Old 04-25-2013, 01:21 AM   #393
Ghostmerlott
Drives: GT86
Originally Posted by Brody602 View Post
Hmm, I thought the unit with green led's was a little wider, i really wish someone would make a dash kit that wouldn't need any modification..
But the harness is plug and play on the green one right?
@nzer would be able to confirm that once he receives it in next couple of days..
we were actually curious on why the 30$ markup over the tun21a given that the specs are exactly the same!
Ghostmerlott is offline   Reply With Quote
Old 04-25-2013, 01:29 AM   #394
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
The TUN21A has a 6.2" lcd screen, the T7019A has a 6.5" lcd screen, thats why I was under the impression it would be a perfect fit, that's probably where rhe 30$ mark up kicks, also housing may cost a little more to manufacture.
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 04-25-2013, 01:30 AM   #395
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Patience grasshopper
nzer is offline   Reply With Quote
Old 04-25-2013, 01:31 AM   #396
Ghostmerlott
Drives: GT86
True that..
Old 04-25-2013, 04:12 AM   #397
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
The photo on the website showed green LED's on the one I've bought but it turned out to be blue.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 04-25-2013, 06:18 AM   #398
2forme
Eagerly waiting for results, i think if it's a perfect fit/rootable, plug and play, I'll deal with the green led's if they're too hard to swap out!
They all need the dash kit , there are gaps on the left n right.. You have got a choice of the Metra or Beatsonic..
Let me clear a few things up.
The TUN21A is a universal fit. Requires the beat sonic kit to fit correctly (though I might just buy a 3D printer and make my own haha). It also has a capacitive screen and blue LEDs.
The other is a 200mm wide toyota fit head unit...HOWEVER you will need to modify the bezel of it to get your dash bezel to fit. The dash bezel won't snap in completely on the bottom because it hits part of the radio bezel. This is all behind the dash, nothing you actually see needs to be modified. It also has a plug and play harness for using the internal amp on the speakers. You still need to run RCAs for a external amps. You still need the antenna adapter. It has green LEDs. It is also a resistive touch screen.
Hope this clarifies everything.
Old 04-25-2013, 06:23 AM   #399
sav
sav's Avatar
@2forme - are you sure about modifying the bezel? I've bought a 200mm wide one from Trade Solution and got it to fit perfectly without modifying the bezel. The trick was to drill the OEM metal plate out a bit to give it more room for adjustment. The radio had to go a little bit further back and angle down a bit more else it would catch at the top.
Also, if you're buying a universal unit I would suggest the GT86 specific kit from connects2
http://www.connects2.co.uk/c2/c2Rang....aspx?id=11383
95RON SAV Tuned
Old 04-25-2013, 06:52 AM   #400
2forme
Yea I got it to fit, but my point is that it's not a simple drop in. Some modification is necessary.
Old 04-25-2013, 07:03 AM   #401
sav
sav's Avatar
Agreed, just don't modify the radio itself.
95RON SAV Tuned
Old 04-25-2013, 07:39 AM   #402
Ghostmerlott
Drives: GT86
The "plug and play harness for using the internal amp"... are you referring to the wiring harness? Does the Tun21A come with the wiring harness too? If thats the case, I will skip the wiring harness purchase...
Old 04-25-2013, 07:41 AM   #403
2forme
The TUN21A comes with a universal harness for the radio only. You still have to get a kit to use your OEM harness that's in the dash and wire the two together.
The other one has a harness that just clips into the stock harness, no wiring necessary except for external amps and the antenna power.
Old 04-25-2013, 07:47 AM   #404
Ghostmerlott
Drives: GT86
That explains the 30$ premium !
Beatsonic wiring harness + dash kit will come to around that $$. So the two will come to around the same price in total cost.. So its whether u prefer blue or green leds... and the comfort level of connecting wires from the unit to the car. Personally I find the tun21a having more buttons might be useful..
Old 04-25-2013, 07:52 AM   #405
2forme
Not to mention the TUN21A is capacitive touch....
Old 04-25-2013, 09:02 AM   #406
Brody602
Drift King
Brody602's Avatar
If you go look at the specs of the T7019A, under the screen dimension it says that it is indeed a Capacitive.. Don't know where you seen resistive?
Samsung Galaxy Note SGH-I717 - 16GB - Carbon blue (Unlocked & Rooted) JPxM0Dz Canada Classifieds 2 01-19-2013 11:51 PM
chinese man sues wife for being ugly: wins wrxgoose Off-Topic Lounge [WARNING: NO POLITICS] 15 11-07-2012 10:58 AM
Counterfeit Chinese Airbags @Art_Mighty Other Vehicles & General Automotive Discussions 11 11-03-2012 03:20 AM
JDM Vs. KnockOff SIRvive Off-Topic Lounge [WARNING: NO POLITICS] 4 03-05-2012 05:32 PM
Gang of Chinese kick, yell, and drag a little caucasian boy Giccin Off-Topic Lounge [WARNING: NO POLITICS] 34 01-20-2012 10:47 PM
