Old 04-18-2013, 03:07 PM   #267
NickFRS
Drives: 2013 Asphalt FRS
Also I would recommend everyone to get a custom tune that is directly for your car. Base maps or E map data doesn't give justice to what putting your car on the dyno and letting a tuner sit behind the wheel and work their magic.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 04-18-2013, 04:04 PM   #268
Kodename47
Kodename47's Avatar
Drives: UK GT86
Guys, I know what I'm doing. Dyno variance etc. is all old news to me, I'm not going to make my choices over a 1hp difference. I have the ability to log everything as we do the tests, both dyno and road. If there's no difference then I'll say so, but I'll post my findings either way. The map shouldn't be any different whether the resonators are present or not anyway, I'm guessing you'll all agree on that since you're telling me that there's no performance difference.
Oh.... and you don't have to put up with a dead pedal after reset/reflash I know I don't...
@NickFRS, have you considered that on partial throttle when a smaller vacuum is created that having a larger volume of air in a chamber near the TB may well be beneficial? Hence the large TRD box and the resonator on the stock airbox. It's just my theory and I could happily be wrong.
.: Stealth 86 :.
Kodename 47 DJ:
NickFRS (04-18-2013)
Old 04-18-2013, 08:46 PM   #269
zooki
Drives: waiting on a 2021...
When you say "at partial throttle a smaller vacuum is created", are you measuring before or after the throttle body? You will have more vacuum behind the TB at part throttle than if the TB was wide open, correct? I know in the old school carb days dual plane intakes used a split plenum so there was less mass of air to accelerate into the chambers when the throttle was opened. The trade off was less plenum volume to fill the cylinders at high RPM.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 04-18-2013, 09:05 PM   #270
sierra
Drives: Skoda Yeti DSG diesel 4x4
Unless I need the power I stick to the higher gears and use 6th in 60kph limits, 5th for 50kph. Around town 3rd is good for roundabouts and taking turns into sidestreets with 1060rpm to 3200rpm equating to 20kph to 60kph.
In that rpm range it pulls sweetly, without any drama and with good strong torque.
The dyno plots the full throttle power throughout the rev range while partial throttle is, I suspect, far less affected by the torque dip.
If I floor it at 2000rpm it pulls hard and then dies from 3200rpm to 4000rpm when it comes alive again with 5000rpm to the cut out really strong.
However I rarely use full throttle and the same exercise using 1/3 throttle has far less impact[if any] in the 3200 - 4000rpm zone and at 5000rpm up I enjoy increasing the throttle in increments because it's so responsive you can feel every extra bit you give it.
My last 3 fill ups by calculation were 6.61, 6.96 and 6.50 L/100km[36.2mpgUS]
All my resonators are connected and the only mods are Perrin drop in filter and Nameless axleback.
sierra is offline   Reply With Quote
Old 04-18-2013, 09:31 PM   #271
Turdinator
Señor Member
Turdinator's Avatar
It seems logical to me that a greater volume of air between the throttle and ait filter will provide better throttle responce. But i can't see how a larger volume before the filter would improve things unless there is a further restriction before the filter.
1974 TA22 Celica
2013 86 GT
Old 04-18-2013, 09:40 PM   #272
Turdinator
Señor Member
Turdinator's Avatar
Originally Posted by sierra View Post
...My last 3 fill ups by calculation were 6.61, 6.96 and 6.50 L/100km[36.2mpgUS]...
Off topic but those are fantastic fuel consuption figures. I don't drive at all for economy but my computer says i am at about 10.5L/100km [22.4mpgUS]
1974 TA22 Celica
2013 86 GT
Old 04-18-2013, 11:11 PM   #273
sierra
That's probably why I rave about the power, it's a surprise when I put my foot down! You must get into it all the time! I reset the average L/100km when I fill up and it reads 0.2L/100km low.
I'm going to start another thread, if I can't find one, about changing the engine oil because it's been cooked. So I do give it some too.
Old 04-18-2013, 11:27 PM   #274
NickFRS
I average 30MPG..... 36 is awesome!
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
The Following User Says Thank You to NickFRS For This Useful Post:
sierra (04-18-2013)
Old 04-18-2013, 11:31 PM   #275
Turdinator
Señor Member
Turdinator's Avatar
Haha, i enjoy driving my car thats all i will say. Incidently i don't feel the car is underpowered. If the torque dip was filled in i would think it was a great engine for this car.
Sorry for going off topic.
1974 TA22 Celica
2013 86 GT
Old 04-19-2013, 12:10 AM   #276
sierra
I agree. This is one sweet car and the engine is a perfect match apart from the torque dip. Any mods to improve it, without going to FI are of interest to me, that's why I follow threads like this.
I wonder if those that fit a turbo are really happy with that route afterwards? They have more torque and power but the delivery, once it spools up, is quite linear in delivery and engines under boost are quiet.
I much prefer to hear it working it's guts out, at least when it sounds good and this motor while NA delivers and completes the race car package.
Old 04-19-2013, 12:15 AM   #277
Jesse
wheel gap
Jesse's Avatar
Drives: whiteout frs, 04 xrs
recently went from injen intake to TRD airbox/intake. much more smooth with fa20clubs tune. less noise, but its drives better. i would like one of the upgraded snorkels mentioned earlier in the thread, i think i would work nice with the trd box.
Jesse is offline   Reply With Quote
Old 04-19-2013, 02:34 AM   #278
nix
nix's Avatar
Drives: AVO BRZ
I checked today and my average is at 13.8l/100km (17 MPG). Oops.
I am going to leave the main resonator on my car. I took the snorkel off when installing my FMIC but plan to replace it with aftermarket eventually.
I still need to do some shrouding tweaks around the fmic/radiator/heat exchanger before I'm totally finished with the intake.
nix is offline   Reply With Quote
Old 04-19-2013, 04:17 AM   #279
Kodename47
Kodename47's Avatar
Drives: UK GT86
I don't see that it would matter particularly just before/after the filter as it's within the same enclosure. It's not like there's a much of a pressure difference before/after the filter
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-19-2013, 04:22 AM   #280
sierra
I agree.
It's the volume after the throttle valve that's critical and the only way it could be important before that is if there's a restriction back down the line.
Why would they engineer that in?
Stock resonator removal? jm1681 Engine, Exhaust, Transmission 33 10-11-2019 06:58 PM
MT Stock Shift Knob, Stock Intake w/Snorkel Vicious LED Interior Parts (Incl. Lighting) 1 02-09-2013 03:14 PM
Length of stock resonator? jm1681 Engine, Exhaust, Transmission 5 10-26-2012 07:25 AM
WTB Stock OEM Airbox/snorkel brichard0625 Engine, Exhaust, Bolt-Ons 1 10-20-2012 09:21 AM
WTB: Stock AirBox SkullWorks Engine, Exhaust, Bolt-Ons 1 08-15-2012 09:09 AM
