Old 04-25-2013, 10:19 AM   #29
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
From an ACT owner review, the ACT is worse than the Clutchmasters for driveability because their flywheel is even lighter the CM and because of this the car about stalls everytime you put it in neutral.
Thanks a lot im not getting it lol
Silverdub is offline   Reply With Quote
The Following User Says Thank You to Silverdub For This Useful Post:
Sportsguy83 (04-25-2013)
Old 04-25-2013, 10:31 AM   #30
dabocx
dabocx's Avatar
Drives: Scion FRS
Im narrowing it down to the excedy stage one or the clutchmasters 300
dabocx is offline   Reply With Quote
Old 04-25-2013, 11:07 AM   #31
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
My final choice was exactly between both
Old 04-25-2013, 04:53 PM   #32
lexusb3
Drives: FRS
I'll start driving the Clutchmasters FX300 this weekend. Will input feedback here ASAP.
im curious on how its drives as well the reason im not on higher boost because i rather get a clutch first im in tune for your review
lexusb3 is offline   Reply With Quote
The Following User Says Thank You to lexusb3 For This Useful Post:
Old 04-25-2013, 05:45 PM   #33
Mrc@ptuning
Mrc@ptuning's Avatar
Drives: S1000RR
You can't beat the pedal feel of the exedy stage 1. When I say the pedal pressure feels like stock, I really mean It literally feels like stock. Even with 345whp(DD) there's no clutch slippage and no heavy-ass pedal pressure that can kill your master/slave cylinder.
MrC
Mrc@ptuning is offline   Reply With Quote
The Following 4 Users Say Thank You to Mrc@ptuning For This Useful Post:
ecko04 (06-01-2013), Khyron686 (06-20-2014), KSpider (10-23-2013), Pete (04-27-2013)
Old 04-25-2013, 05:52 PM   #34
Unleashed
Unleashed's Avatar
Drives: 13' WRX
That bad really? Kinda concerning since that is what is being installed on my car as I type this. Oh well, I'm up for a learning curve I guess. On the plus side though, if its that light it must rev pretty quick and feel very responsive.
Unleashed is offline   Reply With Quote
Old 04-25-2013, 05:58 PM   #35
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
Do you know which ACT flywheel they used (11.8lb or 10.5lb)? Also do you by chance know the Clutchmasters flywheel weight?
The 3 streetlite (11.8lb) setups I have sold with the SS street disc the customers have been very happy with. Just a bit more aggressive than the stock clutch.
I have another guy who has a Clutchmasters FX400 which doesn't stall, but it makes a whole bunch of noise with the clutch in, or when taking off from a stop sometimes.
I am trying to figure out what should be the go-to clutch for this car. I have no brand allegiance's. For the past few years ACT has been on there game, and I had planned on putting either a street or 6 puck sprung ACT in our car when I install the turbo kit.
Adam
Adam
No Limit Motorsport is offline   Reply With Quote
Old 04-25-2013, 07:46 PM   #36
Sportsguy83
Drives: Limited BRZ
Please, take my word with a huge grain of salt, as I have not driven it, but just relay information a friend who drives it told me.
Adam
Adam
I believe it was the 10.5 lb and I believe that is the main culprit. The 11.8 should be noticeably better. Also it was a modified car with LW Pulley too.
I will let you know as soon as I'm driving the clutchmasters how good/bad it performs (FX300).
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Unleashed (04-25-2013)
Old 04-25-2013, 07:49 PM   #37
Sportsguy83
Drives: Limited BRZ
MrC
I was leaning heavily towards Exedy. Three things swayed me towards CM:
1) Reviews for both online were more favorable towards CM (not on our cars, but any car in general).
2) Exedy was not yet available at the time so I would have had to wait a bit.
3) The torque rating was higher for the CM.
I think they are both awesome clutches.
Old 04-26-2013, 08:10 AM   #38
No Limit Motorsport
Originally Posted by ptuning View Post
We use the Exedy Stage 1 Clutch on our 345whp, 257wtq FR-S. We can tell you with certainty, that it is the closest that you'll get to the stock clutch, in terms of range of modulation and overall feel. There is a little bit of clutch noise when idling in neutral, but it's very minor compared to most other aftermarket clutches. This clutch is 100% parallel parking friendly.
Please contact us, if you'd like any additional information.
Have had good luck with this clutch on WRX/STI, but in this case, the stage 1 for BRZ/FRS is only rated at 203 wheel torque, so I feel like it is only a matter of time before it calls it quits in a turbo application.
Specs:
Disc Size 225mm
Spline Teeth / Major Dia24T / 25.2mm
Clamping Force/Load exerted (lbs)1652
Disc Material Organic
Number of Disc Single
Type (Push/Pull) Push
Sprung Center (D-core) Yes
Clutch Torque 319
Torque Capacity at Wheels 203
Torque Capacity at Flywheel 254
Flywheel Weight FF503
Old 04-26-2013, 08:30 PM   #39
Sportsguy83
Drives: Limited BRZ
Originally Posted by Supermassive View Post
http://clutchmasters.com/shop/?page=...195&AppID=5310
The VividRacing FR-S had one in it way back when...at least they claimed that they did.
So, it seems you were right. It LOOKS like i got the FX350, not the FX300.
EDIT: Box says FX300
Look at the face of the disc I got:
Now look at the face of the FX 350. Look closely at the friction surface, even though its different colors, it is the same shape and size. The small contact areas are completely separated by themselves.
Now look at the FX300 face and see how instead of being completely separated per contact area, there is still a little bit of material on the edges to connect the whole contact area as one.
Reviews to come as soon as I am able to drive it!
Old 04-27-2013, 09:08 AM   #40
Nothing
Drives: FRS
I have the ACT 6 puck and lightweight flywheel. I hate it but hopefully I can get a more streetable disc like the FX350 later on. Just need to give manufacturers time to catch up.
Nothing is offline   Reply With Quote
Old 04-27-2013, 12:06 PM   #41
jamesm
Call me crazy but I'm a fan of a weak clutch. Well, not weak, but you don't want it to the the strongest link in the chain, you want it to be a drivetrain fuse. I made that mistake on a wrx and went from having a bit of clutch slip to having two gearboxes grenade at the strip. Clutches are cheaper to replace than gears.
The Following 7 Users Say Thank You to jamesm For This Useful Post:
acro (01-31-2015), bakerr6 (05-27-2014), mrk1 (02-23-2014), No Limit Motorsport (04-27-2013), radroach (04-28-2013), SirBrass (01-31-2014), Sportsguy83 (04-27-2013)
Old 04-27-2013, 12:24 PM   #42
No Limit Motorsport
Which flywheel prolite or streetlite and is it a sprung or unsprung disc? If you have the part number on an invoice that will tell us. I am trying to get opinions on what is working well.
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 12:11 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
