Old 04-23-2013, 04:20 PM   #15
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
I've tried several times to get mine to work with no success.
No biggie, primary reason for wanting it was to turn the DRL's off. I managed to do that with a relay swap.
FRSFirestorm is offline   Reply With Quote
Old 04-23-2013, 06:03 PM   #16
Yruyur
Yruyur's Avatar
Originally Posted by naikaidriver View Post
That's it! I'm done waiting!
I am going to design a box that sends these EXACT "pedal dance" signals to the ECU that I can activate with a simple, plunger-button on my dash!
Shouldn't be too hard.
Scott
I did see an option in there about inspection mode for cars that did not have a vsc button. Not sure if its just for testing though.
Old 04-23-2013, 06:06 PM   #17
kanundrum
Drives: 2013 Whiteout FR-S
If this can turn off tpms light I am in!
Old 04-23-2013, 06:11 PM   #18
xjohnx
Grip>Slip
xjohnx's Avatar
Nope, unfortunately not.
kanundrum (04-23-2013)
Old 04-23-2013, 06:13 PM   #19
kanundrum
doh
Old 04-23-2013, 06:17 PM   #20
ftc~brz
Done
Drives: WRB BRZ
those @#$@ers at the steelership told me the buzzer couldn't be turned up! LIES all LIES!
Ty for this rad post!
ftc~brz is offline   Reply With Quote
The Following 3 Users Say Thank You to ftc~brz For This Useful Post:
Fly Guy (04-26-2013), ill86 (07-20-2013), Jamifra (04-29-2013)
Old 04-24-2013, 12:38 AM   #21
dokterdewe
dokterdewe's Avatar
Drives: an automatic lightning red 86
Send a message via Yahoo to dokterdewe
Why did the techstream in my dealer didnt have the option to turn ON the DRL... i want my LED to act as what they should be...
dokterdewe is offline   Reply With Quote
Old 04-24-2013, 01:48 AM   #22
Yruyur
Yruyur's Avatar
You could have the old ecu. I believe there was a tsb for a new ecu that added that option.
Sent from my GT-P3113
Old 04-24-2013, 08:00 AM   #23
wparsons
wparsons's Avatar
I would bet the ambient air temperature adjustment is to correct the reading from the outside temp sensor. Mine consistently reads about 2* C too warm.
flickr
Old 04-24-2013, 08:24 AM   #24
Freude am Fahren
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
What's the autolock you turned off? Is it supposed to be that the car autolocks when the fob is not in wireless range for set amount of time? I tried to test mine and it didn't autolock. I'd actually like this, in case I forget to lock it.
Or is it one of those ones where if you unlock but don't open anything, it re-locks?
I also want to be able to turn up the beep. It's so quiet.
Too bad there's not a way to turn on the parking light halo things on with DRL's
-XXR 527 18x8.75 +35
-Nameless 2.5" OP/FP Combo (Coming soon) & Axleback
-SBD 500X (Waiting on coating to install)
-Southbend SBD500X Clutch
Freude am Fahren is offline   Reply With Quote
Old 04-24-2013, 08:48 AM   #25
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Originally Posted by xxscaxx View Post
Thanks for this post. Timely too as I purchased the same from that ebay seller and am just waiting for it to arrive.
I bought it because I had to get some module replaced inside my BRZ when I first bought it, and ever since then, my DRL's will only come on now with my headlights? I'm hoping I can go in and change the settings to make it normal again. Unlike most I like the DRL's so I just want them to work properly.
I had this exact same problem - managed to short the module out while replacing the door lights in my BRZ (don't ask) - the replacement had the same problem - the dealership had to do something with settings from my old module to the new to get my DRLs working correctly again.
mikalem is offline   Reply With Quote
Old 04-24-2013, 09:48 AM   #26
Yruyur
Yruyur's Avatar
Its if you unlock the car but don't open anything.
Old 04-24-2013, 11:53 AM   #27
Wonderbar
Driveway labs.
Wonderbar's Avatar
Drives: '13 BRZ Limited, 6sp, SWP
Will tech stream work with a tactrix 2.0?
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list)
-'13 Town and Country Limited (Mods: too many kids)
Wonderbar is offline   Reply With Quote
Old 04-24-2013, 12:02 PM   #28
xxscaxx
Drives: 2013 SWP BRZ
Exactly what happened to me. You wouldn't happen to know what settings they had to change do you? I'm assuming it was something in Techstream...which is why I bought the cable. I really don't want to have to bring it back to the dealership.
xxscaxx is offline   Reply With Quote
Toyota Techstream xjohnx Engine, Exhaust, Transmission 206 08-20-2023 04:01 PM
TechStream TIS - No work FRSFirestorm Engine, Exhaust, Transmission 19 07-10-2014 03:14 AM
Techstream/ECU customizations phanguy Northern California 60 10-05-2013 11:12 PM
Techstream ECU Options mrjester Electronics | Audio | NAV | Infotainment 10 03-18-2013 10:24 AM
86 TRD Customize Concept JDMrolla Scion FR-S / Toyota 86 GT86 General Forum 6 01-11-2013 12:31 PM
