Old 04-12-2013, 10:21 PM   #1
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Quad projectors and Quad halos
So one of the ladies in our vegas86 club and also one of the first 86 owners, asked me if I could retrofit her headlights because she liked my retrofit. Also like the halos on my car and on the other members cars I've done. We got to talking and she asked me if I could do a quad projector and quad halos, I said sure. Called up my source at TRS and ordered up the quick retrofit for the main projectors and the matchbox for the high beams.. I also ordered up the 90mm halos and 60mm for the high beam.. She really wanted to stay chrome housings so making this easy and blacking it all out wasn't an option.. I also hooked up the bi-xenon on the low beam projectors to assist with the high beams.. I removed the actuator of the high beams because that's all they will be used for. I wired all the halos up to be used as daytime running lights and with the relay harnesses installation was cake.. So on to the pictures
We decided to paint the inner high beam housing as the reflector was reflecting the cast aluminum of the projector housing and we both agreed it didn't look that great
Gixxersixxerman is offline   Reply With Quote
Old 04-12-2013, 10:22 PM   #2
Gixxersixxerman
This was just testing the halos
Old 04-12-2013, 10:26 PM   #3
Gixxersixxerman
Everything lite up
So halos only
[IMG]http://i305.photobucket.com/albums/nn239/gixxersixxerman/fdd8b9d4f1dcc8575a578c014dae0209_zps37b1***7.jpg[/IMG]
Low beams
And high beams
Old 04-12-2013, 10:36 PM   #4
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
husker741 is offline   Reply With Quote
Old 04-12-2013, 10:59 PM   #5
DIM
That looks fckin awesome. I think it'd look ALOT better blacked with some chrome accents.
DIM is offline   Reply With Quote
Old 04-12-2013, 11:03 PM   #6
jazztennor
jazztennor's Avatar
Drives: Scion FR-s
looks crazy cool!!!!!!
jazztennor is offline   Reply With Quote
Old 04-12-2013, 11:07 PM   #7
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Awesome Job! Looks amazing...
Wish I had the time and patience to do this mod, referring to the halos
I'll ship my headlights out to you asap j/k
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 04-12-2013, 11:13 PM   #8
Pin Flare
Luna
Pin Flare's Avatar
Drives: 2016 FRS Release Series 2.0
Wow. @Gixxersixxerman
I need to fly you out to do mine!
2016 FRS RS 2.0 #347 of 1000
2013 SCION FRS DEAD AND GONE THANKS TO A FLOOD.
Pin Flare is offline   Reply With Quote
Old 04-12-2013, 11:15 PM   #9
Pin Flare
Luna
Pin Flare's Avatar
I'm kinda diggin the chrome headlights. Everyone to include myself is goin all black but that's different and looks great. She has a great taste in mods!
Old 04-12-2013, 11:18 PM   #10
Trashed675
Trashed675's Avatar
Drives: 2013 Ultramarine FRS
How did you get the hi beam projector to stay put?
Trashed675 is offline   Reply With Quote
Old 04-12-2013, 11:21 PM   #11
Gixxersixxerman
She is thinking of going bronze, I tried talking her into white.. Like the old Ferrari f50 in red when they painted the housing around the light the same color.. We was going to go black if needed, but she really didn't want to..
Old 04-12-2013, 11:24 PM   #12
Gixxersixxerman
They have a threaded housing.. You can see it in this picture, a nut and washer hold it in place
It's the one laying on the table
Also they just don't bolt in.. I had to spend quite awhile with my dremel cutting the housing and widening the socket on the stock housing
Old 04-12-2013, 11:44 PM   #13
jlu
jlu's Avatar
Drives: Asphalt AT FR-S
o_O
Beautiful!
Although I might not want to be on the other end of that :P
jlu is offline   Reply With Quote
Old 04-13-2013, 12:24 AM   #14
Gixxersixxerman
Originally Posted by jlu View Post
o_O
Beautiful!
Not with the brights on.. Hell no.. It's almost painful.. With just the lows, it's like any other projector hid setup.. Insane amounts of light down low, but nothing above the cut off..I'm a little.. And I mean a little disapointed in the right projector, out of all my retrofits I've never had a bad one, but this projector has a hot spot down a little low.. The spot should be just under the cutoff preferably right at the point in which it angles down.. This is a little low
You can see where it should be on the left projector in this picture
And with the high beams on
Again, you can see the spot a little low.. I'm going to call TRS and see if it can be fixed, adjusted, or if I need a new one
Quad exhaust tips? migle Engine, Exhaust, Transmission 86 09-23-2020 11:45 PM
J2 Quad catback exhaust? bcmakesiteasy Engine, Exhaust, Transmission 22 06-01-2015 03:43 AM
quad tips project d CANADA 6 10-03-2013 02:43 PM
TRD Style Quad exhaust Nafe AUSTRALIA 17 05-11-2013 02:13 AM
Quad Exhaust Lip? Neekowahhhh Scion FR-S / Toyota 86 GT86 General Forum 4 12-17-2012 08:49 PM
