#295 |
I Love custom Turbo kits
Drives: Limited BRZ
I'll let you know what I do, but its very probably my solution will not work for you because it will involve either moving the turbo discharge pipe, or getting a new one made.
#296 |
Drives: 2023 WRB BRZ (MT)
#297 |
NASA SpecE30 Racer
Can you make me a boost curve graph now?
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#298 | |
NASA SpecE30 Racer
- King Tut
| The Following User Says Thank You to King Tut For This Useful Post: | Sportsguy83 (04-18-2013) |
#299 |
Drives: Limited BRZ
I haven't forgotten about you!! Next tune John sends me, I'll do the pull.
#300 |
NASA SpecE30 Racer
Awesome. I am still working on my EBC settings to get the best curve I can. I am almost there.
- King Tut
#301 | |
Drives: Limited BRZ
7 and change psi in second, 8 + in third almost 9 in fourth and haven't checked more than that.
#302 |
NASA SpecE30 Racer
That seems very strange.
- King Tut
#303 |
Drives: Limited BRZ
The state in their instructions that you should check PSI at 3rd or 4th, because if you check in 1st or 2nd, PSI will be higher at higher gears, but I don't understand why.... Probably they designed it like that, but what have they done different than any other MBC and why did they do it like that.
I put the universally recommended half hole preload in the WG.
#304 |
Drives: FRS with 2jz, 2015 STI 9.68@147
If after you adjust the downpipe and overpipe and it still rattles try upgrading your motor mounts. The motor rocking around on the stock mounts will cause it to move. With the mounts all nice and solid it could fix it.
#305 | |
Drives: Limited BRZ
Thanks for the suggestion! On another note, I get compliments on the gauge cluster EVERYWHERE I go (well, except for user ft sjo LOL) Hope everything is going good Mike!!
#306 |
Regarding the overpipe hitting the frame, running a 2.5" pipe through there was already a pretty tight fit (vs the 3" ). We ended up using the AVO 2.5" over pipe and have not had any issue with contact. But I have the auto which trends to have less engine movement during shifts.
#307 | |
Drives: Limited BRZ
Ihave the solution pictured in my mind, but the pain in the ass is going out and doing it LOL. Worst case scenario, a new 3" turbo discharge pipe an inch shorter will for sure do the trick.
#308 | |
So generally, you'd see the turbo reaching peak boost in 1st and 2nd gear around 3000-3500 (assuming you even have time to pay attention), then dropping to 3000 in 3rd, then 2500-2800 in 4th, then even quicker in 5th/6th. |
| The Following 2 Users Say Thank You to AVOturboworld For This Useful Post: | Chewie4299 (04-20-2013), Sportsguy83 (04-18-2013) |
| Volk Racing TE37SL - Mag Blue/ Hyper Blue/ Flat Black/ Red/ Gold IN STOCK!!! | Speed Element | Wheels and Tires | 151 | 09-26-2013 05:56 PM |
| Dream Mod For FR-S/BRZ | JPxM0Dz | Other Vehicles & General Automotive Discussions | 22 | 03-08-2013 11:35 PM |
| Have You Had A Dream About Your Car? | chanomatik | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 01-29-2013 03:38 AM |
| Sonic Blue 86, Galaxy Blue deleted? | 450hp/tonne | AUSTRALIA | 14 | 09-01-2012 08:10 PM |
| I had a dream... | ashtray | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 03-13-2012 12:35 AM |
