| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Wheel Directory: Enkei NT-03M 18x9.5 +40
![]() Here is our Black FR-S with White NT03+M Wheels: 18x9.5 +40 Front Tires: Yokohama S-Drive 225/40/18 Rear Tires: Yokohama S-Drive 245/35/18 Coilovers: Stance Super Sport + SWIFT Springs ![]()
#2 |
#3 |
Here's another....
#4 |
NW Region Moderator
Drives: FR-S No More
Added to the Wheel Directory:
http://tinyurl.com/86wheels
#5 | ||
We couldn't fit the rear setup up front due to the inside of the tires rubbing on the inner fender liner at full lock. With a slightly lower offset you should be able to fit, but will require some camber to clear the fenders. The 225 tires up front at full lock we have about .5" of clearance. |
#6 | |
#7 |
It is just thin plastic, but directly behind it is the subframe. by removing the plastic panel wouldn't really gain too much. I think our offset is just on the high side. Lower offset would allow for good clearance inboard and fender for larger tires. The high offset and width of the wheels would cause clearance issues with certain coilovers too I'd think.
#8 |
#9 |
It should work on the stock suspension given that you have enough height clearance between the tire and fender. Under full compression, I wouldn't be surprised if you rubbed with 245's up front.
#10 |
#11 |
#12 |
Enkei NT03+m 18x9.5 +40 265's squared
Sup guys, got my wheels in today and can't be any happier! I still need to work on camber in the front to make it sit flush, but I need to get camber strut tops or coilovers. Until then here are a couple of teasers and I will post better pics when I get more time.
.... And yes they're BLACK!!! ![]() ![]() ![]() Finally picked up a Nikon D5100 and took some pics at work. Im still learning how to use this thing but Its still much better than the Iphone^^^. Also installed some ISC coilovers and the wheels fit much better up front. ![]() ![]() ![]() ![]() ![]()
#13 |
#14 | |
Drives: On track
18x9.5 +40 can fit with 265 all around with proper camber settings. The rear might just slightly rub the bumper plastic at worst accoding to customers. |
| Wheel Directory: Enkei RS05RR 18x9.5 +43 | FT-86 SpeedFactory | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 129 | 09-22-2019 10:39 PM |
| Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 | GuerillaRacing | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 221 | 08-01-2019 10:30 AM |
| Wheel Directory: Enkei RPF1 18x9.5 +38 | FRS8SIX | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 297 | 02-15-2018 03:50 PM |
| Wheel Directory: Enkei Tenjin 18x8.5 +45/18x9.5 +45 | Sciby | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 11-10-2014 12:53 AM |
| Wheel Directory: Work Meister S1 3-Pc 18x9.5 +29 / 18x9.5 +24 | PradiG | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 48 | 12-12-2013 03:15 AM |
