#15 |
Lost in Kansas
Drives: 2013 Scion FRS (Raven)
Definitely like the new proposal.
Now we just gotta hope they get the MSR MX-5s and ZOK Soltices (Solstii?) out of CS. |
#16 | |
The Crawford can through its mounting also happens to tie together the two diagonal braces, which also isn't legal. |
| The Following 2 Users Say Thank You to xwd For This Useful Post: | Scooby South (04-23-2013), whataboutbob (04-24-2013) |
#17 | |
Conedancer
Drives: 2013 Subaru BRZ SWP
Bill
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
#18 | |
Typically the remotes allow for extra oil which means less heat, also sometimes the shock components work better because you aren't having to package so much in the shock body. It can also allow compression to be adjusted easier since they are typically easy to get to versus having to monkey with something on the bottom of the shock. |
#19 | |
#20 |
Conedancer
^^ Agreed. ... had a shot at 2812's .. but didn't work out..
Someone that can't afford the OMG stuff.. shouldn't be precluded from running for a title just because they can't afford the top shelf livery.. .. Again my opinion.. Autocross is meant to be affordable for the Average Joe... for the most part.. But I also understand the other side..![]() Bill
#21 |
Like Sam has said plenty of times many championships have been won on off the shelf or simply revalved Konis and even stock shocks. In the end it is a tenths type of gain, not seconds.
#22 |
Drives: BRZ(sold), STI
#23 |
Finding a lightweight 16x7 in the right offset isn't easy. Rota used to make the slipstream in +48, about 14 lbs, but they stopped making them a long time ago. You can find the motegi traklite in 16x7 +50 but they aren't cheap. 17x7 has more tire options, 16x7 the 225/50 is the only real tire offered.
#24 |
AutoX Addict
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
I guess that will eventually be legal lol
Sent from my Galaxy S3 using Tapatalk 2
2013 BRZ Limited- GBS - 6MT -VIN #0937 ~~NYR SCCA # 18 C Street R (CSR)~~ "But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson |
#25 |
I'm new to this auto x stuff.. Can someone clarify the T/C rules, particularly as it relates to our car? It seems like they deleted the rule that allows us to disable it when they removed 13.10.O, is that correct?
2013 Asphalt FR-S 6MT - Perrin 2.5" Catback Exhaust - Grimmspeed Strut Tower Bar - Grimmspeed Master Cylinder Brace
Grimmspeed Hood Struts - Grimmspeed 86 Oil Cap - Grimmspeed Boxer Battery Tie Down - HID - Pioneer AVH-X5500BHS - Infinity Basslink 10" Sub |
#26 |
If you can disable it via an existing method the car supports via buttons, switches, etc. then you are free to do so. The original allowance they added in was to allow people to change the T/C computer and vehicle ECU for all vehicles, they narrowed it down now to ONLY vehicles which do not have another method to defeat it. The only "autocross" car right now which comes to mind is the VW GTI.
So no change for us, you can defeat it by holding the button down or doing the "pedal dance" trick. |
| Let's discuss SCCA Stock Class | ayau | Tracking / Autocross / HPDE / Drifting | 314 | 04-18-2013 02:03 PM |
| April SCCA Fastrack | xwd | Tracking / Autocross / HPDE / Drifting | 86 | 04-05-2013 08:48 AM |
| 2012 BRZ/FR-S Stock Class Autocross Discussion | EMguy | Tracking / Autocross / HPDE / Drifting | 183 | 01-04-2013 03:17 AM |
| November Fastrack | xwd | Tracking / Autocross / HPDE / Drifting | 2 | 10-23-2012 06:26 PM |
| And the Winner is:...........BRZ to STX ..Oct fastrack | Scooby South | Tracking / Autocross / HPDE / Drifting | 79 | 09-28-2012 03:40 AM |
