#253 |
Señor Member
And a sound clip. This is with the MaxRacing duct, Perrin silicon intake, Perrin foam filter and all other resonators removed and sealed.
[ame]http://youtu.be/xbpEtjbpRFc[/ame]
1974 TA22 Celica
2013 86 GT |
| The Following User Says Thank You to Turdinator For This Useful Post: | Teseo (07-24-2024) |
#255 |
Señor Member
I don't have any in my local area but I will see if I can hunt one down. The good old butt dyno thinks it adds more than the silicone tube but less than the filter.
1974 TA22 Celica
2013 86 GT |
| The Following 2 Users Say Thank You to Turdinator For This Useful Post: | Huehuecoyotl (04-13-2013), NickFRS (04-17-2013) |
#256 |
Drives: 2013 Asphalt FRS
Now I need to buy one..... They are so expensive though!!!
2013 Sion FRS
2014 Subaru WRX 2014 Subaru XV |
#257 |
can you take a picture with flash of where it sits behind the bumper? I'm curious about that. If I did go this route I think a mesh guard before and after the snorkel might be a good idea
2013 Sion FRS
#258 |
Señor Member
I have a close up one that i'll post when i get home. I will se what i can do from further away. I don't know if the iphone flash is strong enough.
1974 TA22 Celica
2013 86 GT |
| The Following User Says Thank You to Turdinator For This Useful Post: | NickFRS (04-18-2013) |
#259 |
Señor Member
And Gem when you return PM again.
1974 TA22 Celica
2013 86 GT |
#260 |
Señor Member
1974 TA22 Celica
2013 86 GT |
#261 | |
Drives: Scion FR-S
Sent from my Nexus 7 using Tapatalk HD |
#262 | |
Drives: UK GT86
I still believe that the main resonator helps throttle response lower down, might have to do with added volume of the airbox as well as wave cancellation. As stated the Griffon is a race car and will spend time at full throttle & high RPM where it's likely the resonators make less of a difference.
.: Stealth 86 :.
#263 | |
Drives: Scion FR-S
| The Following User Says Thank You to vtmike For This Useful Post: | NickFRS (04-18-2013) |
#264 |
I don't think a dyno will truly show anything. But if you do get a dyno and be like the car lost 1HP! The engine will flux 2-3HP per pull on its own naturally. So it's hard to figure it out... I believe the only way you could compare is if you had a stock car with stock intake. Then compare the AFR's with and w.o. Otherwise it's just false data. PLus when you speak of throttle response we are talking milliseconds here. Also all CAI in your theory would have the same waves you are talking about and create bad throttle response since they don't have resonators. (the only reason cai's have better throttle response is the added volume in the tune and it's not so aggressive bends. This creates better air flow)
My theory: The resonators are put in place to reduce induction noise. All stock cars have zero induction noise. The sound tube was created to increase engine noise in the cabin to give that little extra pazaz of performance but in reality doesn't really change anything that dramatically. You can hear my intake scream now after 4k RPM's when my vvt and dual avcs kick in harder. Also i'm assuming w.o the resonators the car wouldn't be carb legal. Plus on a stock car when you are talking about 2k response time the only time I would see myself at 2k RPM's is in first rolling at 5mph and there will always be a flux in throttle response in first due to the drivetrain and gear size as well as 2nd. This will be more dramatic with a LWCP and LWFW. Since the ratio is so small and if you have the reduction in spinning weight/mass the ECU has to really think to go with throttle position let alone all the other variables. If you are in a higher gear your car in general is about to hit the torque dip and w.o headers the plot from 2k-4k is discusting. Mine shows this on the dyno graph. a camel back of torque between 2k-3k is always going to feel weird while driving.
2013 Sion FRS
#265 |
Also I believe the TRD griffith car was the creation stand point behind the TRD intake. They were testing "I mean truly" testing with that car. Once they figured out the resonators and sound tube were for emissions and customer satisfaction they deleted them and started production of the TRD intake you see today that just hit the market as an "after market solution." The box is still huge and thats due to emissions also! Big ins't always better. Vacuums dont have huge hoses on them for a reason. It creates less suction. A small 2.0 doesn't need a huge intake! A engine has to be rounded and mods have to complement each other. mods don't stack up HP or TQ .
^^^ assumption Plus cai intakes don't really show any real true gains over stock once tuned unless we are talking about FI.
2013 Sion FRS
#266 | |
Drives: Scion FR-S
| Stock resonator removal? | jm1681 | Engine, Exhaust, Transmission | 33 | 10-11-2019 06:58 PM |
| MT Stock Shift Knob, Stock Intake w/Snorkel | Vicious LED | Interior Parts (Incl. Lighting) | 1 | 02-09-2013 03:14 PM |
| Length of stock resonator? | jm1681 | Engine, Exhaust, Transmission | 5 | 10-26-2012 07:25 AM |
| WTB Stock OEM Airbox/snorkel | brichard0625 | Engine, Exhaust, Bolt-Ons | 1 | 10-20-2012 09:21 AM |
| WTB: Stock AirBox | SkullWorks | Engine, Exhaust, Bolt-Ons | 1 | 08-15-2012 09:09 AM |
