Old 10-26-2012, 06:57 PM   #253
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
The suspension shop I used never bashed anything when they aligned my car. Get your money back
mechaghost is offline   Reply With Quote
Old 12-19-2012, 12:24 PM   #254
WolfSongX
WolfSongX's Avatar
Drives: 2013 Subaru BRZ Limited SWP
Pheadrus29: From what I remember, wheel/strut clearance should remain a static value unless you lose the bearings in the hub or something else catastrophic causes distortion. So if you have clearance between the strut and wheel it doesn't change. This does not mean that you have clearance with regard to the wheel well, so you still need to verify that aspect, which is dynamic.
I agree with everyone, if that shop didn't clear those modifications with you prior to install, they should be offering your money back. Back when I owned my shop, I would've fired someone if they'd tried to sneak a hack job like that out on a customer's car, and would've offered a refund and made it right.
Derek
2013 BRZ Limited SWP
Professional driver in search of closed course..
WolfSongX is offline   Reply With Quote
Old 12-19-2012, 02:25 PM   #255
Phaedrus29
Phaedrus29's Avatar
Thanks. I see how the wheel/strut clearance is basically static, but with the RCE lite pack I'm adjusting camber up front with the crash bolts. On one side, if the crash bolt slips the wheel can hit against the strut. So it is really just a question of how secure those crash bolts are. I'd prefer to put the fixed strut bolts back in for clearance and stability, and adjust camber in some other way. But I don't really see a good option that would allow me to use the RCE Yellows, fixed bolts, and wouldn't increase ride height.
Phaedrus29 is offline   Reply With Quote
Old 04-22-2013, 11:58 AM   #256
mad_sb
Drives: 2013 Asphalt FR-S
whiteline comp-c top hats will increase camber if i am not mistaken
Old 04-24-2013, 02:06 AM   #257
Phaedrus29
Phaedrus29's Avatar
Yes those top hats do increase camber but don't allow adjustment.
Old 05-16-2013, 12:28 AM   #258
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Just did the Rce / koni yellow install with the com-c's. had to take them off tonight was having some popping if you will. The bearings in the com-c's are notchy to the touch and rough. I have the new sets not sure what the issue is.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 08-14-2013, 07:59 PM   #259
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Originally Posted by elopez View Post
after reading this entire thread, think i'll stick to an uncomplicated eibach spring installation...
Installing Eibach springs is the exact same procedure. What exactly do you find so complicated about installing RCE Yellows? The OP's shop installed the bump stops and dust boots incorrectly, but if the included installation instructions are followed then there are no "complications".
All of the other issues mentioned in this thread have been directly related to the Whiteline Com-C top mounts and Whiteline rear camber bushings and have nothing to do with the springs.
The Following 5 Users Say Thank You to ATL BRZ For This Useful Post:
autobrz (08-15-2013), console_cowboy (08-14-2013), lazyluka (08-15-2013), OICU812 (08-14-2013), Racecomp Engineering (08-14-2013)
Old 08-18-2013, 03:11 PM   #260
What are you talking about?
- Andy
Old 08-18-2013, 04:40 PM   #261
KKaWing
KKaWing's Avatar
Drives: Nissan Versa
I think elopez misunderstood the install shop's blunder with the whiteline bushes for RCE installing Yellows on a customer's car... I don't know how but that's what it feels like.
KKaWing is offline   Reply With Quote
Old 08-18-2013, 06:17 PM   #262
Yup, I remember that. We worked through that a long time ago and we don't sell the whiteline com c top mounts thanks to mecha's feedback and others. It took us a little to get all the details to get there since whiteline usually is all quality.
Let me know if you have any questions about the springs.
- andy
Old 02-07-2014, 04:21 PM   #263
Just to be clear here.....
The RCE Yellow springs are easy to install and DO NOT make noise.
Period. Installed correctly (like any other spring) they are SILENT.
The Whiteline COM-C top mounts do make noise. We do not sell them anymore based on the feedback in this thread and others. We do not recommend them.
The Whiteline rear camber adjustment bushings should be installed by a professional shop that knows what they are doing! It is not a straightforward install....for an easier rear camber solution get lower control arms.
Short version: RCE Yellow springs good. ComC mounts noisy. WL rear camber bushings pain in the ass to install.
- Andy
fstlane (02-07-2014)
Old 02-07-2014, 04:47 PM   #264
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Wow..I'd be irked to no end if they did that ghetto'ness on my car.
Post that pic on their Yelp and give them a bad review - make em pay and warn others to not go there.
fooddude is offline   Reply With Quote
Old 02-07-2014, 06:38 PM   #265
jprice130
AutoX Nut
Drives: 2020 Toyota Supra
Would a few of you RCE Yellow users mind providing me with a measurement from the ground to the edge of your fender wells? I know the ideal measurement is from center of hub to the fender, but I'm just looking for a rough measurement and could not find this information with the forum's search feature or Google.
I also know that the advertised drop is 20mm, but if you wouldn't mind humoring me and giving me a few measurements for the front and back fenders, I'd appreciate it. It would be preferable if you were using tires with stock diameter (215/45/17 or 245/40/17). Thanks!
jprice130 is offline   Reply With Quote
Old 02-07-2014, 09:12 PM   #266
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
But I think a more accurate way to measure would be from center of wheel to fender
Fizz is offline   Reply With Quote
White n' Yellow. Asterisked Accolade Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 33 08-02-2015 05:01 AM
Yellow fog tint looks awesome! DookDookDGM BRZ Photos, Videos, Wallpapers, Gallery Forum 37 11-07-2012 04:40 AM
RCE YELLOW Performance Lowering springs intro buy! RCE Suspension Starter Pack! Racecomp Engineering Brakes, Suspension, Chassis 141 10-07-2012 09:12 PM
Amber Turn signals to yellow? deedz Cosmetic Modification (Interior/Exterior/Lighting) 1 08-01-2012 03:44 AM
FT86s at Megaweb (more footage of the yellow 86) ESBjiujitsu FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 16 05-26-2012 03:08 PM
