#15 |
DADA
Drives: 2013
Oh lord Jesus, warm air from vents!!
Ain't nobody got time fo that |
#16 |
Drives: Raven Black
Every single car I have ever owned has done this.
two ways to solve the non-issue: 1 - turn your air temp knob all the way to the cold/blue side 2 - turn on the air recirculation |
#17 |
Ontario's FT86
Drives: 2016 Lexus GS-F
no disrespect but have you ever driven a car before? Your own car? Parents car?
EVERY CAR IS LIKE THIS |
#18 |
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
When you consider the outside air is ducting through your engine compartment (which is hot) you're not too likely to get cool air even if your temperature dial is turned all the way down. Hit the button on the left dial to close off outside air and/or turn on the a/c.
#19 | |
Drives: Raven Black FR-S
you don't even have to turn the fan off, just switch the cold and hot knob and you're good to go. I don't think is an "issue" i see it as free air hehehe... Why waste gas on A/C? |
#20 | |
Drives: Supercharged Golf Cart
#21 |
Drives: Whiteout FR-S
I've noticed this car even if using the vents on cold air on a semi cold day the air is still hot/warm. Never had this with my civic. Wondering if its due to engine bay design.
2013 Ford Focus St
2013 Scion FR-S 2007 Honda Civic Si 2003 Acura RSX Type-S 1998 Ford Escort ZX2 |
#22 |
Drives: 2013 Whiteout FR-S AT
My FRS does this too, even with the temp setting all the way in the blue for cold. This definitely is not normal as the air is pretty warm, none of my previous cars did this. Doesn't bother me too much though.
#23 | |
Señor Member
Drives: white BRZ 6MT
funny, I just found this out too last week. but it seems that hitting the reciculate button works ok for me
#24 |
Drives: Raven Manual FRS
All toyotas do this. Leaving the recirculation button off allows air to come in from outside. If the temperature knob is set to warm, then you get slightly warm air. If it is set to the cold side, then you get cooler air that is closer to the outside temp.
People can't really be this dumb, can they? |
#25 |
First 86
Drives: Scion FRS Argento Automatic
Bunch of whiners. I owned a 66 VW bug with NO vents. If it was hot you opened the little window vent or just rolled down the window if it was really hot. In cold weather you just plain froze your ass.
Life is short...NO BORING CARS |
#26 |
Drives: FR-S MT
Putting recirculation on is not a solution, not only will the air become stale, but humidity builds up in the cabin and eventually fogs the windows.
#27 | |
Drives: FR-S 6MT
after the car has been running and then off.. the ducts get heated up by the engines heat nearby.. so when you enter the car again and the fan is on or the outside air flows thru the vent.. you feel the heat built up coming thru.. this is not a lexus and is minimal on noise and temp isolation materials.. |
#28 |
i've noticed this annoying problem too. Never had this on my past two Civics. Post #11 does NOT work. its prolly a design flaw.
| Warm Up? | gt865 | Scion FR-S / Toyota 86 GT86 General Forum | 71 | 09-17-2014 11:28 AM |
| Want to trade my BRZ fender vents for you FRS fender vents, or buy FRS vents outright | ill roller | Exterior Parts (Aero, Lighting, Etc.) | 6 | 09-22-2013 10:49 PM |
| Want to Trade: My Whiteout FRS Fender Vents for the SWP BRZ fender vents | DC-FRS | Exterior Parts (Aero, Lighting, Etc.) | 15 | 11-01-2012 11:41 PM |
| a thought about the warm air coming from the vents... | pr086 | Scion FR-S / Toyota 86 GT86 General Forum | 32 | 08-02-2012 10:06 AM |
| Warm vs cool Weather performance | EsoBOFH | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 07-10-2012 11:45 AM |
