Old 10-03-2012, 03:44 AM   #71
Jun_
Drives: Satin White Pearl BRZ Limited
Originally Posted by Flat Black VW View Post
It is shown in this thread, first post:
I looked over that, and I'm still pretty damn confused. I suck at these kind of things and might probably require step-by-step directions with pictures. ):
Jun_ is offline   Reply With Quote
Old 10-03-2012, 08:57 AM   #72
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
Its not really a step by step thing, you pull the radio, cut the VSS wire and put a switch in it, and ground the grey ebrake wire. That thread has a picture of where the VSS is cut which is the most difficult part.
Flat Black VW is offline   Reply With Quote
Old 10-03-2012, 12:26 PM   #73
Jun_
I have an uneasy feeling I'm going to mess something up. haha.
Old 04-27-2013, 09:36 PM   #74
cfusionpm
Drives: Firestorm 6MT Scion FR-S
Bump for old thread, what does this mean "put a switch in it"?
I am getting and installing a pioneer nav deck soon and plan on doing all the bypasses myself... this is still somewhat confusing to someone not terribly familiar with auto wiring.
2013 Firestorm 6MT Scion FR-S
cfusionpm is offline   Reply With Quote
Old 04-28-2013, 09:08 AM   #75
cmspooner
cmspooner's Avatar
Drives: 2013 SWP Limited BRZ - Manual
He put a physical toggle switch in so that he can ground out the speed sensor allowing him to use the gps when he wants. The speed sensor is used to help the gps keep track of the vehicle in times of poor gps signal, so the gps works with the speed sensor off; but it may be less accurate. If the gps needs help he can now switch it back to having the speed sensor, but the head unit will lock hm out again.
cmspooner is offline   Reply With Quote
Old 04-28-2013, 10:23 PM   #76
Flat Black VW
This will not be the correct method for bypassing a Pioneer unit. If you are getting a pioneer nav unit check out the avic411 forums. For those you need to move the mute wire on the rca harness and ground it.
If it is a non nav unit you just put a toggle switch on the parking brake wire and when you want to use VIM flip the switch.
The Following User Says Thank You to Flat Black VW For This Useful Post:
cfusionpm (04-28-2013)
Old 04-28-2013, 10:29 PM   #77
xjohnx
Grip>Slip
xjohnx's Avatar
Or for the AVH and AppRadio models get a microbypass. $20 on Amazon, 3 wires connect to the harness, done.
Old 04-29-2013, 11:31 AM   #78
cfusionpm
That looks wonderfully easy. Looking forward to getting my 950bh a lot more now.
Old 05-01-2013, 03:35 PM   #79
omegared19
omegared19's Avatar
Drives: White 2013 BRZ Limited 6MT
So I went ahead with ordering the Beat Sonic wiring harness that's posted in this thread, since I'm not good with wiring and just wanted to do something simple. When going to install the harness, it's the wrong size. So at this point I'm very frustrated because the box says Subaru on it. I want something simple....and I'm not completely confident in my abilities to cut n splice wires.
omegared19 is offline   Reply With Quote
Old 05-04-2013, 06:48 AM   #80
BRZY
BRZY's Avatar
Drives: World Rally Blue BRZ
page 2 of this thread:
http://www.ft86club.com/forums/showp...9&postcount=23
here's a list of vehicles that Beat Sonic's kit support:
2008-2012 Subaru Forester
2008-2010 Subaru Impreza
2008-2009 Subaru Legacy
2008-2009 Subaru Outback
http://www.beatsonicusa.com/nav-dvd-...ic-tvk-54.html
hope Beat Sonic has a good refund policy!
BRZY is offline   Reply With Quote
Old 05-05-2013, 11:07 PM   #81
omegared19
omegared19's Avatar
^^ DUDE!! You're telling me
Old 05-06-2013, 11:12 PM   #82
Rsktrance4mer
Rsktrance4mer's Avatar
Drives: 06 STI & 13 BRZ
so in order for me to play videos while driving all i need to do is cut the ground and reground to the chassis?? sorry was reading this thread and i'm so confused..
Rsktrance4mer is offline   Reply With Quote
Old 05-06-2013, 11:16 PM   #83
Rsktrance4mer
Attachment 9812
Attachment 9813
Attachment 9814
I tired one of the bolts that holds the Unit, no dice. Still blocks out phone functions like dial pad dialing. Tried that screw on the last picture, no dice either.... The ground on the 10 pin connector, I need to cut it then connect with the gray one?
sorry so this picture is from a BRZ? correct?
so the ground would be the pink wire?
or is it the black and blue wire? and once i cut it i just re-attach a wire to extend the wire to the chassis and plug the connector back into the HU?
Old 05-07-2013, 07:16 AM   #84
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by xcelir8brz View Post
cut the grey wire. tape the side going to the front of the car. with the grey wire hanging from the connector, add a wire to that grey wire and solder/tape. next, take the end of the new wire and ground it to 10 pin connector, pin 7 (on your car it looks like a pink wire), on my BRZ, I think it was black. you can also tell if the grounding works by going to the diagnostics menu under settings, and watch the screen with (r)everse, (p)ark, etc.
You can also find a screw on the back of the headunit, and ground the grey wire there. It needs Chassis ground. OR add a really long wire and find a nut/bolt on the car somewhere behind a panel and ground it there.
Where you ground it is not chassis ground (left of head unit nut) image 98.jpg.
10-pin power/speaker harness
1 2 - - 3 4
5 6 7 8 9 10
(orientation: viewing pins on car's factory plug, wires pointed away from you)
Code:
1 RF+
2 LF+
3 +12V Accessory
4 +12V Battery/Constant
5 RF-
6 LF-
7 Ground
8 Power Antenna (provides power to Subaru's antenna booster amp)
9 [NC] {amp remote turn-on signal on Toyota HUs, not Subaru}
10 Illumination+
Follow the above post, but keep in mind this does not complete the bypass. This is only to not need the parking brake up. To complete the bypass,you need to add a switch in the VSS cable to turn it off for instruction input and then back on for normal driving in order for the GPS to work properly.
