Old 04-18-2013, 04:31 PM   #225
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
Originally Posted by ill roller View Post
There is justification... Anyone can do whatever they want with a car, that is the justification.
Originally Posted by Wonderbar View Post
You know... At the core of this entire argument, it really isn't any different than when I want to build my daily driver into a 500+ whp monster car.
Like with my Eclipse; do I *need* 500whp and a roll cage, $5,000 dollars in suspension and brakes and wheels? Is it "safe" that I don't have airbags? Is it really necessary for me to be able to smoke my tires while rolling on the freeway?
Most people would ask me the same questions of why I need to do all that to my car.
SLICVIC is offline
Old 04-18-2013, 05:17 PM   #226
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
Let's take a look at some cars that are form before function:
Below, a car that has modified it's suspension to mimic a race car and is basically unsafe for public roads:
How about another car enthusiast group that requires fender modification, messing with suspension geometry, and putting undue stress on factory components? here:
Just sayin, we're all car enthusiasts
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline
The Following User Says Thank You to 6-Shift For This Useful Post:
Rayme (04-18-2013)
Old 04-18-2013, 05:47 PM   #227
SatinWhitePearl
Drives: '07 Subaru STi / '11 Honda Civic Si
... we all know "stance" is just a really cool way to play off your car's theft recovery status - from Mexico.
Calling a tastefully modified car clean, because it has been tastefully modified, and then calling a clapped out car clean because its been clapped out, isn't the same thing.
SatinWhitePearl is offline
Old 04-18-2013, 05:47 PM   #228
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
Originally Posted by Subarudood View Post
Having a raised or lowered car is not the same as deliberately setting your camber to completely ruin your contact patch and cornering characteristics for no reason other than to look like a fool. There is really no need to keep discussing it. It hurts performance just so someone can try to stand out.
lmao what am i performing?! should i be suicidal that i cant pull hella G's on the way to the movies or supermarket?
ps: @ill roller just seen your car on the stancenation instagram, looks really good
SLICVIC is offline
Old 04-18-2013, 05:50 PM   #229
6-Shift
Señor Member
6-Shift's Avatar
Having a raised or lowered car is not the same as deliberately setting your camber to completely ruin your contact patch and cornering characteristics for no reason other than to look like a fool. There is really no need to keep discussing it. It hurts performance just so someone can try to stand out. This behavior is second only to get the gentleman getting the BRZ tattoo.
CAR 1 is lowered and chopped. Not sure how you can argue that hurts performance for the cars original state especially with the upgraded suspension, increased function over stock
CAR 2 DRAG CAR, has drag suspension and is setup foR FUNCTION. Come on kick star that brain
Car 3 Truck lifted off the ground for ground clearance, again function.
BRZ photo, mods that increase and enhance nothing at all, only take away from the car. Are you starting to understand?
*To establish, I tried to only reference street cars. For the first car, I was more responding to people talking about being "too low." Also, have you RIDDEN in a hot rod this low? Trust me, the suspension is a lot LESS functional for a street car. For the second, it's a response to the people who are complaining about modifying suspension outside factory specs/replicating racecars. And, lastly, lifted trucks run into a lot of similar problems that super-lowered cars do suspension wise: increased wear on bushings, stress on wheel bearings, body damage from "ill-fitting" wheels and tires, etc.
6-Shift is offline
Old 04-18-2013, 05:54 PM   #230
6-Shift
Señor Member
6-Shift's Avatar
I just don't even know what to respond to this. Yes, because these brand new BR-Z's are definitely stolen from Mexico by ill and vic...just like their other cars and in response to the bolded part:
6-Shift is offline
Old 04-18-2013, 06:01 PM   #231
Outlawstar98
SLOW BRZ
Outlawstar98's Avatar
Drives: 2013 328i xDrive; 2013 BRZ
Might want to add that any lifted truck going down the road at normal speeds tend to swerve some due to the soft suspension setup.
Outlawstar98 is offline
The Following User Says Thank You to Outlawstar98 For This Useful Post:
6-Shift (04-18-2013)
Old 04-18-2013, 06:02 PM   #232
SatinWhitePearl
Joke > you.
Personally, I think stancing out your "whip" make it look cheap more than anything else...
There's a way to make a car flush and functional without detracting from the car.
Old 04-18-2013, 06:14 PM   #233
polarstorm
polarstorm's Avatar
Drives: Scion FR-S
Originally Posted by Jinzen View Post
He thinks it looks sooo cool. That's the lifestyle. Except most people think it looks mega lame.
That not even half as bad as badge swapping, which portrays only a self confidence issue on the part of the driver and not the vehicle, or brand. I for one bought the car exactly for the specs. If I wanted a badge I woulda bought a beemer or a rolls.. toyota badge I kinda understand that, its a gt86 elsewhere in the world. was gonna buy a golf, but I started looking at the specs in a very lucid kind of way..
polarstorm is offline
The Following User Says Thank You to polarstorm For This Useful Post:
strat61caster (04-18-2013)
Old 04-18-2013, 06:17 PM   #234
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
That's funny! I traded in my BMW for my Scion!
Scott
naikaidriver is offline
Old 04-18-2013, 06:38 PM   #235
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Wha- but I thought...
We're not a part of the "stance scene"
ATL BRZ is offline
Old 04-18-2013, 06:41 PM   #236
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
Originally Posted by ATL BRZ View Post
Wha-
huh?
SLICVIC is offline
Old 04-18-2013, 07:56 PM   #237
EarlQHan
Drives: Subarus
ill roller doesn't build his car specifically for the "hellaflush/stance nation" scene. he builds his cars the way he likes them, as we all do. his car just happens to fit the type of car they like to post. he also loves to beat the living hell out of the car. i promise you his cars see more mileage and more track time than most "track-oriented" cars or "show" or "hellaflush/stanced" cars
EarlQHan is offline
The Following User Says Thank You to EarlQHan For This Useful Post:
SLICVIC (04-18-2013)
Old 04-18-2013, 08:32 PM   #238
ill roller
Drives: BRZ/E30/IS300/LS400
See that's a problem, "gay" has negative connotations for you when it shouldn't. Do you get offended for being called "straight"? Masculine? Feminine? Assumptions about sexuality are just bad, let alone racial or gender based stereotypes. It's an issue humanity has struggled with and will continue to struggle with, justice and equality for all is a long time off, don't be one of the people who delay that even in a minute way.
Like it or not lowering a car to near impracticality or putting on shiny wheels that only serve to please a certain subset WILL raise objections, as will putting on slicks or putting in a roll cage or stripping out the interior as will painting it pink or metallic green or putting on a body kit.
Everybody is different, there are certainly people I talk to daily who think I'm dumb for not wanting a wing + fart cannon + 19" wheels for my FRS but that's one of the few things that make car culture interesting. All you gotta say is "well it makes me happy" and let others blow the blood vessel.
or penis as the case may be.
Why shouldn't it? I'd rather not be associated with something that I personally do not care for... Should I be welcoming dudes to hit on me? As i said, I'm completely cool with whatever other people want to do, but saying that I'm stereotyping by not wanting to be called something I'm not is a joke.
Near impracticality? I drive my car 100 miles a day and bring it to the track with no issues... Where is the impracticality? As I said, people can dislike it, people can express the fact that they don't like it, but stop spouting out misinformation.
I can't stop some stance blog from posting a picture of my car... They post what they find on the internet. If they want to post a drift car, more power to them.
RISKY DEVIL // ILL PHOTOGRAHY
ill roller is offline
The Following User Says Thank You to ill roller For This Useful Post:
sklimo (04-18-2013)
What function can it be used for, the idle button place yuli8466 Cosmetic Modification (Interior/Exterior/Lighting) 50 01-29-2013 04:17 PM
List of plug & play Recaro seats compatible w/heat function? [Cyanide] Cosmetic Modification (Interior/Exterior/Lighting) 0 12-11-2012 12:50 AM
AG.Function Forged Wheels Eric@GetYourWheels Wheels and Tires 22 08-01-2012 01:16 PM
In Stock Form: hybrid4g Scion FR-S / Toyota 86 GT86 General Forum 31 07-20-2012 07:44 AM
Roofline: Form over function. ft86cbx Scion FR-S / Toyota 86 GT86 General Forum 15 04-24-2011 01:27 AM
