Old 04-18-2013, 02:40 PM   #1
MrMista
Drives: 2013 BRZ, Satin White Pearl, MT
Lower the seats?
Hi guys,
I am 6' 6'' and took a test drive in the FRS. I was surprised by how well I fit, with the seat all the way back, the pedals were not too close and I had about 1 inch clearance with the roof. This is about as good as it gets, and am really happy with it!
The issue that I can see is that when I get the car, I plan on tracking it. To go to the track I will need to wear a helmet and with that I would be too tall and would hit the roof. Do you taller guys have any tips on how to fit in the car with a helmet? I could sit a little less upright while driving on the track but that isn't optimal. Has anyone removed the headliner or replaced it with something not as thick? How much space did you gain by doing that? Would it be easy to remove for track days and then put back?
MrMista is offline   Reply With Quote
Old 04-18-2013, 02:47 PM   #2
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Might want to consider going with an aftermarket seat eventually (especially if you plan on dedicating a serious amount of time doing this), if it's non-adjustable you could likely get it sitting a couple inches lower (with less padding of course).
But my money is that the first few times you'll have to drive in the "lean back" position...
No opinion on the head liner but removing and re-installing will shorten the life of it, they don't ever fit quite the same after the first time apart and it will likely begin to fall apart if you do it regularly but it might net you an extra half an inch.
ineedyourdiddly
Old 04-18-2013, 02:53 PM   #3
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
I used to have a helmet with a hose vent on the top, which would scratch up the headliner so I ended up getting a helmet without one. It fits, but it does touch the top when I sit up completely straight.
Also, you may not have noticed this on the test drive, but the drivers seat has an up/down adjustment so you can raise/lower it.
campy is offline   Reply With Quote
Old 04-18-2013, 02:58 PM   #4
fatoni
a "foamectomy" would probably be the cheapest option. you might want to eventually want to look into an aftermarket seat but for a more elegant solution
The Following User Says Thank You to fatoni For This Useful Post:
n2oinferno (04-18-2013)
Old 04-18-2013, 03:00 PM   #5
MrMista
Thanks for the input. I think that the best option probably is to just get the right helmet and deal with leaning back and later think about getting an aftermarket seat.
Yea, I saw those up/down adjustments. I have the seat all the way down.
Some seats have spacers that can be removed to lower the stock seats. Does the FRS (or BRZ) have anything similar?
Old 04-18-2013, 03:18 PM   #6
MrMista
http://www.frsport.com/Nagisa-Auto-S...e_p_37474.html
Something like that could be a good option. Maybe there is one that gives an inch or two?
Old 04-18-2013, 03:58 PM   #7
wootwoot
Drives: FRS
Someone is working on a lowering bracket for the stock seats. I couldn't find the thread. Do a search and bump the thread for updates. They should have some news by now.
Old 04-18-2013, 04:28 PM   #8
MrMista
Found the thread you were referring to. Sounds interesting, I hope it happens!
http://www.ft86club.com/forums/showt...wering+bracket
Old 04-18-2013, 04:43 PM   #9
donutfilling
donutfilling's Avatar
Drives: frs
Just incase you missed it but did you adjust the stock seat to its lowest position? and if you don't want aftermarket fits maybe you could get someone to make you custom brackets?
donutfilling is offline   Reply With Quote
Old 04-18-2013, 05:18 PM   #10
Reason
Reason's Avatar
Drives: Whiteout 6MT FR-S; E30 BMW's
So glad I found this thread. 6'7, 300 lbs, its impossible to use helmet. It's been breaking my heart to stay home during track days simply because I can't physically fit with a helmet.
Even daily driving, it's comfortable enough but I too am looking at my sun visor and have to duck to see lights when I'm the first car haha.
I will definitely buy a set of the DA Motorsports brackets when they offer them and will post a review with some before/after measurements.
Reason is offline   Reply With Quote
Old 04-19-2013, 12:51 AM   #11
MrMista
I'm hoping that those brackets end up making the seat low enough to fit with a helmet. Even still, its very impressive how much I do fit in such a tiny looking car.
Also in terms of seeing lights I've heard good things about this product: http://lightinsight.com/ I haven't used it myself though. Right now they are out of stock.
Old 04-19-2013, 07:41 PM   #12
strat61caster
Originally Posted by jaynutter2 View Post
Why not wait until the convertible comes out? You will have all the headroom you need, plus because racecar.
Not everybody likes convertibles.
Coupes are structurally stiffer and as such will inevitably be better racecars than convertibles, not to mention that there are aerodynamic benefits to a true hard top over an open space which generates a negative pressure zone that adds drag, or cloth which isn't as slippery as painted metal.
But definitely valid for the average Joe interested in a couple track days a year for fun.
ineedyourdiddly
Lumbar support for seats? My lower back is killing me Indestruct Cosmetic Modification (Interior/Exterior/Lighting) 65 05-18-2017 11:56 AM
FRS/BRZ Rear Lower Valance!!!!! jazztennor Groupbuys 24 03-20-2013 07:54 PM
WTT: My FRS seats for your BRZ Premium Seats Hanakuso Interior Parts (Incl. Lighting) 17 03-04-2013 01:37 PM
HOW to lower BC Coils whitefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 10-24-2012 07:09 PM
Lower car 1.5 - 2.0 inches F3dzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 06-23-2012 09:30 PM
