Old 04-15-2013, 07:20 PM   #99
CSG Mike
CSG Mike's Avatar
Originally Posted by Hanakuso View Post
I just ordered the Eibach R2 with off the shelf springs. I'd like to do a comparison vs the SRC for the sake of this forum but not really sure how to do so. If it was between your car and mine, they have similar parts but the two biggest things would be the alignment and my stock tires.
Then again i'm planning on getting an alignment at Westend but not sure if you want to share your specs and i'm not sure if I want such an aggressive alignment.
Currently -3.0 front, -2.4 rear, 0 toe all around. -1.4" drop; rear camber was attained via drop only.
I don't think West End will allow you to walk out with that alignment though... (it's a "loose" alignment and they won't do it for your safety, unless they know you're experienced and/or you absolutely insist)
We'd be more than happy to put our tires on your car for testing to remove that variable.
Hanakuso (04-15-2013), sittinSideways (11-05-2014)
Old 04-16-2013, 03:35 AM   #100
trdfrs
Drives: 13' asphalt 6mt, 91' Beams Mr2
Eibach has made trd suspension parts for over 20 years!
trdfrs is offline   Reply With Quote
Old 04-22-2013, 01:35 AM   #101
mtsui
Drives: 135i
anyone know what is the springs rate on the R2?
thanks
mtsui is offline   Reply With Quote
Old 04-22-2013, 01:44 AM   #102
ayau
Drives: Some rust bucket
thanks
They come with 275 front and 350 rear.
The Following User Says Thank You to ayau For This Useful Post:
mtsui (04-22-2013)
Old 04-22-2013, 10:44 AM   #103
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
We're running -3.0 front, -2.6 rear, 0 toe all around, -1.75" drop front, -1.4" drop rear.
Once we got the real bump dialed on the clubsports, the car handles loose, but is very controllable for an experienced driver. We'd recommend some toe in on each side to help stabilize the car. We're hoping to settle the car down a little with spring rates.
GTM_Challenge is offline   Reply With Quote
The Following User Says Thank You to GTM_Challenge For This Useful Post:
Old 04-22-2013, 11:54 PM   #104
mtsui
Drives: 135i
is it hard enough for track use? it seems like too soft?
Old 04-22-2013, 11:58 PM   #105
OrbitalEllipses
Drives: Attitude
Like I said...get the 25kg fronts and the 19kg rears.
Old 04-23-2013, 01:13 AM   #106
ayau
I got 500/650 springs for R2. I'm sure the stock 275/350 rates will be fine at the track.
Old 04-23-2013, 01:17 AM   #107
robispec
Drives: Black frs project
fine for going slow...lol
robispec is offline   Reply With Quote
Old 04-23-2013, 01:23 AM   #108
ayau
What rates are you running?
Obviously your suspension is completely different than OEM, but just curious.
Old 04-23-2013, 01:32 AM   #109
robispec
modified KW's higher hydralic compression resistance and the front springs are 7Kg rears 8Kg these are on a car 250 lbs lighterwith a 3" lower cg and raised roll center so we dont lean over and keep the weight more equally distributed on the 4 corners than stock...and imo they are right at the limit of how soft you can go
The Following User Says Thank You to robispec For This Useful Post:
ayau (04-23-2013)
Old 04-23-2013, 04:00 AM   #110
mtsui
Drives: 135i
you try that
The Following User Says Thank You to mtsui For This Useful Post:
wootwoot (09-14-2013)
Old 04-23-2013, 09:13 AM   #111
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Jackson what kind of pricing are we looking at for the R2's with springs. Is there a "homie hook up" price for form members? I have friends in the industry and I am almost positive I can get a sweet deal on these. Feel free to PM me a response if its too sensitive. Thanks yo.
TouchMyHonda is offline   Reply With Quote
Old 04-23-2013, 11:42 AM   #112
Jackson
Jackson's Avatar
Drives: E46 M3 (daily) / EG Civic (track)
I would recommend going through one of the forum vendors or people you know that can get these. The pricing will really vary and the MSRP price almost means nothing when you start getting quotes or shopping online. Also, we don't sell direct at Eibach and have to send people to our distribution and dealers.
If you have any questions just PM me.
Jackson is offline   Reply With Quote
Eibach Multipro R1 and front and rear sway bar installed Pekingduck Suspension | Chassis | Brakes -- Sponsored by 949 Racing 43 12-30-2013 10:59 AM
AST's at buttonwillow raceway Matt Andrews Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 07-02-2013 03:16 PM
◙◙◙ [NY Local] SPECIAL on Eibach Sportlines Installed | Real Auto Dynamics ◙◙◙ Kevin@RAD Announcements, Contests, Giveaways 48 06-07-2013 02:19 PM
Buttonwillow Track Day Heads-Up sv_dave Southern California 3 09-08-2012 09:20 AM
