Old 04-17-2013, 10:41 AM   #1
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
I can reproduce the struggle-to-start issue
I don't know if this applies to the manual or the frs, but i have a BRZ limited auto, and i figured how to reproduce the struggle-to-start issue.
When starting the car with push button start, the process normally is: step on brake, push the button. I find if i don't step on the brake all the way down AND press then release the push start button right away, the car will struggle to start.
Here is what i tried on the same day:
First try in the morning: step on brake firmly, push start button hold for 1 sec, car starts fine.
Second try after the the first drive in the morning: step on the brake lightly, press the start button and release right away, car struggles to start, but eventually started.
I repeated the above the next day, same result. I tried these about a week ago and i have been firmly stepping on the brake and hold the push start for 1 sec and haven't had the car struggle since.
Not sure if it's just my car, or anyone with an auto with push start can reproduce this? Donno about the manual start procedure. Maybe some of you who are mechanically inclined can speculate what's wrong based on my steps?
chenshuo is offline   Reply With Quote
Old 04-17-2013, 10:59 AM   #2
congiiee
Drives: WRB Subaru BRZ
hmm. I need to try this but I have been getting spotty starts as well.
congiiee is offline   Reply With Quote
Old 04-17-2013, 11:17 AM   #3
gzpermadi
gzpermadi's Avatar
Drives: Toyota 86 Silver
security measures?
In the owner's manual, it is mentioned: "firmly depress the brake pedal" and continue until engine starts.
For Manual you have to press the clutch.
gzpermadi is offline   Reply With Quote
Old 04-17-2013, 12:10 PM   #4
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Yeah on a manual, if you release the clutch (while in neutral) during the starting procedure, it will kill the engine... I guess it's a question of timing that differentiates struggle-to-start and plain ol' stall.
Guillaume is offline   Reply With Quote
Old 04-17-2013, 12:18 PM   #5
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Thanks potato.
Old 04-17-2013, 12:34 PM   #6
OrbitalEllipses
Drives: Attitude
I don't even think I press the brake when I start the car; just the clutch since my e brake is engaged.
Must remember to try this later.
Old 04-17-2013, 12:37 PM   #7
Moshpit37
FR-S Owner!
Moshpit37's Avatar
Drives: 2013 FR-S Ultramarine 6AT
So what you're saying is, when you don't follow the procedure properly as per the owners manual, it doesn't work properly? Seems pretty self-explanatory to me. We in the aircraft maintenance field call that "pilot error."
Frances - 2013 Scion FR-S in Ultramarine
Owner's Journal
Moshpit37 is offline   Reply With Quote
The Following User Says Thank You to Moshpit37 For This Useful Post:
strat61caster (04-17-2013)
Old 04-17-2013, 12:40 PM   #8
SloS14
SloS14's Avatar
If a non-qualifying sequence is initiated, the vehicle shouldn't struggle to start: it should not try to start at all.
Old 04-17-2013, 12:41 PM   #9
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Pilots (even private ones like me) tend to call that "design flaw".
Old 04-17-2013, 12:43 PM   #10
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
So in other words: If you don't allow the car to prime itself it will struggle to start.
In other news cars continue to operate as designed.
ineedyourdiddly
Old 04-17-2013, 12:47 PM   #11
OrbitalEllipses
Drives: Attitude
Fuel pump priming in a Limited must be done by pressing the start button twice with the clutch engaged (foot off pedal). Due to the five seconds longer this takes me, I don't do it. Never had a reproducible starting issue. Only inconsistent struggle to start occasionally when cold and several times after starting shortly after a drive.
Old 04-17-2013, 12:49 PM   #12
Moshpit37
FR-S Owner!
Moshpit37's Avatar
The sequence OP is describing isn't wrong, just that he's not holding the brake firmly and, what I'm guessing the real issue is here, he's not holding the start button long enough. I've had my FR-S struggle to start a few times as well (which is how I found myself in this thread to begin with) but it was always when I was in a rush and let go of the key too soon. Usually it cranks through 3-4 firing sequences before fully coming to life, but for some reason sometimes it takes longer. Thought the reason for that was being addressed here, but when I read the thread I just had to laugh.
Owner's Journal
Old 04-17-2013, 12:52 PM   #13
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
I don't think you need to press the brake while starting a manual car...
shu5892001 is offline   Reply With Quote
Old 04-17-2013, 12:54 PM   #14
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
what i'm saying is, for those who are experiencing this issue, maybe they didn't press the brake HARD ENOUGH even if they thought they press the brake firmly. The word "firmly" is pretty subjective. We in the software field don't believe in subjective terms. We like to have everything to be "measurable".
again, this reproducing sequence is my personal experience, and it's with the auto. YMMV.
BRZ wouldn't start Pete156 Issues | Warranty | Recalls / TSB 57 05-29-2013 08:36 PM
No maf no start? Silverdub Engine, Exhaust, Transmission 14 03-30-2013 12:21 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 03:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 04:44 AM
Car Won't Start schtebie Issues | Warranty | Recalls / TSB 25 10-15-2012 05:06 PM
