Old 04-20-2013, 07:45 PM   #183
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
Originally Posted by oso_25 View Post
When we did a dyno with the mustang dyno we got a avg 162 to 166 whp on stock cars so if it does 173 to 178 whp with the trd exhaust and intake then that's a nice gain.
This was on Dynojet.
husker741 is offline   Reply With Quote
Old 04-20-2013, 07:49 PM   #184
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Not bad, eh?
Old 04-20-2013, 07:56 PM   #185
Boosted
Boosted's Avatar
Drives: 13 brz, 06 STI
We also had a tuned FRS with over pipe, drop in filter and ARP cat back. He put down 180 who and 148tq. Another tuned FRS with just a Perrin cat back only made 173 whip and 144 tq, though they said they still had some work to do on his tune.
-Alex
2013 BRZ Limited build: http://www.ft86club.com/forums/showt...d=1#post586737
2006 STI- lots of go fast goodies 551whp/491 Tq on 93(weekend car)
1988 CRX si- b16A1 (Sold)
RIP 2003 WRX
Boosted is offline   Reply With Quote
The Following User Says Thank You to Boosted For This Useful Post:
tripjammer (04-20-2013)
Old 04-20-2013, 08:01 PM   #186
OrbitalEllipses
Drives: Attitude
My baseline on a dynojet on a cold fall night was around 172-175 cold to hot. It appears we dont have a baseline for the above car so while that dyno is informative it's also useless.
The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post:
blu_ (05-18-2013), CircuitJerk (04-20-2013)
Old 04-20-2013, 08:46 PM   #187
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Tragic seeing as this intake is probably a 5 minute swap between the stock box.
industrial is offline   Reply With Quote
The Following User Says Thank You to industrial For This Useful Post:
blu_ (05-18-2013)
Old 04-20-2013, 09:01 PM   #188
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
-Alex
I don't have a Perrin catback! I just have the Perrin tips. I am completely stock except for the tune and a aEf dry drop in filter. And its a BRZ, but it's all good bro!
tripjammer is offline   Reply With Quote
The Following User Says Thank You to tripjammer For This Useful Post:
Boosted (04-20-2013)
Old 04-20-2013, 09:08 PM   #189
acro
Drives: GT-86
So close but so far . Awaiting baseline comparisons vs TRD dyno
acro is offline   Reply With Quote
Old 04-20-2013, 09:10 PM   #190
tripjammer
tripjammer's Avatar
Originally Posted by yayforaddison View Post
If I'm not mistaken, the baseline dyno is 173.
If 5hp is all you're expecting, stick to a drop in. The results of a drop in filter are about 4whp, and at least 8 times less expensive.
I am not sure about that.
I got a aEf dry filter drop in, and a 93 octane ecutek tune and all i got was 174hp and 142 ft lbs torque. Sure dynotronics has not dialed in the car completely yet, so its going to go up, but if this FR-S with the TRD intake and exhaust got close to 179 HP completely on a stock tune. That is awesome!
Old 04-21-2013, 04:50 AM   #191
Mars2
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
Useless without baseline let's wait somebody does OEM vs TRD
Mars2 is offline   Reply With Quote
Old 04-21-2013, 06:38 AM   #192
Nardi330
Nardi330's Avatar
Drives: 86
Quick question about this intake. Is the air filter washable and reusable?
Thx
Nardi330 is offline   Reply With Quote
Old 04-21-2013, 07:24 AM   #193
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by switchlanez View Post
Just wondering, do SS brakelines reduce chances of brake fluid from splattering? Meaning, when I took a drive through the twisties a few hours, by the end of it I noticed traces of brake fluid on my wheels and along my doors. Same happened on other cars I've driven spiritedly but not under normal everyday driving. Or is that unavoidable?
i would guess its whatever tire shine you are using rather than tar since you said it has happend on other cars you have driven spiritedly
The Following User Says Thank You to mad_sb For This Useful Post:
switchlanez (04-21-2013)
Old 04-21-2013, 07:41 AM   #194
TEWwild
TEWwild's Avatar
Drives: 2015 Ultramarine FR-S MT
Thx
Yes
TEWwild is offline   Reply With Quote
The Following 3 Users Say Thank You to TEWwild For This Useful Post:
cslntuee (05-13-2013), Nardi330 (04-21-2013), tripjammer (04-21-2013)
Old 04-21-2013, 08:41 PM   #195
Thorpedo
The SquadWhisperer
TRD intake review WITH DYNO RESULTS.
So I finally got the FR-S on the Dyno.
This was my procedure.
-Unhook neg terminal
-Wait 5 minutes or so
-Hook neg cable back up, run car for 5-10 minutes.
-Do 3 dyno runs.
-Install TRD intake
-Hook neg cable back up, run for 5-10 minutes
-Do 3 more runs
This way I believe to be the best, as it makes it so I am comparing apples to apples. My car has around 3500km on it, and it has the TRD exhaust as well.
First 3 runs are as follows:
1. 162.9hp - 133.52tq
2. 166.05hp - 136.51tq
3. 167.95hp - 136.73tq
After the TRD intake was installed (within an hour, so similar temp etc)
1. 174.39hp - 143.59tq
2. 175.6hp - 144.2tq
3. 170.02hp - 141.16tq - Something was up on this last run as I felt the car shift a bit on the dyno. I was satisfied with the figures so we just took it off.
Shitty pic of the graph, but as you can (kind of) see, it was a pretty even increase throughout the rev range with a decent peak at 4500.
(Will be posting pic, vid of gauges shortly)
The Red box is around the runs done with the TRD intake.
I see he his banned, but in closing I'd like to send out a big GFY to FR-S Matt!
Thorpedo is offline   Reply With Quote
The Following 53 Users Say Thank You to Thorpedo For This Useful Post:
86 FRS (04-21-2013), 86drift (08-15-2013), 86GT (04-21-2013), AZOOZ_95 (04-22-2013), bdub85 (04-22-2013), bedabi (06-08-2013), blu_ (05-18-2013), bobpuffer (04-22-2013), Bonburner (04-21-2013), Cadenz (04-22-2013), CamryDS (04-22-2013), ChristosG (04-21-2013), CrazyWookiee (04-22-2013), Dang Lad (05-25-2013), dun3 (04-21-2013), Enraged21 (04-22-2013), evox2frs (04-21-2013), finch1750 (04-21-2013), forwallblakmail (04-21-2013), Freeman (04-21-2013), GoSharks (04-22-2013), Hanakuso (04-21-2013), Jeff86 (04-22-2013), Jesse (04-29-2013), JETRED (04-22-2013), lazyluka (06-18-2013), LeeMaster (04-21-2013), mgarcia707 (04-04-2019), Mikem53 (04-22-2013), Mikepage (04-22-2013), mit_peid (05-15-2013), Mr.Zoolittle (06-26-2013), Nambo (04-22-2013), Ninjin (04-22-2013), normancw (04-21-2013), OnkelC (04-22-2013), Paewrblue (02-26-2015), r4m3n (04-21-2013), rasec29 (04-21-2013), RazBRZ (04-21-2013), Sargy (04-21-2013), shawnperolis (04-21-2013), shu5892001 (04-22-2013), Sigh-on-Rice (04-22-2013), Sugi (05-02-2015), switchlanez (04-21-2013), TEWwild (04-21-2013), The Tengu (08-16-2013), tmcmullins (04-28-2013), torqdork (04-22-2013), tripjammer (04-22-2013), Valentino (06-19-2015), Verge (04-21-2013)
Old 04-21-2013, 08:46 PM   #196
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
Nice numbers, thanks for the info!
o= FR-S =o
Mikepage is offline   Reply With Quote
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 12:43 AM
So cold air intake or air intake? bcmakesiteasy Engine, Exhaust, Transmission 12 02-01-2014 08:06 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 01:31 PM
