Old 04-24-2013, 06:49 PM   #99
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by Frs300 View Post
I hope not
If i did im driving it back without a turbo. but i havent heard if the turbo was good or bad yet.
Have it checked regardless.
I had a friend with a 2.5RS which blew out a timing pulley. The valves hit the pistons and we found the STEM of an intake valve in the exhaust manifold. Considering how much confetti there was in your "event", it's worth giving the turbo a look-see to be 100% sure it didn't try to ingest anything.
Draco-REX is offline
Old 04-24-2013, 08:05 PM   #100
Frs300
Frs300's Avatar
Drives: Pile of junk
fa20club sent it off to get inspected
Frs300 is offline
Old 04-24-2013, 08:39 PM   #101
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Originally Posted by buditjoenawan View Post
Not to derail the original thread too much, but I just had to chime in regarding catalytic converters before the turbocharger. It is a TERRIBLE idea. So terrible, in fact, that Subaru STOPPED doing that after the 2003 WRX. @cf6mech's motor is fine, but his turbocharger is destroyed due to debris from the catalytic converter. At least that's how I understood the situation.
That said, please think twice about putting a turbocharger right after the stock header. ESPECIALLY that cat which isn't rated to withstand the kinds of heat a turbocharged setup produces.
Budi
Every STS turbo car puts the turbo after the cat. I've never heard of a cat failure being ingested by the turbine. Not to say it doesn't happen, but I would bet it's a rare scenario.
Coheed is offline
Old 04-24-2013, 10:17 PM   #102
buditjoenawan
Drives: Very very slowly
And how far away is the turbocharger from the cat in sts systems? Visualize the glowing hot turbine housing and merge collectors when the car is ran hard. Then visualize a cat right next to that. Not a good recipe. I would ask tuners and motor builders to chime in here.
Budi
buditjoenawan is offline
Old 04-24-2013, 11:49 PM   #103
Coheed
Coheed's Avatar
Budi
I'm not really sure what the catalyst temp would be in comparison, but this is likely the culprit. But I do know that the sts systems do create quite a bit of backpressure. Perhaps EGTs should be looked at carefully to ensure the cat stays happy. But generally with a ceramic substrate catalyst the engine starts to melt before the cat falls apart... unless that catalyst has been overheated by running too rich of mixtures or burning oil.
Coheed is offline
Old 04-25-2013, 12:08 AM   #104
jamesm
Originally Posted by SkullWorks View Post
That is unfortunate, I mentioned this to Don on the day he debuted the setup and he said I was uninformed and that that was very common, even tried to tell me OEM's did it all the time...Im sorry someone else had to learn that lesson for him.
Some cars do. My old mazdaspeed miata had one between the head and the turbo iirc. Early (u.s. model) wrxs had them in the uppipe as well.
jamesm is offline
Old 04-25-2013, 04:38 AM   #105
Tradewind
Drives: 2006 Subaru Liberty EZ30 S/charged
I think the clutch pictures are a bit telling, some amount of torture occured before this motor blew, wasnt just an easy drive home from the dealer and suddenly motor went bang with just mild driving - NO SIR
Toyota 86 test driver
Tradewind is offline
Old 04-25-2013, 07:04 AM   #106
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Reading the thread where FRS300 stated he blew his engine would help you even more than the pictures. OP never stated or tried to imply it was an "easy drive from the dealer and motor went boom with mild driving"......
Edit: I think I may have misunderstood your post, sorry was sleepy
Sportsguy83 is offline
Old 04-25-2013, 08:40 AM   #107
Frs300
Frs300's Avatar
Clutch slipped when motor blew.
Frs300 is offline
Old 04-25-2013, 09:06 AM   #108
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
Which headgaskets and studs are you using?
No Limit Motorsport is offline
Old 04-25-2013, 09:17 AM   #109
No Limit Motorsport
I was not aware of anyone running a motor with lower compression pistons yet. I think there was a guy in Texas with an Accelerated kit that was putting pistons in, but I haven't seen him post recently. Full Blown is waiting to blow theirs up to install pistons. I have definitely considered just swapping in lower compression pistsons and rods to get some more power.
I have a local customer with the low compression CP's and a set of Pauter rods running an AP turbo kit with a GTX3071. 18psi is low boost now.
Old 04-25-2013, 10:11 AM   #110
ft_sjo
Drives: GT86
18 psi has always been low boost on a 2 litre engine
ft_sjo is offline
Old 04-25-2013, 10:38 AM   #111
Frs300
Frs300's Avatar
Not real sure what toni went with...which ones did your customer use?
Frs300 is offline
Old 04-25-2013, 11:02 AM   #112
Dustin@Dynosty
We have case studs and head studs available if FA20Club needs them for your build
Dustin@Dynosty is offline
#car in litigation?, #ferris bueller ferrari?, 12 year build, 5 month engine build, are we there yet?, edging, fantasy, innovate thread pt.2, its happening!!!!, keep calm and carry on, maybe tomorrow?, not today, not viscontiqued ftw, the neverending build, unicorn!, vaporware
Full Blown Stage 1 Short Block FullBlown Forced Induction 116 03-22-2019 07:29 PM
Full Blown 521hp Stock Motor @ 20psi FullBlown Forced Induction 276 08-31-2016 02:05 AM
How often to rebuild coilovers or stock shocks? stockysnail Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 12-24-2012 12:54 PM
2013 FR-S / BRZ (The R&D has Begun) Cotnoir CANADA 10 06-26-2012 03:08 PM
PM Spammers, it's begun! Beast Off-Topic Lounge [WARNING: NO POLITICS] 11 01-30-2010 01:13 PM
