Old 04-19-2013, 11:55 AM   #15
CSG Mike
CSG Mike's Avatar
Originally Posted by RAWR BRZ View Post
My helper spring is currently completely compress with the car down. I believe it is more than 2 inch drop at the moment.
Wut?!?
Raise that sucker up!
The helper is there to just help with droop; it should be compressed at rest.
Did you get your spring change done yet for tomorrow??
WillRacer1jz (04-21-2013)
Old 04-19-2013, 12:14 PM   #16
Racecomp Engineering
Wut?!?
Yup, that explains his issues on the track. Raise it up and enjoy the travel!
- andrew
Old 04-19-2013, 12:35 PM   #17
RAWR BRZ
Drives: 2010 BMW M3, 2013 Subaru BRZ
Wut?!?
Ill have to look again... I believe it only compressed after we raised the car up... When it was slammed it wasnt compressed. Im putting the 400/500 and everything else done today
RAWR BRZ is offline   Reply With Quote
Old 04-19-2013, 12:48 PM   #18
JackSmiley
JackSmiley's Avatar
Drives: A Potential Traffic Ticket
I wanted to stance out my frs for a car show with the R2's, but now that im reading this, im having 2nd thoughts.
JackSmiley is offline   Reply With Quote
Old 04-19-2013, 12:54 PM   #19
CSG Mike
CSG Mike's Avatar
Keep in mind that @RAWR BRZ is bottoming out at the track. Are you ever going to track your stanced show car?
Old 04-19-2013, 01:15 PM   #20
RYU
RYU's Avatar
Drives: really slow...
@RAWR BRZ - Thanks for your impressions! I read the section about your ride height being so low you were on the b.stops. What final ride height to you think you'll end up with or did end up with?
+1 on suspension travel!
RYU is offline   Reply With Quote
Old 04-19-2013, 01:27 PM   #21
JackSmiley
JackSmiley's Avatar
When i track it, i'll raise it of course. I dont want to see shreds of my lip in my rear view miror. I drift and track the car, but mostly DD.
Old 04-19-2013, 01:31 PM   #22
RYU
RYU's Avatar
The thing about raising and lowering these cars is that the alignment gets all wacky. The alignment doesn't seem to be as tolerant to height changes from what i've noticed.
$0.02.
Old 04-19-2013, 01:32 PM   #23
JackSmiley
JackSmiley's Avatar
1.5" drop is enough huh?
Old 04-19-2013, 01:41 PM   #24
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
That's normal, I meant if they were compressed completely at droop than you may not need them. We were talking about very high rates, etc.
2".. wow.. you can't have much bump travel in the rear at that height.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-19-2013, 01:42 PM   #25
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I'm not sure the R2's are the best choice for a stanced show car really.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 3 Users Say Thank You to Dave-ROR For This Useful Post:
B L U E S L A T E (04-21-2013), JoeBoxer (04-19-2013), WillRacer1jz (04-21-2013)
Old 04-19-2013, 01:42 PM   #26
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
in for more read later.
TouchMyHonda is offline   Reply With Quote
Old 04-19-2013, 01:46 PM   #27
Hanakuso
I'm guessing if he really wanted to do the show car and track. He could get it aligned with the helper springs and take them out when he goes to car shows?
Btw I asked a Eibach rep about the spring sizes and he said 6 front and 7 rear. He advised not to swap them.
Hanakuso is offline   Reply With Quote
Old 04-19-2013, 01:51 PM   #28
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Told you
He can do a lot of things, but he might be better off with some of the coilovers designed for large drops. I'm assuming some of them have additional shock travel for that reason (I could be wrong of course in that assumption).
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 2 Users Say Thank You to Dave-ROR For This Useful Post:
CSG Mike (04-19-2013), Hanakuso (04-19-2013)
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 06:30 AM
Eibach Multi-Pro R2 Coilover Review donutfilling Suspension | Chassis | Brakes -- Sponsored by 949 Racing 254 05-08-2016 11:56 AM
Eibach Multipro R1 and front and rear sway bar installed Pekingduck Suspension | Chassis | Brakes -- Sponsored by 949 Racing 43 12-30-2013 10:59 AM
***Time to freak out, Eibach coilover pricing available**** JoeBoxer Brakes, Suspension, Chassis 154 05-16-2013 05:30 PM
Eibach Coilover Options - SEMA 2012 Coverage FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 01-25-2013 07:19 AM
