Old 04-17-2013, 06:42 PM   #15
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
Use contact adhesive...the yellow stuff. For a small part like this you can brush it on each side and let it tack up before sticking the two together.
chadstyle is offline   Reply With Quote
Old 04-17-2013, 07:00 PM   #16
driftartist
Kurenai Samurai
driftartist's Avatar
Drives: Red and manual
i got my shifter boot for my 93 mr2 from that site. awesome products i would recommend. very durable feeling
driftartist is offline   Reply With Quote
Old 04-17-2013, 10:19 PM   #17
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
just went ahead and ordered the dash pieces too. hopefully it'll come out ok
abutterman is offline   Reply With Quote
Old 04-18-2013, 12:04 AM   #18
stockysnail
Just the tip
stockysnail's Avatar
I ordered the dash piece a week or so ago so it should be here next week hopefully.
Old 04-18-2013, 12:41 AM   #19
Gen
Drives: Scion FR-S
They need to work on that stitching. Looks good otherwise, but even the shift boot is off and these are the photos on their website.
How it should look...
Not trying to hate, just pointing it out so people aren't disappointed.
Gen is offline   Reply With Quote
The Following User Says Thank You to Gen For This Useful Post:
2pt5RS (02-04-2016)
Old 04-18-2013, 07:36 AM   #20
s2d4
s2d4's Avatar
Fair pick up, perhaps that side was meant to be facing the AC controls.
If so, it isn't like you'll ever see it and you can't beat that for ~50 dollars.
I can see some stitching issues on the top right corner, it doesn't appear to follow the contour of the dash pad either?
Old 04-18-2013, 08:22 AM   #21
cslntuee
Drives: Subaru BRZ Limited
They have multiple options for material, color and pattern…etc.
What kinds di you select?
Thanks a lot.
cslntuee is offline   Reply With Quote
Old 04-18-2013, 10:26 AM   #22
abutterman
abutterman's Avatar
I noticed the stitching on top as soon as i opened it up but since it's literally only one stitch that they missed i'm ok with that. It's bound to happen here and there regardless of who makes it when they're hand made them since they're all made to order and not mass produced. I can even pick out a few examples of the stitching being off a little bit on my $800 leather coat so it's to be expected. I was going to put that side facing the back but realized the other side was supposed to be the back as it had 2 small slits cut in it to allow it to stretch over to the reverse lockout. (not sure if they need to use the slits on all possible designs or just with the stripes since the stripe is it's own piece and has to be stitched in and that part ends up stiffer since the leather is rolled in on the inside and creates seams) but all in all i'm quite pleased for $50 shipped.
Their stock picture of the dash pad stitching is definitely of concern but it was literally their first one they made like that so hopefully mine will be ok. For good measure, i added a comment in my order to try to get that even lol
Old 04-18-2013, 03:03 PM   #23
stockysnail
Just the tip
Thanks a lot.
I just kept it simple and got the black alcantara with red stitching to match my stock parts and JPM Coachworks gauge cluster hood.
Old 04-18-2013, 04:02 PM   #24
abutterman
abutterman's Avatar
i ordered basically the same thing but with black leather instead with the red stitching. I just hope it's cut in a way that it won't interfere with getting the pieces to clip back in. If it wraps around the that edge where the 2 meet, it might be too thick. Guess we'll see what happens
Old 04-18-2013, 04:05 PM   #25
abutterman
abutterman's Avatar
i just put the ebrake boot up to handle to see how it'll look and it blends so nice with the leather texture of the plastic they used for the center console. I might get it glued up to the frame tonight
Old 04-19-2013, 01:27 AM   #26
wootwoot
Drives: FRS
pictures of the e-brake boot?!
Old 04-19-2013, 02:11 PM   #27
abutterman
abutterman's Avatar
in the process of gluing it up now on my lunch break lol should be ready to put it back in the car when i leave work this evening
Old 04-19-2013, 03:54 PM   #28
abutterman
abutterman's Avatar
Glues done... Just need to pop it back in
Crown Royal Shift Boot Derik210 Cosmetic Modification (Interior/Exterior/Lighting) 30 09-04-2015 06:06 PM
How-to: Install JPM Coachworks 6MT Alcantara or Leather Shift Boot JPM Coachworks DIY (Do-It-Yourself) Guides 22 06-27-2014 12:46 AM
WTB: Red stitched ebrake boot AG3NT_5CARFAC3 Interior Parts (Incl. Lighting) 1 02-28-2013 01:04 AM
WTT: My red stitched ebrake boot Laika Interior Parts (Incl. Lighting) 10 02-09-2013 02:26 AM
Need Subaru BRZ shift Boot djliquidsteele Cosmetic Modification (Interior/Exterior/Lighting) 0 10-21-2012 05:18 PM
