Old 04-20-2013, 10:45 PM   #85
Synack
Boosted
Synack's Avatar
Drives: Sideways
I was not aware of anyone running a motor with lower compression pistons yet. I think there was a guy in Texas with an Accelerated kit that was putting pistons in, but I haven't seen him post recently. Full Blown is waiting to blow theirs up to install pistons. I have definitely considered just swapping in lower compression pistsons and rods to get some more power.
Talking about me? I have a D3 Performance kit. I just moved from Houston to Atlanta though.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline
The Following User Says Thank You to Synack For This Useful Post:
Carlysh (08-17-2013)
Old 04-21-2013, 01:26 PM   #86
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Nope. Talking about the guy that posted a few posts ago.
King Tut is offline
Old 04-21-2013, 10:45 PM   #87
Blue86
Drives: Sonic Blue 86GT Manual
"my son is also named Bort"
Blue86 is offline
Old 04-22-2013, 08:50 AM   #88
bakerr6
Drives: 2013 raven black fr-s
Originally Posted by cf6mech View Post
Dons kit is advertised as retaining stock cat for emissions,...when he went to higher hp numbers he doesn't state if it is still retained......guess we found out otherwise.....but yah it went south. No biggie, time for upgrades without it. Still working out bugs and breaking new ground,....kind of why I keep to myself on build.....the wise cracks from others un-boosted......once you reach close to 400whp this car is a little unsettling unless your going in a straight line or a drifter, not my cup of tea....working on that solution now.....later!
Hey cf6mech, I'd still like to find out a little mroe about your build. I know you've kept it quiet for obvious reasons, but I've been watching the little info. you've put out here and there.
bakerr6 is offline
Old 04-23-2013, 11:33 PM   #89
Frs300
Frs300's Avatar
Drives: Pile of junk
@FA20Club.com any updates?
Frs300 is offline
Old 04-23-2013, 11:37 PM   #90
FA20Club.com
Drives: 2013 White Out FR-S
more pics tomorrow for you
FA20Club.com is offline
Old 04-24-2013, 01:39 PM   #91
Frs300
Frs300's Avatar
cant wait!!!!
Frs300 is offline
Old 04-24-2013, 01:42 PM   #92
SkullWorks
Drives: SSM LT MT BRZ
Engines fine,...the cat that is retained in Accelerated Performance kit crapped itself into the turbine wheel destroying tolerances/the turbo,....upgrading to a Garrett GTX-R turbo minus the cat now,.....and yes besides Crawford and the Robert Stout race team car, mine is the only forged FA20 that I know of. 18 psi boost. Latest upgrade was Drive Shaft Shop axles that are rated up to 500hp.
That is unfortunate, I mentioned this to Don on the day he debuted the setup and he said I was uninformed and that that was very common, even tried to tell me OEM's did it all the time...Im sorry someone else had to learn that lesson for him.
SkullWorks is offline
The Following User Says Thank You to SkullWorks For This Useful Post:
cf6mech (04-25-2013)
Old 04-24-2013, 02:22 PM   #93
sw20kosh
Drives: 2013 Black FR-S
Looks like I will not be having any cat in between the motor and the turbo...
sw20kosh is offline
Old 04-24-2013, 03:51 PM   #94
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I don't think the cat just spontaneously broke up on its own. Likely it was impacted by pieces of the engine. So whether it was pieces of the cat or pieces of the engine, that turbo was doomed regardless.
Draco-REX is offline
The Following User Says Thank You to Draco-REX For This Useful Post:
Coheed (04-24-2013)
Old 04-24-2013, 04:05 PM   #95
FRSPirate
FRSPirate's Avatar
Drives: 13 Scion FRS Raven M/T, 05 Raven R6
^This
-Alex
05 Raven R6
13 Raven FRS M/T
FRSPirate is offline
Old 04-24-2013, 04:10 PM   #96
buditjoenawan
Drives: Very very slowly
Not to derail the original thread too much, but I just had to chime in regarding catalytic converters before the turbocharger. It is a TERRIBLE idea. So terrible, in fact, that Subaru STOPPED doing that after the 2003 WRX. @cf6mech's motor is fine, but his turbocharger is destroyed due to debris from the catalytic converter. At least that's how I understood the situation.
That said, please think twice about putting a turbocharger right after the stock header. ESPECIALLY that cat which isn't rated to withstand the kinds of heat a turbocharged setup produces.
Budi
buditjoenawan is offline
Old 04-24-2013, 06:41 PM   #97
Draco-REX
Corner Junkie
Draco-REX's Avatar
Budi
Ok, I was confused. I thought it was FRS300 that lost the aforementioned turbo (I still expect he did).
The up-pipe cat in the WRX wasn't really an issue. Lots of people were worried about it, but I don't recall any actually coming apart. The cat Subaru used was designed with a metal structure that didn't break apart. Check out any thread about gutting the up-pipe and it's pretty clear that unlike conventional cats which can be fractured and removed, it has to be dug out.
Subaru stopped using them when they went to the 2.5L. Despite the larger displacement, they were able to reduce emissions such that they could remove that cat and gain a little power. The 2.5L WRXs were underrated.
Old 04-24-2013, 06:44 PM   #98
Frs300
Frs300's Avatar
I hope not
If i did im driving it back without a turbo. but i havent heard if the turbo was good or bad yet.
Frs300 is offline
#car in litigation?, #ferris bueller ferrari?, 12 year build, 5 month engine build, are we there yet?, edging, fantasy, innovate thread pt.2, its happening!!!!, keep calm and carry on, maybe tomorrow?, not today, not viscontiqued ftw, the neverending build, unicorn!, vaporware
Full Blown Stage 1 Short Block FullBlown Forced Induction 116 03-22-2019 07:29 PM
Full Blown 521hp Stock Motor @ 20psi FullBlown Forced Induction 276 08-31-2016 02:05 AM
How often to rebuild coilovers or stock shocks? stockysnail Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 12-24-2012 12:54 PM
2013 FR-S / BRZ (The R&D has Begun) Cotnoir CANADA 10 06-26-2012 03:08 PM
PM Spammers, it's begun! Beast Off-Topic Lounge [WARNING: NO POLITICS] 11 01-30-2010 01:13 PM
