Old 04-26-2013, 12:12 PM   #1
Driveshaft Shop
Drives: 31 Ford, Viper GTS,65 Riviera,Cayen
DriveShaft's and Axle's
Hey guys since this is a newer market and these items were just put on the website i wanted to share with y'all. We are also doing some work on getting the Driveshaft's made you you automatic guys/gals as well.
Here are the links to our products.
Carbon-Fiber
http://www.driveshaftshop.com/import-driveshafts/toyota/gt86/2012-scion-frs-subaru-brz-toyota-gt86-3-5-aluminum-1-piece-driveshaft
600 HP axles Direct fit
http://www.driveshaftshop.com/import-axles/toyota/gt86/2013-subaru-brz-scion-frs-toyota-gt86-600hp-direct-bolt-in-rear-axles
Pro-level axle/hub kit
http://www.driveshaftshop.com/import-axles/toyota/gt86/2012-scion-frs-subaru-brz-toyota-gt86-pro-level-axle-hub-kit
Let us know if we can build anything else (drive line wise) for y'all
Driveshaft Shop is offline   Reply With Quote
The Following User Says Thank You to Driveshaft Shop For This Useful Post:
usptwins (04-27-2013)
Old 04-26-2013, 12:43 PM   #2
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
I'd like to see some aluminum drive shafts and loops.
post_break is offline   Reply With Quote
The Following 3 Users Say Thank You to post_break For This Useful Post:
charged86 (04-29-2013), soros151 (04-29-2013), usptwins (04-27-2013)
Old 04-26-2013, 12:52 PM   #3
robispec
Drives: Black frs project
how about some superlightweight axles for the NA crowd? also it looks like the super low crowd (with extended rear travel) will need longer axles too...I just broke a bearing cage and the wear is in the outer third of the plunge joint
robispec is offline   Reply With Quote
Old 04-26-2013, 12:57 PM   #4
OrbitalEllipses
Drives: Attitude
Robi inadvertently proves herrafrushcambermadlowtyteyo! bros ARE wrecking their cars.
Not saying Robi's car is like that since it's a racecar and all.
Chewie4299 (05-06-2013)
Old 04-26-2013, 01:12 PM   #5
robispec
I'm a charter member of the "HelleFUNCTIONAL" group....
lol
Robi
The Following 3 Users Say Thank You to robispec For This Useful Post:
Chewie4299 (05-06-2013), FasterpromsFRS (04-27-2013), Pitman (07-23-2013)
Old 04-26-2013, 01:35 PM   #6
OrbitalEllipses
Drives: Attitude
lol
Robi
We know
Old 04-26-2013, 01:53 PM   #7
stockysnail
Just the tip
stockysnail's Avatar
I'll keep this on my wish list for when my build gets to this point. No money for this currently.
Old 04-26-2013, 02:25 PM   #8
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Everything you'd need to upgrade in the rear for hard launches with a lot of power at the strip.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 04-26-2013, 05:59 PM   #9
Driveshaft Shop
light and strong sometimes are hard to put into the same axle, NA cars have instentanious Hp and will give an axle a good shock Factor. with dimensions i can custom make the bars to the right length (actuall have them already) we can lighten the inner CV also
here is the "Wall of bars"
ProjectD (04-27-2013)
Old 04-27-2013, 12:01 AM   #10
ben15r
ben15r's Avatar
Drives: FBM stage 1 rebadged FRS
Just broke one tonight will be ordered on Monday
ben15r is offline   Reply With Quote
Old 04-27-2013, 12:09 AM   #11
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Why does The Driveshaft Shop give whp ratings? I would have thought torque would have been the measurement to use.
Old 04-27-2013, 04:39 PM   #12
ben15r
ben15r's Avatar
We were looking at mine when we pulled it today it looks like the harder the car squats the more angle you get in the inboard joint and the shorter the distance from the hub to the diff becomes.
my question, do these allow for more angle?
Old 04-27-2013, 04:49 PM   #13
robispec
My wear pattern was at the outboard end of the inner joint..as the car squats the axle lengtj gets longer. Not shorter...
Old 04-27-2013, 04:59 PM   #14
ben15r
ben15r's Avatar
when the suspension was completely relaxed the distance from the hub to the diff is longer than when the suspension was as compressed as we could get it
http://www.ft86club.com/forums/showthread.php?t=34943
there are the pix from this morning, I have been lowered since about aug
Replacing Axle's in my Elantra suprachica79 Other Vehicles & General Automotive Discussions 3 10-16-2011 10:25 PM
