Old 04-19-2013, 12:36 AM   #1
Xdragonxb0i
Drives: ex500r
question for guys with headers
How did your car feel after you installed it with a ecu reset? Mines feel sluggish, i definitely need a tune. Do you guys think you need a tune after your header install?
Xdragonxb0i is offline   Reply With Quote
Old 04-19-2013, 12:45 AM   #2
sierra
Drives: Skoda Yeti DSG diesel 4x4
It always feels sluggish with a lousy throttle response after a reset.
It's self learning and I wonder if it might be better to leave it alone?
sierra is offline   Reply With Quote
Old 04-19-2013, 12:48 AM   #3
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
I will talk about my brief spin in @Concept 3 LED FRS, but that torque dip is all but gone, just barely noticeable.. And honestly felt like a whole new car, with a whole new sound.. It just pulls so much harder.. But I tagged him so he could give his impression
Gixxersixxerman is offline   Reply With Quote
Old 04-19-2013, 12:49 AM   #4
mashal
DADA
mashal's Avatar
Drives: 2013
How long has it been since you did your headers?
After I installed my CAI , I reset the ECU and it was "sluggish" for about 5-10 minutes .. Haven't had it happen after that
mashal is offline   Reply With Quote
The Following User Says Thank You to mashal For This Useful Post:
Ruckus (04-20-2013)
Old 04-19-2013, 12:52 AM   #5
Xdragonxb0i
Drives: ex500r
finally installed it today. Drove it for about 5 miles with the reset ecu, i am just asking for your opinion. I am sure the ecu will adjust to it soon.
Old 04-19-2013, 08:12 AM   #6
Dynotronics1
Trust me, you need a recalibration with the header. We have seen several cases where the header/cai combo are causing a over lean bog due to over scavenging. Tuning is cheap, why chance it ?
Dynotronics1 is offline   Reply With Quote
Old 04-19-2013, 10:36 AM   #7
Opposed
Drives: 2013 Asphalt FR-S
What kind of header are we talking about?
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 04-19-2013, 11:39 AM   #8
Xdragonxb0i
Drives: ex500r
P&L headers.
@dynoyronics. I was hoping I could run my car without a tune for a few months to save up. Right now. My car isn't enjoyable
Old 04-19-2013, 11:55 AM   #9
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
The pedal delay goes away after ~100 miles.
Old 04-19-2013, 12:06 PM   #10
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Depends on which header you get. PPE Header has an angle extension for 2nd O2 sensor so it can run fine on stock tune. Improved with Visconti tune.
JDKane527 is offline   Reply With Quote
Old 04-19-2013, 05:06 PM   #11
reeves
P&L headers.
I got the EL headers from FA20club.. they're pretty similar. You'll definitely need a tune. I wouldn't have even thought about getting the CAI & headers if I couldn't tune it that same week. Like @Dynotronics1 said, you don't want to risK running too lean.. that goes with any mods, but header are much more drastic a change IMO than other bolt-ons, in terms of power gains and potential AFR fluctuations.
To be honest, you may actually lose a bit of torque down low just from the loss of backpressure in the exhaust system by putting on headers.. A tune will definitely help compensate, but I actually don't feel too much of an improvement (if any) below 3K rpms.. which is OK actually, since I gained so much more pull above 3K.
Old 04-19-2013, 05:11 PM   #12
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Our Firestorm car has been running without a tune for several hundred miles and an open track day with no issues. I sure wasn't easy on the car for the track day either Mods include AEM intake, HKS EL header, Perrin over-pipe, Invidia catted front-pipe, and T1R cat-back.
I will be interested to see the logs on the stock tune. We have tunes waiting for it, but just have not had the time for it. Also, kind of want to see what kind of numbers we are putting down with the stock flash.
Just my .02, I suppose.
Cheers!
-Yo
FT-86 SpeedFactory is offline   Reply With Quote
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
Skywgn1 (04-19-2013)
Old 04-19-2013, 05:14 PM   #13
reeves
Totally agree! In fact, I'm inclined to say the DIP is now "upside down".
Old 04-19-2013, 05:23 PM   #14
mad_sb
yup, the cam timing for sure needs to be changed around the dip rpm range.. and with that fuel and timing as well, and while your at it you may as well tweak the rest of the rpm range to account for the reduced back pressure and improved flow as well.....
or you could just rock the stock tune and not make more than a few hp with your new header i suppose
Question for Subaru veteran repair and ecu guys:radiator fans Huehuecoyotl Engine, Exhaust, Transmission 11 04-14-2014 06:19 AM
Question for you guys!? mbh1101 Electronics | Audio | NAV | Infotainment 5 03-22-2013 03:48 PM
Question for the guys with the cusco spin knob "drift" knob Juurian Cosmetic Modification (Interior/Exterior/Lighting) 5 03-13-2013 08:51 PM
Question for the Phoenix area guys Pscylo Southwest 11 09-11-2012 12:28 PM
What you guys do with stock headers and exhaust after swap? WatchmaN Engine Swaps 6 08-09-2012 06:26 PM
