Old 02-21-2013, 02:48 AM   #197
s3xy_burrito
Taco Flavored Kisses 💋💋💋
s3xy_burrito's Avatar
Drives: Scion FR-S Raven
Powered by max
http://www.gtfactory.jp/cms/page.php?29
Instagram: tilted_h3ro
s3xy_burrito is offline   Reply With Quote
Old 02-21-2013, 01:01 PM   #198
Hix
Hix's Avatar
Drives: 2017 WRB PP
@Racecomp Engineering What is the point of having such high front rates on the Yellows?
I am having a big issue deciding on which springs to get. This is my daily driver and I have another car that is a track car. I really just want a better feel without much harshness added. Filling the insanely large gap would be nice as well.
Anyone have some advice?
Hix is offline   Reply With Quote
Old 04-16-2013, 05:08 PM   #199
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
are the inches on the springs are the amount of drop?
imravenit is offline   Reply With Quote
Old 04-17-2013, 03:14 AM   #200
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
springs with the most drop?
ive done a lil bit of research but i was hoping you guys can help..
so far the only company i know that provides you with the most drop is the EIBACH with there sportline springs..
any input? advice? thanks
Old 04-21-2013, 03:14 PM   #201
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
drop is listed in inches, however some springs wont give you that drop until the springs settle after install. Also some will drop and additional .1-.3 after spring settle from the listed drop.
Advice? i don't believe anyone can give you accurate advice because you haven't told us what you want to achieve. Looks or performance? mix of both? compromise one over the other?
WingsofWar is offline   Reply With Quote
Old 05-05-2013, 12:50 PM   #202
glorydays
Remember me?
glorydays's Avatar
Drives: BRZ Series.Blue
Did some window shopping. Found these springs by vogtland and even some megans... the vogtland's drop is 1.6" all around with an unknown spring rate (I sent an email). The megans are 1.75" in the front 146lbs/in and 1.25" in the rear 230lbs/in.
http://shop.vdf-springs.com/index.ph...rz-typ-zc.html
http://www.meganracing.com/products/...=1541&catid=44
glorydays is offline   Reply With Quote
Old 05-07-2013, 10:51 PM   #203
glorydays
Remember me?
glorydays's Avatar
The vogtland rep responded with these spring rates...
Front Initial: 160, final:200
Rear Initial: 143 Final:257
Old 05-09-2013, 01:57 AM   #204
JimmyCrez
Drives: 2012 Toyota GT86
Eibach Sportline Ordered- 3 weeks delivery
Any one know if there is any australian stores with Sportsline in stock, i have just ordered from Eibach Australia and they have said 3 weeks until they are in australia.
Also if anyone who has these fitted, what are you thoughts on camber bolts ??
-will i need them
-what do they do
Also i have been looking at some Spacers for the rear to give it abit more poke.
-can i do this?
Im running 18x8.5 +45 all round
Thanks
JimmyCrez is offline   Reply With Quote
Old 05-09-2013, 02:06 AM   #205
ilpad
ilpad's Avatar
Drives: 2013 - Scion FR-S in White"red"out.
-will i need them
-what do they do
-can i do this?
Thanks
I was able to align my fronts without any additional products. I wanted -2.5" of camber for my rears and that happens naturally with the sportlines, so i didnt have to do anything in the rears either. I got 1.6 inches of drop both front and rear. My springs didnt settle at all and are the same now as they were after my first rally around the block. Im running 18x9.5 e38 with 255/35s square all around and have zero rubbing. The ride isnt like stock contrary to popular belief tho. I like it much better than how my stock setup felt. Much tighter and much more aggressive. Hope that helps.
ilpad is offline   Reply With Quote
Old 05-13-2013, 01:53 AM   #206
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
I am having a hard time figuring out what springs or coils to get for my girls FRS. She wants a aggressive drop something like the Eibach SPORTLINE. But does not want the harsh ride it gives. She dos not mind a little stiffer. She also wants to do track HPDE events and perhaps some auto x for fun but nothing very serious. So I am not sure what can achieve the low look she wants while having a comfortable ride. We were looking at the pro street coil over and the R1 kits.
Sorry if somebody already asked this question and i missed it.
clayrush is offline   Reply With Quote
Old 05-18-2013, 09:54 PM   #207
JimmyCrez
Thanks man, helped a lot would you be able of post pics of rear camber ?
Old 05-20-2013, 04:18 AM   #208
ilpad
ilpad's Avatar
best shot i had access to atm.
as you can see the rear tires tuck in sooooo perfectly. If you want to see what it looks like on an extreme drop, check out @636 's build thread. Same setup as me but running a much more aggressive drop.
I do prefer the cambered look in the rears as well even tho a lot of our people prefer very little. I may even look into adding some camber to my fronts and reducing the current poke i have.
Old 05-20-2013, 03:27 PM   #209
636
636's Avatar
Drives: '23 CWP BRZ
Yeah, I'm running -3.5 degrees in the rear, if I had a 10mm spacer it would be gorgeousssss.
636 is offline   Reply With Quote
Old 06-03-2013, 06:55 PM   #210
ethanzhang
Drives: blue BRZ
Tein coilover
Hi there. I just got new street flex coilover on my Brz. I just wanna ask what is the best height for this coilover?
ethanzhang is offline   Reply With Quote
brz aftermarket coilovers, brz aftermarket springs, brz coilover, brz coilovers, brz lowering springs, brz springs, brz suspension, fr-s coilover, fr-s coilovers, fr-s lowering springs, fr-s springs, fr-s suspension, frs coilover, frs coilovers, frs lowering springs, frs springs, frs suspension, scion fr-s coilover, scion fr-s coilovers, scion fr-s springs, subaru brz coilovers, subaru brz foru, subaru brz forums, subaru brz springs
Adjustable shocks+ springs vs Coilovers CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 06-08-2013 04:59 PM
Canadian FR-S options VS U.S.A's options? Tino Scion FR-S / Toyota 86 GT86 General Forum 15 11-06-2012 11:07 PM
coilovers or springs? koyv90 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 04-01-2012 09:49 PM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 02:11 PM
Subaru BRZ different suspension / springs tuning ahausheer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 12-06-2011 01:52 PM
