#71 | ||
Matt Engineering |
| The Following 2 Users Say Thank You to GrimmSpeed For This Useful Post: | chanomatik (04-16-2013), tripjammer (04-16-2013) |
#72 | |
Drives: Skoda Yeti DSG diesel 4x4
How about costing it in alloy and steel at an early stage so you don't need to have 2 sets of design parameters, to judge the response? The difference in weight might not be large but it's there for the life of the car in fuel consumption, acceleration, braking and handling. Surely it's not twice the price? For another car it might not be important but this one is light and nimble and deserves to be given true fuction over form, not a compromise to save a few dollars in the short term. A great option in alloy would be polished, black or a combo. I particularly liked the machine finish on the strut mountings in the pics I posted. My choice would be that with a black tube. |
#73 | |
In the design of a bar like this, we're most concerned with stiffness, not strength, since a bar that's stiff enough for our needs will certainly be strong enough. When we talk about material selection with stiffness as a primary goal, we compare the modulus of elasticity, not the yield strength. The modulus of aluminum is around 10 million psi, while steel is around 30 million psi. What this means, roughly, is that for a standard structural shape (a round tube, in this case), for the same limit of bending with the same load, the aluminum tube will require a wall thickness that's around 3 times as great as the steel tube. Now, steel is roughly 3 times heavier than aluminum. So, you can see that comparably stiff aluminum and steel tubes are actually, like I mentioned before, very similar in weight. We're talking did you finish your glass of orange juice this morning or not weight. Of course, this is pretty general, but you get the idea. You'll see some finite element analysis that we've done later on and that might help make things more clear. Matt Engineering |
| The Following 2 Users Say Thank You to GrimmSpeed For This Useful Post: | mottor (04-16-2013), tripjammer (04-16-2013) |
#74 | |
Maybe i'm just yearning after some to play with again? So much sexier than steel. How about using high tensile steel? It's up to six times stronger than conventional steel. http://www.thetruthaboutcars.com/201...ght-and-money/ |
#75 | |
:happy0180:
2013 Asphalt FR-S 6MT - Perrin 2.5" Catback Exhaust - Grimmspeed Strut Tower Bar - Grimmspeed Master Cylinder Brace
Grimmspeed Hood Struts - Grimmspeed 86 Oil Cap - Grimmspeed Boxer Battery Tie Down - HID - Pioneer AVH-X5500BHS - Infinity Basslink 10" Sub |
| The Following User Says Thank You to mottor For This Useful Post: | GrimmSpeed (04-16-2013) |
#76 | |
Seriously though, more exotic alloys would incur a significant cost increase, at again, little to no performance gain. Aircraft structures often do use steel, but only in places where manufacturing methods or cost prohibit other materials. Having worked in the defense/aerospace industry, I can tell you that those folks work with a budget that normal people like us can't even comprehend. You should look up a photo of 787 wing deflection testing. Matt Engineering |
#77 |
USMC Veteran Semper Fi
Drives: 2010 WR Blue STi
I've read the thread and a couple of questions come to mind.
#78 |
Klaatu barada nikto
Drives: Raven FR-S MT
Just found this thread. How did I miss it?
First off... every piece I have purchased from Grimmspeed has been top notch. The hood struts are FAR superior to any others I have seen in action. Also the Master Cylinder Brace really surprised me, I DO notice a difference under hard braking. I did some Pre and Post-install testing. Great feel at the limit. (Not a placebo effect) So... I trust your engineering methods. I have NO engineering background, so I won't comment on the design. So what can I add for input... I think we all have the same goals here. Function over form, allowance for use in different race series, and the lowest weight that is cost effective. I am a weight freak, and wouldn't mind spending an extra $10-20 for it to weight a little less. I would like to see one tower to tower bar, with an option for matching tower to firewall braces. Can this be done at low cost, and low weight? Esthetics. Looks shouldn't matter right. But, all of you know that they kinda do. My Grimmspeed oil cap and battery brace look awesome. The red cap on the MCB looks kinda cool too. But, I didn't put the stickers on the hood struts because I have nothing gold under my hood. I really like the metal sticker concept. I think it's a great idea, but I would really, REALLY like it to be consistent across your product line. Red and silver, optional placement, metal sticker, on a flat black bar for me please. If a group buy comes about... you can add me without question. :happy0180:
I vow to do no harm. 2013 Raven FR-S Manual "Lenore" 1985 Silver RX-7 GSL-SE (Gone and missed) |
#79 | |
I posted the pic of the JDM bars because I thought it was interesting and Grimmspeed have asked for feedback. If they could make something like that for $250 instead of $450? I would buy it. |
#80 | |
2. Not extra 100 dollars just for looks. You actually just want the password JDM item to be cheaper. I don't think that is what grimspeed is about. |
| The Following 2 Users Say Thank You to s2d4 For This Useful Post: | chanomatik (04-16-2013), civicdrivr (04-16-2013) |
#81 | |||
Matt Engineering Last edited by GrimmSpeed; 04-16-2013 at 06:02 PM. |
| The Following 5 Users Say Thank You to GrimmSpeed For This Useful Post: | chanomatik (04-16-2013), civicdrivr (04-16-2013), s2d4 (04-17-2013), Slartibartfast (04-16-2013), tripjammer (04-19-2013) |
#82 |
Since at least one forum member and maybe more have snapped off the nut from one of those studs, what are those 2 studs made from? If you stick your finger up under the bracket you will feel that those 2 studs do not have a 6 sided bolt head, it's more like a stud glued to a dime (to try and explain it in common terms). I don't believe those 2 studs have much strength to them and while it looks like an aesthetically clean installation, I have serious concerns as to the strength of those 2 studs (plus they're attached to a small welded on bracket and not the strut studs).
#83 | |
I want to say again that these studs were designed to handle the forces from the stock triangulation bars, and were definitely designed with a certain safety factor, and I can almost guarantee it's greater than 2. Unfortunately without knowing the grade of the studs I can not calculate the ultimate tensile strength, but I can rely on our own testing with our prototype. If nothing else, I'd like the note again that the engineers at TRD (who would have access to this information) have elected to using the same mounting points in their strut bar. And to reiterate, the initial deflection data that we've shown is from our car, and is measuring deflection at the strut mounting studs with and without our prototype strut bar. To say that the "small welded bracket" is not influencing the struts directly is debunked right there. Even though the bracket is made out of sheetmetal it is important to keep in mind that it has a substantially higher equivalent strength over flat sheet metal due to its three dimensional shape. We'll continue testing, but so far we're not concerned with the shear strength of the studs ![]() Here's a few shots of a quick prototype from yesterday. What do you guys think about the brackets? What would you change? ![]() ![]() Chase Engineering Last edited by GrimmSpeed; 04-17-2013 at 11:56 AM. |
| The Following 2 Users Say Thank You to GrimmSpeed For This Useful Post: | F1point4 (04-17-2013), tripjammer (04-19-2013) |
#84 |
The previous prototype bracket had a solid support on the front side. Do you find that it is equally as strong with the cutout? Also, is there any benefit to be had by using this support on the face of the bracket instead of alongside it?
| Anyone using the STi Flexible Strut Tower Brace? | ngabdala | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 45 | 08-15-2019 01:59 AM |
| F/S Beatrush Strut Tower Brace Type-2 $175 | Dan-in-Japan | Brakes, Suspension, Chassis | 2 | 02-24-2013 01:38 PM |
| FT-86 SpeedFactory Strut Tower Brace Review | F1point4 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 35 | 01-07-2013 04:31 AM |
| DIY - Strut Tower Brace - FT-86 SpeedFactory | F1point4 | DIY (Do-It-Yourself) Guides | 4 | 10-28-2012 04:30 PM |
