Old 04-29-2013, 10:07 AM   #169
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
Originally Posted by Gshoxx View Post
Will there be any hp gain aside form torque gain? And do we need to send new data logs for any tweaks on the tune if we already have your stage 2 tune?
There is definitely a HP gain. I should be able to quantify the gains in my setup later this week.
Keep in mind the following formula...
HP = Torque x RPM ÷ 5252
If you already have a stage 2 tune then i would send in your logs post install and have them review (free HP sitting on the table). I recall them mentioning somewhere that you should be able to run a bit more timing.
pixel67 is offline
Old 04-29-2013, 10:27 AM   #170
FA20Club.com
Drives: 2013 White Out FR-S
yes you will see hp gains untuned but i can still bump up power a bit with a tune revision because of the increase in exhaust flow.
FA20Club.com is offline
Old 04-29-2013, 10:28 AM   #171
FA20Club.com
Originally Posted by Knickstape View Post
I'm pretty sure the answer is no, but would there be any issues installing this with a Perrin headerback setup?
its a direct bolt on for any system out there that was designed to bolt to the end of the stock header since we use the exact same placement.
Old 05-05-2013, 06:53 PM   #172
swift996
swift996's Avatar
I got the car dynoed on Saturday down in Richmond. The dyno numbers were reading a little low so take it with a grain of salt. There were 5 or 6 of us so there are some good comparisons in the post here:
http://www.ft86club.com/forums/showthread.php?t=35546
I'm running the 92 octane Fuel ~ Timing + map on my unichip (AEM Intake w/Headers)
The map is running too rich up top. I'm sure I could squeak out an extra 4-7whp at peak if I went with a leaner mixture. Very consistent pulls, goodbye torque curve:
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline
Old 05-05-2013, 08:15 PM   #173
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Very nice numbers, and I'm sure you'd see 200~ on E85
SmsAlSuwaidi is offline
Old 05-05-2013, 09:29 PM   #174
mad_sb
Drives: 2013 Asphalt FR-S
Looks good I think you would see more gains with a reflash tune since the cam timing can and probably should be adjusted with the factory bottle neck removed, especially in the 3000 - 4500 range.
mad_sb is offline
Old 05-06-2013, 04:25 AM   #175
Freude am Fahren
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
Good to see!
-XXR 527 18x8.75 +35
-Nameless 2.5" OP/FP Combo (Coming soon) & Axleback
-SBD 500X (Waiting on coating to install)
-Southbend SBD500X Clutch
Freude am Fahren is offline
Old 05-06-2013, 08:40 AM   #176
swift996
swift996's Avatar
Just to clarify -- So the only mods were the AEM intake, FA20Club header, and unichip. Everything else is stock. I'm very happy with the torque curve. It looks like a few adjustments to the map and I can make the HP curve a little more linear from 4-5k rpms and a few more ponies up top. The dyno reads how the car feels so I'm happy with it.
I had roughly the same numbers as a guy running E85 w/tune and overpipe-back exhaust and intake. However, my torque curve was a table where he was still battling the dip. The header definitely got rid of that. It just makes the car more fun to drive on backroads.
swift996 is offline
Old 05-06-2013, 10:30 AM   #177
pixel67
pixel67's Avatar
I updated my build thread with a few more thoughts, mostly the same as what i posted here. My Virtual Dyno numbers are pretty close to your actual numbers @swift996 with the exception that mine are even more linear than yours. Likely due to using Virtual Dyno vs real dyno though.
pixel67 is offline
Old 05-06-2013, 10:35 AM   #178
FA20Club.com
its a tried and true design. its exactly what the car needed to allot of powerband issues throughout the entire range. couple with a proper tune and youll see more gains up top and probably a bit more around the dip area with the cam phasing adjusted.
Old 05-06-2013, 10:36 AM   #179
xjohnx
Grip>Slip
xjohnx's Avatar
Yep. Although I don't have an intake. Just a replacement panel filter from K&N. Other power mods are the Nameless overpipe/downpipe/hfc, nameless axleback, and reflash.
There's definitely some work to be done on my map (especially in the dip area, I dynod an older revision of Visconti's E85 rom (1.07) and it had about half of the torque dip as my current rom.
Seeing the result from your header was definitely encouraging though. As soon as Nameless releases theirs, i'm all over it. Hopefully between the header and some more work in the E85 rom I hope to hit 200whp NA and i'll be happy.
xjohnx is offline
swift996 (05-06-2013)
Old 05-06-2013, 04:02 PM   #180
swift996
swift996's Avatar
My best attempt to mock-up a stock/near-stock run.
swift996 is offline
The Following 2 Users Say Thank You to swift996 For This Useful Post:
allawd (05-06-2013), SkAsphalt (05-06-2013)
Old 05-07-2013, 12:57 AM   #181
jflogerzi
jflogerzi's Avatar
I am getting this header in June/July time frame. Hold off till FI in a year or 2.
jflogerzi is offline
Old 05-10-2013, 06:44 PM   #182
FastLane1000
FastLane1000's Avatar
Drives: White FR-S, 6M
Got mine ordered! Should be here in a couple weeks. Can't wait!
FastLane1000 is offline
header, turbo manifold
Visconti vs FA20Club vs Stock Tune Dyno Results mechaghost Engine, Exhaust, Transmission 153 07-08-2013 12:35 PM
FA20CLUB V2 Turbo Kit Progress FA20Club.com Forced Induction 40 05-17-2013 02:26 PM
FA20CLUB Power Pack #1 Tested FA20Club.com Engine, Exhaust, Transmission 31 01-16-2013 04:32 PM
Borla cat-back w/ UEL header tested at the track BeltedBiscuit Engine, Exhaust, Transmission 17 12-30-2012 03:57 AM
Turbo FR-S Tested For Drift Reportedly Spotted DanPO Scion FR-S / Toyota 86 GT86 General Forum 123 01-24-2012 02:25 AM
