Old 04-28-2013, 08:35 AM   #29
blue cat
blue cat's Avatar
Drives: Toyota 86 GTS
It might be worth getting someone who has driven a manual transmission for a long time to actually sit with you in the car or better yet drive it with you so they can give you feedback based on feel. But most of the responses in this thread should have you covered already.
blue cat is offline   Reply With Quote
Old 04-28-2013, 12:59 PM   #30
Myv
Myv's Avatar
Drives: SWP BRZ Limited MT
Learned manual on this car too Stalled a lot in the beginning because I could not get used to the large free play on the clutch, but I'm pretty used to it now, but I'll probably still do the clutch adjustment since most say it feels even better even if you are used to large free play.
Question,
If you about to come to a stop at a light, and neutral'd but still rolling 8-10mph to your stopping point, and the light turns green, would you rev match to continue in 2nd or start from 1st? I've had this happen a few times, and I usually rev a bit and the shifter loves sliding into 2nd, and it's very hard to get it into first. My friend told me I should go into 1st though, else I'd grind my clutch a lot since there is a bit of riding the clutch before fully letting go of clutch into 2nd.
Myv is offline   Reply With Quote
Old 04-28-2013, 01:04 PM   #31
Dezoris
Dezoris's Avatar
Meet up with someone on here and get some lessons!
Old 04-28-2013, 05:14 PM   #32
OrbitalEllipses
Drives: Attitude
Originally Posted by @Art_Mighty View Post
I salute you sir!
There's a lot of us who made the jump to manual for this car.
Old 04-28-2013, 11:52 PM   #33
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
Question,
If you're coming to a stop at 8-10 mph, depress the clutch, shift into 2nd, slowly let go of the clutch as you rev match.
2nd gear is made to drive off once your car is in motion from 1st. If you panic you can even use 2nd to start your car off from a stop, but it's not recommended of course =).
CamryDS is offline   Reply With Quote
The Following User Says Thank You to CamryDS For This Useful Post:
Myv (04-29-2013)
FR-S Hail Damage Repaired! LarryGP Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 04-29-2016 11:20 AM
Hail Damage execoll BRZ First-Gen (2012+) — General Topics 61 07-21-2014 06:22 PM
Damage report that_one_guy Scion FR-S / Toyota 86 GT86 General Forum 14 01-02-2013 03:34 PM
Crawfor brz damage? PowderfaceTr. Cosmetic Modification (Interior/Exterior/Lighting) 6 10-13-2012 09:29 AM
