts but its going to take us some time to cover all the coil overs on the market.
Raceseng is offline   Reply With Quote
Old 04-29-2013, 06:27 PM   #24
Raceseng
Raceseng's Avatar
Originally Posted by naikaidriver View Post
Excellent question!
If these will be compatible with the Koni's, you will most certainly have at least one customer!
Scott
We can make that happen! Send me an email - jarrett@raceseng.com
Old 04-29-2013, 06:31 PM   #25
Raceseng
Raceseng's Avatar
Originally Posted by simpleisbest View Post
Will ride height be effected?
These have less stack height then the top plates that come on coil overs. Since the plate extends up into the strut tower, I was able to push the bearing housing further up into the caster/camber plate.
Old 04-29-2013, 06:37 PM   #26
Raceseng
Raceseng's Avatar
Originally Posted by eckoflyte View Post
What sort of ball bearing is being used?
Glad you asked, the upper is a spherical bearing with a stainless steel race/ball and a teflon liner. There are a large number of private labeled spherical bearings carried by every "bearing manufacturer" under the sun. Sifting through the mess of private labeled bearings is the difficult part.
The spring perch bearing is a double row angular contact bearing. This is a more expensive bearing but truly intended for the axial/thrust load that it will see.
The Following User Says Thank You to Raceseng For This Useful Post:
Eric@ptuning (01-28-2014)
Old 04-29-2013, 06:43 PM   #27
Raceseng
Raceseng's Avatar
Hearing something like this makes me proud because we pour hours upon hours into truly designing our products. All things begin and end with design at Raceseng, it is one of our core foundations.
Hawk77FT (08-10-2013)
Old 04-29-2013, 06:45 PM   #28
Raceseng
Raceseng's Avatar
The caster/camber plate will be black anodized and the bearing housing and spring perch will be anodized orange.
Supermassive (04-30-2013)
billet, billet aluminum, caster adjustment, caster camber plate, raceseng
Tein Flex Z Coilovers Evasive Motorsports Brakes, Suspension, Chassis 54 07-16-2017 01:21 AM
Raceseng | Billet Aluminum Engine Pulleys Raceseng Engine, Exhaust, Transmission 174 07-24-2014 12:24 AM
Raceseng | Lightweight Billet Aluminum Tow Hook Raceseng Cosmetic Modification (Interior/Exterior/Lighting) 13 08-27-2013 01:48 PM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
SRP Billet Aluminum Door Sills pedalpusher Cosmetic Modification (Interior/Exterior/Lighting) 2 09-20-2012 06:44 PM
