Old 12-02-2011, 10:47 AM   #15
ryude
Drives: Volkswagen GTI
If it's a supercharger, I would hope it would be a roots type.
I'm hoping it's twinscrew.
ryude is offline   Reply With Quote
Old 12-02-2011, 11:01 AM   #16
mele63
mele63's Avatar
Drives: 05 LegacyGT
I'd love to see a factory-backed bolt-on supercharger package from TRD or SPT but I am skeptical due to the 12.5:1 compression ratio....meaning we may have to wait a few years for special model to come out.
mele63 is offline   Reply With Quote
Old 12-02-2011, 11:02 AM   #17
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
I think his point was anything positive displacement. Twinscrew ~~ TVS >> classic Roots, of course. A centrifugal would be less desirable since boost is RPM proportional.
Since we're talking TRD here, roots is most likely, yes?
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 12-02-2011, 11:04 AM   #18
ryude
I've never seen TRD use anything except roots.
Old 12-02-2011, 11:35 AM   #19
Sabastian
will rain on your parade.
Drives: 2007 Mini Cooper, 1996 Mazda MX-5
If they do a supercharged version, I hope it ends up being an actual factory model with bigger brakes, more aggressive suspension tuning, etc. I think I would much prefer that to an aftermarket bolt-on.
Sabastian is offline   Reply With Quote
Old 12-02-2011, 11:36 AM   #20
cassidy0998
cassidy0998's Avatar
Drives: '99 Ranger / '94 APU Supra / Ninja!
definitely going to be roots if it's true. Toyota has offered them on many of their vehicles for years.
This would make sense - I've heard of people asking Toyota if there was going to be a turbocharged version of this car - their replies of "absolutely not" make more sense now.
I hope I'm not getting my hopes up for nothing though...
cassidy0998 is offline   Reply With Quote
Old 12-02-2011, 11:37 AM   #21
Motordyne
Motordyne
Motordyne's Avatar
Drives: Nissan Z & Infiniti G
It will be.
Notice the article said it will greatly increase low end power.
TRD is already doing a lot of work with belt driven Eaton based superchargers.
Motordyne is offline   Reply With Quote
Old 12-02-2011, 11:55 AM   #22
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
Twin scroll turbo set up would be what I want as it provides a flat torque curve and instant response...
mokinbird87 is offline   Reply With Quote
Old 12-02-2011, 12:12 PM   #23
Infernal
NO FI?! (╯°□°)╯︵ ┻━┻
Infernal's Avatar
Drives: BMW e92 330D
has anyone ever heard of someone supercharging a boxer/flat4 ?
Infernal is offline   Reply With Quote
Old 12-02-2011, 12:24 PM   #24
ryude
Originally Posted by Motordyne View Post
It will be.
Roots is a pump, it draws the air through the inlet, the air heats up against the casing causing heat\turbulence. Cheap to build, easy to tune, and tends to be more efficient at lower boost levels.
Twin Screw is a compressor, it draws the air through the inlet and compresses the air within the screws. Less heat\turbulence, more expensive, better at higher boost levels.
Twin screw has less parasitic loss compared to a Roots, but you're talking 5-10 HP in our power range.
OEM's use roots style because they are reliable and cheap.
TS are used in lots of after market and racing applications.
Old 12-02-2011, 12:44 PM   #25
Levi
Drives: Toyota
WOW, TURBO and INSTANT RESPONSE in the same sentence. Tell me of any turbo engine that has throttle response as a naturally aspirated engine?
The best turboed cars - 911 Turbo, 1 Series M, M5 F10, MP4-12C - all have turbo lag and cannot match the responsivnes of 911 GT3, M3 E9X, LF-A, Ferrari.
A supercharger can be a better solution if you want more power without losing throttle response. Audi S4 with Supercharged V6 is a better car than BMW 335i with Turbocharged I6. However Audi handling sucks.
Levi is offline   Reply With Quote
Old 12-02-2011, 12:59 PM   #26
youngxlos
Drives: 2000 Toyota Celica GT-S
Everyone always talks about turbo lag... from my experience there is barely any lag, and its only noticeable wen I'm in like 6 gear in the highway and i put my foot down, takes about 1 second to hit boost then the car is off.
So unless your using a massive GT35R you'll barely notice lag, I have a GT2860RS and when i put my foot down the car goes, there is no lag, and I'm using 9.0:1 CR
Supercharging to me is stupid, it takes power to make power, turbos dont.
we can sit here and argue about it all day, its all personal preference if they make a factory supercharged good for them, ill still rather turbo mine.
youngxlos is offline   Reply With Quote
Old 12-02-2011, 01:23 PM   #27
Jah1mon
Jah1mon's Avatar
Drives: s13 240sx
I couldn't agree more. Elimnating lag, or making it less noticeable takes the right compression ratio and proper turbo sizing. Both of which Subaru can match. I do hope they go this route with a Sti model.
Jah1mon is offline   Reply With Quote
Old 12-02-2011, 02:00 PM   #28
ryude
All turbocharged cars have lag, whether you perceive it or not is not the argument.
Turbo FR-S Mino Engine, Exhaust, Transmission 24 12-16-2011 09:42 AM
The Turbo Conundrum Chocoholic005 BRZ First-Gen (2012+) — General Topics 82 11-22-2011 04:20 PM
Turbo or Suppercharger or none xc Engine, Exhaust, Transmission 12 11-17-2011 06:40 PM
From MKIV Turbo to FR-S Crashoverride Scion FR-S / Toyota 86 GT86 General Forum 62 11-11-2011 02:32 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 07:20 PM
