Old 04-12-2013, 06:28 PM   #1205
FR-S Matt
Originally Posted by peace_noel View Post
are you guys going with the 2.5" or 3" exhuast?
3" so I'll be ready to turbo a year or so down the road. Going full 3" so I can just swap to a turbo without changing anything else, just modifying the header from NA to FI.
Old 04-12-2013, 06:37 PM   #1206
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
How about muffler? 4" or 5"
Old 04-12-2013, 11:07 PM   #1207
FR-S Matt
5" because the header is going to make it tons louder. Go 4" if you plan on sticking with the stock header. There's a great description on the site about the difference between both.
Old 04-13-2013, 01:59 AM   #1208
StOpNG0x
StOpNG0x's Avatar
Drives: Firestorm MT FR-S
I tried to find the answer to a question I have in the 50+ pages in this thread, but apparently I missed it so... What's the deal with the offset axleback versus the non offset? Can someone link me to the one I need to get? Or tell me so I don't get the wrong one...
I'm assuming the majority of people are going with the 2.5" 4 inch mufflers?
I apologize if this is a repeated question.
Thanks for the help,
Rob
StOpNG0x is offline   Reply With Quote
Old 04-13-2013, 07:05 AM   #1209
FR-S Matt
Rob
Straight from the Nameless site:
4" Mufflers: These are our hand built mufflers with 4" outer diameter and 8" length. They are center inlet, center outlet and are constructed entirely from T304L Stainless Steel right here in our facility by our crack team of fabricators. The sound of these is less than the muffler delete but greater than the 5" mufflers. This option is the best for those who like a bit of volume to their exhaust but don't want the "race car" noise and are not planning to upgrade other portions of the exhaust. This option is also suitable for those who like a loud exhaust and are planning on upgrading their downpipe or their downpipe and overpipe.
5" Mufflers: The dimensions of these hand built mufflers are 5" diameter with a body length of 8" and offset inlet/outlet. These mufflers are the best option for a nice smooth exhaust note. The tone is nice and deep with volume being mellow with stock exhaust otherwise. When you decide to upgrade to an aftermarket downpipe or overpipe/downpipe combo, this exhaust really comes alive while remaining deep and smooth sounding. This axleback even keeps the volume down at a tolerable level with our catless header.
Off-set = deeper tone
Non Off-set = louder, less deep tone
4" mufflers with a header may introduce some unwanted sounds.
Old 04-13-2013, 09:39 AM   #1210
Noob4Life
86 Noob
Drives: Firestorm FR-S
Originally Posted by russv View Post
Just curious if you installed it yourself or had a shop do it. I live in Yuba City as well and am thinking of getting the Nameless exhaust. If you had a shop do it which one did you use. Thanks in advance. Exhaust looks sharp.
easy as pie. Two bolts and 30 minutes later the exhaust was installed lol if you look under the rear of your car you will see how easy it is.
Noob4Life is offline   Reply With Quote
Old 04-13-2013, 11:00 AM   #1211
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
Thanks. I'm really liking the sound. How many new bushings did you use? I'm looking at getting the 5 inch mufflers. Maybe I'll run into you in YC. Are you going to the event in Livermore?
Life is short...NO BORING CARS
russv is offline   Reply With Quote
Old 04-13-2013, 11:04 AM   #1212
mad_sb
Drives: 2013 Asphalt FR-S
Yup, just be sure to clean off the old gasket material at the end of the stock midpipe before you install the Nameless axle back. Silicone spray or soapy water to get the hangers loose. An extra pair of hands makes it easier but i did it myself without a jack in less than 30 minutes.
Old 04-13-2013, 11:06 AM   #1213
mad_sb
I put the stock hangers back on. I ordered 4 urethane hanger bushings but found they added vibration to the chassis at a few rpm points so i swapped them all back to stock after one drive. Honestly it does not move much at all with the stock bushings... I don't think the urethane ones are needed at all.
Old 04-13-2013, 11:27 AM   #1214
Noob4Life
86 Noob
I just used the stock bushings and theyre fine for me for now lol nah havent heard of the livermore event? Havent seen much in the norcal forums for us up north. Yeah maybe, I work graveyards so im not up during the day too much lol
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
Old 04-13-2013, 11:54 AM   #1215
russv
First 86
russv's Avatar
Here's the link: http://www.ft86club.com/forums/showthread.php?t=33196
Went to a similar event in Novato last November. Lots of interesting cars and people.
Old 04-13-2013, 12:22 PM   #1216
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
So if I order the exhaust from nameless I basically don't need their new bush just use the stock ones will be fine?? Correct?
Old 04-13-2013, 12:41 PM   #1217
mad_sb
They are not required. You can re use the stock ones. If you want to limit side to side movement you can order either 2 or 4, just be aware they may introduce some additional vibration.
Old 04-13-2013, 12:51 PM   #1218
russv
First 86
russv's Avatar
Also just want be clear that there won't be any warranty issues with the axle back. I think I read in these forums tat there shouldn't be, but my confidence in my dealer to be up on warranty policies is pretty low.
BRZ performance driving demo - looks great Oriental Life BRZ Photos, Videos, Wallpapers, Gallery Forum 26 04-11-2012 02:20 AM
What type of performance parts will you be looking to buy first? bFreed Engine, Exhaust, Transmission 12 11-09-2011 05:51 PM
Performance automatics madfast Engine, Exhaust, Transmission 118 08-25-2011 03:26 AM
FT-86 Article on Performance magazine 4agze Scion FR-S / Toyota 86 GT86 General Forum 7 01-09-2010 11:33 AM
