Old 04-19-2013, 10:29 AM   #71
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
Nice writeup!
My 2 cents to it. Removing the headlight stalk. Mine wouldn't budge until I squeezed the clamp (obviously) and pulled up on the plastic clip that holds it. You can see the cutout for the clip in picture 20. Its under the metal clamp in picture 18.
FRSFirestorm is offline   Reply With Quote
The Following User Says Thank You to FRSFirestorm For This Useful Post:
imravenit (04-19-2013)
Old 04-19-2013, 10:57 AM   #72
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
very nice write up --- though I'm trying to get a deal with another dealer that is willing to just sell OEM harnesses so with that package, we can toss the other harnesses and use OEM without fiddling with the battery, etc -- just add the harness against the turn signal's harness then to the fog light.
If I do, and get a price i'll let you guys know. -- I won't be selling them but i will refer you to the vendor who does sell it. And I know this harness is an OEM harness from toyota.
CamryDS is offline   Reply With Quote
The Following 3 Users Say Thank You to CamryDS For This Useful Post:
DekaMori (04-19-2013), imravenit (04-19-2013), PANDA86 (04-19-2013)
Old 04-21-2013, 02:26 AM   #73
CamryDS
Hey guys, I think I found the part number. The dealer was selling a set for 72.00's on ebay -- not worth it.
If ANYONE from toyota can verify if this is the part number we need, then hell I can compile the links that we need together to get this stuff at 300 bucks MAX (not including shipping calculated), from just hunting. Should be OEM install- after the part number is verified:
Here's the Part number I Found online:
USA Part Reference: 81515E (this is based off of the diagram, and not searchable)
Japan TOYOTA STOCK CODE: SU003-02583
SO with the only thing that's to be confirmed (harness part number)
Here's what I've found that I can compile for everyone with part numbers:
FRS - ONLY
1 - L & R Bezels - SU00301519 / SU00301518
2 - 2x Outback H11 headlamp Housing -
84501AJ00A
3 - Toyota Socket Fog + Turn signal Harness - S/N (unconfirmed): SU00302583 (I'm waiting for villagescionparts.com to verify, if anyone else knows -- please update) << has been confirmed that this is the wrong part
4 - Toyota Stalk for Foglight - PT/N - 84140-02670
If this is all correct then you can put this kit together for just about 300 and it'll be exactly like the stock setup (minus the crappy plastic housing for glass housing).
The Following User Says Thank You to CamryDS For This Useful Post:
PANDA86 (04-21-2013)
Old 04-27-2013, 10:17 PM   #74
PANDA86
Old School Status
Drives: .
FYI: panel push plugs works well without having to use nuts and bolts. just push it in and youre done. they stay in snug and will do just fine for this modification.
PANDA86 is offline   Reply With Quote
The Following 3 Users Say Thank You to PANDA86 For This Useful Post:
CamryDS (04-28-2013), imravenit (04-28-2013), lbroskee (04-27-2013)
Old 04-28-2013, 03:47 AM   #75
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
so how did you get your fog lights tinted yellow?
imravenit is offline   Reply With Quote
Old 04-28-2013, 06:54 AM   #76
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Buy yellow tint online... It's like $8. Easy to install on small parts. Mine are tinted yellow
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 04-30-2013, 03:16 AM   #77
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Originally Posted by draggin_az View Post
That plate
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
The Following User Says Thank You to Hawaiian For This Useful Post:
draggin_az (04-30-2013)
Old 04-30-2013, 07:04 AM   #78
nigel-jdmparts
nigel-jdmparts's Avatar
Drives: 86
FRS - ONLY
84501AJ00A
Not sure if I am correct, if you are using the glass housing fog light, you cannot use the toyota harness. The toyota 86 fog light do not use H11 application like the Subaru glass housing.
nigel-jdmparts is offline   Reply With Quote
The Following User Says Thank You to nigel-jdmparts For This Useful Post:
CamryDS (04-30-2013)
Old 04-30-2013, 11:30 AM   #79
CamryDS
There should be some type of adaptor. I'm just not keen on pushing wires across the firewall that's not done by oem. None-the-less, thank you.
Old 05-02-2013, 08:48 PM   #80
BlueLeader
Drives: Ultramarine Blue Scion FRS
mind if you tell us which brand? i'm looking and some look orangish and some too light yellow. the one you got is perfect.
BlueLeader is offline   Reply With Quote
Old 05-02-2013, 08:52 PM   #81
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Don't mind the ricer terms... But this is the stuff I ordered, gets the job done.
http://store.ijdmtoy.com/Golden-Yell...ellow-film.htm
Omar GC
Instagram: 2jzus
Old 05-02-2013, 10:25 PM   #82
BlueLeader
oh! that place. that store is literally 5 minutes from my house. lol. ill pick it some up tomorrow. thanks man =)
Old 05-03-2013, 12:37 PM   #83
PANDA86
Old School Status
Drives: .
sorry for the late reply. theyre sprayed.
Old 05-10-2013, 03:19 PM   #84
Tama-Y
Tama-Y's Avatar
Drives: ZN6, DC2
Originally Posted by Juanito08 View Post
I'm running them to turn on when the side markers turn on, super easy and no switch to worry about
Curious about your setup. If you're running in series with the signal light, won't it not be as bright and aren't you afraid of burning out the the bulbs on both if anything goes? Will the fuse be able to handle the voltage?
I thought about this as well, but afraid that it could burn out my PIAA that I spent $80 on.
According to some of the wiring diagrams, power and connection can either be:
1) drawn directly from the battery and switched on by relay in cabin from stalk\button
2) drawn in series with signal then controlled by stalk\button
3) drawn in series with DRL and enabled with\as DRLs
4) drawn in series with Low Beams and enabled with Lows
This question maybe a noob question, but just trying to clear up a few questions I've been wondering about.
(Based on the Outback H11 fogs)
Everyone mentiones that we require a "harness", either made or purchased.
- would that be a connector that splits the male PSX24W connection into a H11 female (fog) & a PSX24W female (signal)?
I'm just trying to bring it down to the basics because for those who aren't as tech-savvy with this stuff. I want to make sure this is what I need to purchase before I get into the wiring. I purchased the H11 "harness", but it turned out only to be an H11 extension. I know we can cut the ends, but I am still i need of the "harness".
Thanks in advance, and sorry if I need a better clarification.
Tama-Y is offline   Reply With Quote
Custom Shadow Led Lights Scion FR-S Precisionleds Cosmetic Modification (Interior/Exterior/Lighting) 84 07-14-2013 04:26 PM
