Old 04-11-2013, 10:15 PM   #239
Plat
Drives: 2013 BRZ Limited SWP
I actually have the same issue or non-issue just like Rinzler. it is good to know that is normal. Maybe it is a Maryland thing lol.
Plat is offline   Reply With Quote
Old 04-11-2013, 11:54 PM   #240
Rinzler
Rinzler's Avatar
Drives: BRZ Limited
Maybe.. It bugged me for a few days, but now I can carry on! :P
Rinzler is offline   Reply With Quote
Old 04-12-2013, 10:15 AM   #241
ShowTime_DW
Drives: FRS
I have question about clutch adjustment. So basically , you adjust the clutch pedal height and also the grab point will following the height? Just wondering if you low the clutch a lot , does the clutch could be grind all the time when release it when driving .
ShowTime_DW is offline   Reply With Quote
Old 04-12-2013, 11:20 AM   #242
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
There's a few videos on youtube about this already. You should go watch it -- When you adjust the clutch height, the engagement is automatically adjusted since that's the 1st thing you will be moving is the rod that raises or lowers the clutch pedal.
The engagement is inherently going to be adjusted lower since it's a ratio thing. The only thing that you have to be concerned about is the clutch spring and boot. If you adjust it too low then there are incidents that the clutch won't spring back (someone on this thread had this issue).
CamryDS is offline   Reply With Quote
Old 04-14-2013, 06:30 PM   #243
Mgivens
Drives: Fr-s MT Ultramarine
Did this today...EXTREMELY easy! I found after a lot of trial and error th clutch felt best for me atexactly two turns... A HUGE improvement over stock...no more over revving!
Mgivens is offline   Reply With Quote
Old 04-15-2013, 08:32 AM   #244
HunterGreene
Hail Magnet
HunterGreene's Avatar
Did this a couple days ago, finally, and it does feel better. I have the clutch pedal sitting about even with the brake pedal, still a bit of dead play, but much less than before.
Couple of tips: If you have a creeper, or something you can set your feet on while you twist and turn the various bits under the dash, it takes a lot of stress off the back. Also, if you don't have a metric wrench set, a standard 1/2" (for 12mm) and 9/16" (for 14mm) wrench will work.
Old 04-17-2013, 04:25 PM   #245
TM
TM's Avatar
Drives: DGM BRZ 6MT
Thanks a lot for the write-up. I will be doing this either later today or tomorrow. The clutch height is the one thing that made me struggle while driving this car when I first got it. I finally got use to the height and I'm able to shift a lot smoother, but I would prefer to lower the clutch if I can.
TM is offline   Reply With Quote
Old 04-17-2013, 04:48 PM   #246
joshH
Drives: 13 BRZ Red, 08 WRX STI
Made this adjustment a couple weeks ago and now it feels like driving a new car. My previous car actually had a much higher grab that I was used to but after driving BRZ for some time it seemed too high for the car. The clutch pedal is now positioned just below the brake.
joshH is offline   Reply With Quote
Old 04-17-2013, 04:54 PM   #247
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
definitely need to give this a go some time soon. should make stop and go traffic a little easier
abutterman is offline   Reply With Quote
Old 04-20-2013, 06:29 PM   #248
dirtbike250x
dirtbike250x's Avatar
Drives: '13 FR-S Ultramarine
Thanks for posting this, very easy adjustment. I made the clutch about even with the brake as many other have, and it feels much better to me. I only drove the car for two days after getting it before I made the change. The short time in the uncomfortable position pays off.
dirtbike250x is offline   Reply With Quote
Old 04-21-2013, 03:57 PM   #249
Boosted
Boosted's Avatar
Drives: 13 brz, 06 STI
I did this a long while ago and have yet to have any issues. For stop and go traffic it is a must. For back roads driving and track driving it allows for a better seating position due to you don't have a awkward length for your left leg (unless your left leg is massively shorter then your right). To not do this free mod that allows this car to be that much better of a sports car is blasphemous .
-Alex
2013 BRZ Limited build: http://www.ft86club.com/forums/showt...d=1#post586737
2006 STI- lots of go fast goodies 551whp/491 Tq on 93(weekend car)
1988 CRX si- b16A1 (Sold)
RIP 2003 WRX
Boosted is offline   Reply With Quote
Old 04-25-2013, 08:38 PM   #250
harshk
Drives: 2013 Scion FR-S (Raven)
Wow, nice. I've been driving my new FRS for a couple of weeks now and have been getting annoyed at the clutch engagement. Can't wait to try this our.
harshk is offline   Reply With Quote
Old 04-27-2013, 03:30 PM   #251
slowbrz
Drives: '13 black BRZ MT
Anyone else find it hard to screw the bolt in? After a couple turns, it just stops going with my hand; now Im unable to turn it either way and it is stuck in its position
also, should the bolt be threading in deeper, or should it be going out more (closer towards firewall) if I want the grab point to be closer?
slowbrz is offline   Reply With Quote
Old 04-27-2013, 07:47 PM   #252
Koji_Online
N7 Spectre
Koji_Online's Avatar
Drives: 2017 Toyota 86 (Ablaze - 6MT)
Smile
Heya, you have to use your other hand to put pressure on the face of the pedal while you screw it in with your other hand; this relieves the pressure from the threads & will get you unstuck =p
You are going to be threading into the pedal & away from the firewall, in order to bring the grab point closer to the floor.
GT 6/ Sport PSN: Koji_Online
Koji_Online is offline   Reply With Quote
The Following User Says Thank You to Koji_Online For This Useful Post:
slowbrz (04-27-2013)
clutch adjustment, clutch helper spring
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 03:41 PM
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 10:17 PM
Any (easy) way to stiffen up the feel of the clutch? Partial Stall Engine, Exhaust, Transmission 41 07-19-2012 02:17 PM
My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* wanger Scion FR-S / Toyota 86 GT86 General Forum 5 06-02-2012 01:41 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
