#295 |
Drives: '13 WRB BRZ
I'm curious as to what a "normal" timing advance should be like. I've been trying to collect data of different types of gas around my area for the best bang. While at WOT my timing advance goes down to about 10 or so. But for some reason torque says the lowest it's ever gotten is -11.0.
Anyone know what the deal is with timing advance in this car? Also anyone noticing lean conditions when your foot is OFF the accelator after an acceleration? I notice my AFR goes to like 20 for a bit, or until I put the foot on the gas again. (it always stats between 13-14.5 every other time) |
#296 | |||||
Drives: car
Basically, when tuning for cold start emissions you want to retard ignition as much as you can without causing misfire. Quote:
#297 | |
I don't completely understand the timing on this car either.. I've wondered myself why the timing DROPS under harder acceleration.. I'm assuming it's for safety reasons, since there's more potential for knock under hard acceleration than when you're just cruising on light throttle. |
#298 | |
#300 |
Drives: car
The main spark and target AFR maps have already been posted before...
target AFR: |
#301 |
Yep, I've seen some huge variances in intake air temp. When I'm on the hwy I normally see temps in the 70's to 90's range. In city driving I've seen the temp spike as high as 140's, but that was in Socal with the ambient temps in the high 80's. I'm not sure if I want to see what these temps will look like during the HOT summers here.
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam. |
#302 | |
Drives: UK GT86
.: Stealth 86 :.
#303 |
Drives: '13 WRB BRZ
Wow. The thing runs pretty rich at higher rpm and load. I guess I'm going to have to get a tune.
#304 | |
Drives: '13 WRB BRZ
#305 | |
Drives: UK GT86
Think about it, combustion = power which you don't need off throttle.
.: Stealth 86 :.
#306 |
Drives: '13 WRB BRZ
I hear ya, but even at idle there is combustion. Off throttle, say going down hill pretty sure there is still spark and measurable amounts of exhaust
#307 |
Drives: car
There's a difference between idle and deceleration fuel cut. Fuel cut is also called an overrun condition.
The spark and fuel turn off, often in stages. Half the cylinders may cut fuel and then all of them. The crank and cam signals are used to judge how to reactivate combustion. |
#308 |
I do notice.. when 'coasting' to a stop, if you put the car in NEUTRAL, the AFR remains around ~14. But if you keep the car in gear, the AFR goes up to 20+.. Does that mean you get BETTER MPG's if you keep the car in gear when approaching a stoplight, rather than putting it into neutral?
| Tags |
| android, app, boost, gauges, torque |
| Torque app for android question | Brody602 | Electronics | Audio | NAV | Infotainment | 8 | 01-08-2015 04:53 PM |
| Torque for Android | Freeman | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 11-22-2012 11:05 PM |
| Android Torque app questions | Craig | Engine, Exhaust, Transmission | 1 | 11-12-2012 04:14 PM |
| Bluetooth OBD scanner and Android Torque - less than 25 shipped | whataboutbob | Engine, Exhaust, Transmission | 7 | 10-20-2012 01:15 PM |
| Android Tablet + torque | CharlieChaos | Electronics | Audio | NAV | Infotainment | 3 | 10-04-2012 08:23 PM |
