Old 04-29-2013, 04:47 AM   #57
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
How does the 17x9 +45 work with a bbk? Mainly the sti Brembo swap?
Old 04-29-2013, 05:13 AM   #58
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
The 8 inch RPF1s have more room than the 9s. There are plenty of threads with pics of clearance. I've largely ignored them all as I'm not changing the brakes. Search. The info is there!
86•BRZ is offline   Reply With Quote
Old 04-29-2013, 11:04 AM   #59
garf
Great Member
garf's Avatar
Drives: raven, baught 8-29-12, manual
Originally Posted by 86•BRZ View Post
not really sorry, this was a crop of the car in the background of a shot:
the bottom line is that even with the +45, they poke out and look a bit odd.
With lowering and some camber it now looks like it is supposed to be there.
you can't make the +45 look like it fits, spacers will only make it look worse.
just get the 17x8 +45, at least for the front.
you should make a thread of your build with more pics. need more!!!
garf is offline   Reply With Quote
Old 04-29-2013, 01:32 PM   #60
wparsons
wparsons's Avatar
17x8 +45 is pretty close to flush up front on stock suspension and stock camber. I haven't measured, but it looks good. Rear could use about 10mm.
flickr
Old 04-29-2013, 07:01 PM   #61
keen as
keen as's Avatar
Drives: 86 GT MT
9s for the rear?
That would look good. I am a fan of staggered setup, had it in a previous car. However, I am going for a square setup because I am taking it to the track and want to be able to swap front and back wheels.
Also in reply to others on thread, BBK clearance, see this post and the rest of the thread it is from
http://www.ft86club.com/forums/showp...9&postcount=47
keen as is offline   Reply With Quote
Old 04-30-2013, 03:44 AM   #62
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
there's no build, i just bolted on some struts and wheels one morning!
Old 04-30-2013, 03:48 AM   #63
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
fair enough, but i'd just put the std wheels on for track use.. put the shorter living track tires on them
the 8s will look good , they just won't look quite as good as the 9s with their dish!
Old 12-01-2013, 08:07 PM   #64
karma003
auto-crosser/drifter
karma003's Avatar
Drives: 2013 scion FR-S black M/T
17x9 +35 245/40r17 Bfg sport comp 2's
karma003 is offline   Reply With Quote
Old 12-01-2013, 09:31 PM   #65
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Originally Posted by BlaineWasHere View Post
For sure. A little negative camber will do wonders.
Precisely, that and folks don't know what they're missing for improved handling and control by having some (-) camber up front. Having none like stock is actually well... terrible in comparison.
The Following 2 Users Say Thank You to OICU812 For This Useful Post:
FT-86 SpeedFactory (12-01-2013), rookietopro_frs (09-20-2017)
Old 05-06-2014, 02:18 PM   #66
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
here is a shot of the clearance (17x9 +45) 1.5 degrees camber adjusted via the clevis bolts not the camber top
plenty of room!
you're on coilovers, clearance isn't an issue with coils, STOCK struts is where it matters.
Jive Turkey is offline   Reply With Quote
Old 05-06-2014, 02:34 PM   #67
loogs
Drives: on cruise control
+35. i had the +45 and wish i got the +35
loogs is offline   Reply With Quote
Old 05-27-2014, 06:10 PM   #68
captainzib
Oompa Loompa of Science
Drives: Scion FR-S
What's the downside of getting +35 and not adjusting the camber to bring em back in? At the moment, I'm running stock suspension and no plans to change that soon. Other than the poke look and change in drag, are there any other problems? Is there a huge risk of rubbing the fenders at stock suspension?
I saw supersonic's link to djjd42's thread. Has anyone run 255 with 17x9 +35?
Thanks in advance.
captainzib is offline   Reply With Quote
Old 05-27-2014, 06:52 PM   #69
Skurj
Drives: SOLD...
Oakos, is listing a 17x8.5 ET40 now.. mebbe best of both worlds? Though hoping someone has a set so I can see the face of them...
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
Old 05-28-2014, 12:18 AM   #70
D88
D88's Avatar
Drives: 2014 Scion FRS
Thanks in advance.
The downside is appearance. It sticks out a bit too far in the fronts and some people don't like that. Otherwise everything clears fine with 245/40/17 tires. I would be hesitant to use 255 tires on stock suspension as there is already very little room to work with on 245s.
D88 is offline   Reply With Quote
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 06:31 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
RPF1 are coming in 17x9 5x100 in Nov! Cheddar Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 07-23-2012 06:23 PM
