Old 04-24-2013, 04:50 PM   #15
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Supermassive View Post
Well if that's the case that kinda sucks...
345 WTQ is not enough for you? (Honest question).
Or what is it that sucks?
Edit: I find it interesting that on he site the FX300 is n ot for sale, and the FX350 says "new".
I should have a pic of mine soon to try and determine what is it that I really got
Old 04-24-2013, 04:58 PM   #16
Supermassive
Supermassive's Avatar
No...the car is likely going to be pushing near 400Wtq, not crank torque which is the measurement the manufacturers claim as holding capacity. I'm currently finishing some cosmetic work on the car before I turn up the boost and start replacing internals and such. I want to be running about 450-500WHP and 400+ ftlbs on pump gas after I finish the engine. I figure that that is doable, but I have been putting it off until a few shops start getting reliable numbers from built engines and give some insight into why they chose some of the components they decide to use. For now though I will just push my boost up to 12PSI or so and be content until i have some free cash for some forged bits
Supermassive is offline   Reply With Quote
Old 04-24-2013, 08:26 PM   #17
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
I never take the manufacturers claims to heart when it comes to clutches. I had a sintered iron FX500 that didn't even hold over 420wtq. Whenever someone tells me what their capacity is, i just subtract about 80ftlbs just for good measure.
I can't even begin to think the torture this transmission is going to go through at 400wtq. But my predictions are that the manual will not support that power level indefinitely. Fine for a weekend warrior. But I cringe to think of someone making that power with an aggressive clutch setup.
The gears in this transmission are pretty small. Big torque will be destroying these transmissions. But I do wish you the best of luck and look forward to the craziness!
Coheed is offline   Reply With Quote
Old 04-24-2013, 08:38 PM   #18
jamesm
Originally Posted by ptuning View Post
We use the Exedy Stage 1 Clutch on our 345whp, 257wtq FR-S. We can tell you with certainty, that it is the closest that you'll get to the stock clutch, in terms of range of modulation and overall feel. There is a little bit of clutch noise when idling in neutral, but it's very minor compared to most other aftermarket clutches. This clutch is 100% parallel parking friendly.
Please contact us, if you'd like any additional information.
Isn't the stage 1 rated at around 240tq?
Old 04-24-2013, 08:41 PM   #19
FirestormFRS
There are a lot weaker links in the driveline than the gears. Gears are freaking stout no matter how small they appear they take a lot to break. I'd bet on axles being the weak link in any highpower/high traction enviroment.
FirestormFRS is offline   Reply With Quote
Old 04-24-2013, 08:44 PM   #20
ptuning
ptuning's Avatar
Drives: White FR-S
It's rated at 319TQ.
ptuning is offline   Reply With Quote
Old 04-24-2013, 09:11 PM   #21
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Glad to read this. I want a combo withflywheel but i dont want thr crazy nouses like clutch master. Hopefully act isnt as bad...
Silverdub is offline   Reply With Quote
Old 04-25-2013, 12:11 AM   #22
Coheed
Coheed's Avatar
I don't see the gears in this tranny being any stronger than the SR20 6 speed boxes I'm used to. And they break at 400wtq all the time. I've pushed 1" axles to 600hp without fail on a daily driven car. But somehow, gears seem to be more prone to fatigue over time. I've shattered many gearboxes in the past, so my approach is... different.
Old 04-25-2013, 12:29 AM   #23
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
well its been already proven that the axles are a weak link, Fullblown want to upgrade theirs before running it around the strip and so. E.kanoo from bahrain who owns the 2jzgte +v160 gearbox swapped gt86 snapped his axles as he dragged the car with 500sh wheel hp.
[ame="http://www.youtube.com/watch?v=tUp8-vKt6Ug"]2jz Toyota GT86 breaking an axle - YouTube[/ame]
Old 04-25-2013, 12:32 AM   #24
Coheed
Coheed's Avatar
The axles and trans are weak links. But surely I'd expect axles to break with a 2jz hooked up. But at only 500whp? Must be really sticky rubber.
I don't expect the transmission to break 1-3rd. 4-6th are small though.
Old 04-25-2013, 12:39 AM   #25
SmsAlSuwaidi
Boosted
combination of some sticky rubber and a hard launch i guess.
i do agree both are the weak links, id bet axles before trans though. But if somebody decides to flat foot shift 1 to 2 on even 300 wheel with an aggressive clutch i bet he'd break it too
Old 04-25-2013, 12:46 AM   #26
Coheed
Coheed's Avatar
I find that strange, because most axles this size hold up to much more power. A 2-step can break them, but I wouldn't imagine 350-400whp causing much issue. I guess we'll just have to see in a year which one has more failures huh?
Old 04-25-2013, 01:30 AM   #27
crook
crook's Avatar
Drives: storm black GT
Torque and shock break axels, not rated on horsepower. if your running a solid centre button clutch heaps of torque and load the girl up and drop 2nd... Expect something to give
crook is offline   Reply With Quote
Old 04-25-2013, 06:59 AM   #28
Sportsguy83
Drives: Limited BRZ
From an ACT owner review, the ACT is worse than the Clutchmasters for driveability because their flywheel is even lighter the CM and because of this the car about stalls everytime you put it in neutral.
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 12:11 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
