Old 04-17-2013, 08:13 AM   #7477
Ninjin
Ninjin's Avatar
Drives: SWP BRZ 6MT
Originally Posted by Evil86 View Post
I replaced three the first few months. With anti-seize and taking the time to hand tighten the lugs 4+ turns, it hasn't happened again.
The repair is easy. Pull the wheel, dismount the brake caliper, use a zip tie or wire to suspend it to keep strain off of the brake line or shove the caliper someplace so it isn't hanging. If enough of the lug is left, than a good whack with a ballpeen should do it, otherwise, use a punch. Weasel the broken lug out and weasel the new lug in. Use a bunch of flat washers and a nut to set the lug. Easy-peasy.
Fronts aren't too bad, provided you have the right hammer or press to get the studs out. They can be stuck in there pretty good.
Rears could be more trouble, since it would be really difficult to put the lugs in without removing the hub (people who do it on other Subarus usually grind down the stud heads to get them to fit). Taking off the hub to do it right will probably require a good impact wrench to get the axle nut off. (I couldn't get mine off with a four foot cheater bar) You'll also need new axle nuts to put back on, since they're not supposed to be reused (it's a cheap part).
I got tired of breaking wheel studs (especially right before an autocross) and took my car to Goodspeed to have all of them replaced with ARP studs. There's a huge difference now in how easily the lug nuts thread on, it makes me realize how crappy the stock ones are.
You could probably take the car to almost any shop, but Goodspeed's price for the work was actually really good and I wanted someone I could trust since the job involves a bit of hammering on the car.
ARP studs: http://store.propartsusa.com/arp/arp...6/i-61598.aspx
Muteki open lugs: http://store.propartsusa.com/muteki/.../i-545251.aspx
(Also available in purple, chrome and titanium)
The Following User Says Thank You to Ninjin For This Useful Post:
thesleeper (04-17-2013)
Old 04-17-2013, 11:00 AM   #7478
Sivtec
Sivtec's Avatar
So Eric at LM can't find the right green I'm going for. So I thought I would make a thread to see if anyone comes across anything.
http://www.ft86club.com/forums/showt...819#post871819
Old 04-17-2013, 11:21 AM   #7479
jeffsides
AZ FRS 86
jeffsides's Avatar
Eric ordered me more carbon fiber vinyl. I'm doing a couple more small pieces.
@AZFRS86
Old 04-17-2013, 11:31 AM   #7480
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
Give a call to visual impact graphics in mesa I have no idea if they have it but they seem to be the cheapest around encase they have it.
Sent from my SGH-T989 using Tapatalk 2
The Following User Says Thank You to Accurate Race Shop For This Useful Post:
Sivtec (04-17-2013)
Old 04-17-2013, 11:49 AM   #7481
Ninjin
Ninjin's Avatar
Drives: SWP BRZ 6MT
Last time I talked to Visual Impact I got the impression that they don't deal with many wrap type vinyls. Smart wrap would probably be a good place to start, but they are pricier.
Sent from my Nexus S using Tapatalk 2
Sivtec (04-17-2013)
Old 04-17-2013, 12:03 PM   #7482
Accurate Race Shop
Drives: Scion FR-S
I've seen them wrapping a van but no idea if they would be willing to wrap a little car but if they can get it they will probably sell the vinyl dirt cheap if he could talk lm into installing it for him.
Old 04-17-2013, 12:18 PM   #7483
Sivtec
Sivtec's Avatar
Yea Eric said that if I found the material he would still install it for me. We will see if I can find it and for how much. This will probably come down to cost as well. Eric said he would install it but his price isn't exactly dirt cheap, but I know he does a good job as well.
Old 04-17-2013, 12:26 PM   #7484
Evil86
Evil86's Avatar
Drives: Monkey-butt red FR-S
You do not need to take the hub off, I snaked the old one out through and opening in the hub, and worked the new one through the same hole.
Here is a thread with pictures http://www.ft86club.com/forums/showthread.php?t=8852
Evil86 is offline   Reply With Quote
The Following User Says Thank You to Evil86 For This Useful Post:
Ninjin (04-17-2013)
Old 04-17-2013, 12:27 PM   #7485
Sivtec
Sivtec's Avatar
Thought I would share this, my coworker found it.
http://www.groupon.com/deals/gsm-log...hkIRnFiOLywCZy
Old 04-17-2013, 12:42 PM   #7486
Accurate Race Shop
Drives: Scion FR-S
That is the way I have always done it. The extra five minutes working them in place is easier than pulling it all apart in my opinion
Old 04-17-2013, 12:46 PM   #7487
Accurate Race Shop
Drives: Scion FR-S
Kevin's co-driver Elliott was working with them the last time I went over there. It only last about 10min in the car so not worth it unless you really just want to be able to say you drove one. I was there so Elliott could drive my car and give me feedback on my suspension.
Sivtec (04-17-2013)
Old 04-17-2013, 02:02 PM   #7488
nelsmar
I was tryin out my new point and shoot (lol) this morning. And hey its AZ & 86 related right?
My flickr - Canibeat
Local magazine scout
The Following User Says Thank You to nelsmar For This Useful Post:
SMOKETREES (04-17-2013)
Old 04-17-2013, 02:36 PM   #7489
thesleeper
thesleeper's Avatar
Drives: Asphalt FR-S
Thanks for all your input everyone!
I just ordered some studs from the dealership for now until I have time to replace all of the studs with some ARP ones. The more I look into it, I think I'll give replacing them myself a shot
thesleeper is offline   Reply With Quote
Old 04-17-2013, 02:50 PM   #7490
Sivtec
Sivtec's Avatar
Like
