#29 | |
Does the ECU have a oil temp reading that we can log? |
#30 |
#31 |
Pepe Le Pew Wannabe
I use water wetter in my two wheeled track toy(certain events don't allow anti freeze in the bikes on the track, in case you spill some when crashing!). It's fine as long as you keep it in a heated garage during the winter. If you use it in your car and you live in a cold climet, you run the risk of freezing you water wetter, it's not much good below freezing.
My middle age crisis started prematurely… at 16!
I'm also independently very, very..... dependent! |
#32 | |
Drives: Raven Black
Using it in the track bike is what gave me the idea to suggest it to the OP. |
#33 | |
Drives: N/A
See this thread http://www.ft86club.com/forums/showthread.php?t=23530& |
| The Following User Says Thank You to 96z2 For This Useful Post: | WillRacer1jz (04-13-2013) |
#34 | |
![]() I just sold my Nexus 7
#35 |
Drives: Asphalt frs
Anyone know what normal coolant Temps should be? I've been hitting around 197°f easily just driving about 25 miles to work it is Tc just trying to get a basic idea of what Temps you guys usually see.
Sent from my SM-G935T using Tapatalk |
#36 |
Drives: Velocity Orange 86 GT
Normal temps like most cars will be 88-90C On the track I'm yet to see over 105C on the hottest of days.
#37 | |
On the street, my coolant temps hover right around 190-195 F.
2022 BRZ Build 2013 FR-S Build |
| The Following User Says Thank You to DarkSunrise For This Useful Post: | SoCal80six (04-30-2016) |
#38 | |
Chin Track Event Manager
Drives: 15 Series Blue
Jim Pomroy Chin Track Days Event Manager.
15 Series Blue in white 18 Golf R 09 Comp Yellow NC 20 Gladiator tow vehicle. |
#39 | |
If you're getting over 105C/221F, then I'd be worried. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | SoCal80six (05-01-2016) |
#40 |
Drives: Asphalt frs
#41 |
Drives: 2014 Silver BRZ Track Car
Track water temperatures
I will pitch in for the first time in these forums because I have learned a great deal about this topic. I tracked my BRZ naturally aspirated for over 10,000 miles in many race tracks around our Country. I regularly instruct with a number of clubs so I drive my car really hard. I have been using factory coolant all along.
In naturally aspirated form I never had any issues with stock radiator and fans. Never saw the water needle past the middle position. I ran a flex-fuel Delicious e-tune and I had factory exhaust all the way. The oil cooler did not really affected in any way the water temperatures by blocking some direct air flow through the radiator. I installed a Jackson Racing C-38 Supercharger a few months back along with a ceramic coated header and no cats all the way back. I am running 93 and it is making 275 WHP and 225 ft-lbs peak torque. The water temperatures increased immediately up to 220 F (the needle will be around 3/4 tot he right between half and hot). I took 8 directional improvement to the cooling system after SCH due to the heavy track duty. 1) Veloxi hood louvers. 2) Koyo racing Radiator. 3) Mishimoto racing fans with aluminum housing. Re-wired fans to run wiring through the top and not the bottom of the fan shroud to get them away from the header pipe. 4) Mishomoto higher pressure cooling cap with aluminum housing. 5) Perrin aluminum overflow bottle. 6) Mishimoto racing thermostat. 7) Perrin cooling hoses all around 8) Besides the ceramic coating in the header and pipes, I heat blanketed it all since it runs very close to the right fan. All of these combined have kept my water temps just fine in 95+ F track days for the last 4000 miles. A week ago we triple stinted my car the whole day. It ran perfect. Out of the three drivers I am the one that drives it significantly harder and even for me the water temp stayed in the center all day. I do not even log temperatures anymore since water temps are a non- issue. We always blow the heater full blast on the passenger side while on track and that seems to help. With mandatory open windows in most HPDE clubs this is not an issue. I have been doing this since the supercharger and full flow header and exhaust was installed. If you only run in the street and even perhaps for Autocross, you really do not have to do anything like I did. If you beat the car in the track as hard as I do, you have to take care of it like I did. The fact that you have a charge air cooler, an oil cooler and a supercharger oil cooler in front of the radiator certainly affects and limits air flow through the radiator regardless. Our cars already have a limited air flow by design. Try comparing the front to a Mitsubishi EVO for instance. Ideally, I would love to see a water inter-cooler under the hood or perhaps a dual side to side charge air cooler setup for the supercharger instead of the front mounted charge air cooler blocking the radiator. I hope this is helpful folks. UPDATE on 2/22/2017: My engine blew up back in October in my last track day of 2016. As always before anything blows, it was running great when all of a sudden, oil in the windshield and flames shooting at me through the hood louvers accompanied by 5 minutes of postmortem smoke. Car did not had a thermal event because I actually blocked the louvers with the weathertec mat from my trunk. Autopsy revealed 2 rods poking through the block. All I am going to say is that I am already running in a brand new 2017 long block (With improved pistons and valves) along with my always faithful and reliable NA e85 delicious tune that gives me more torque than I had with the supercharger coming out of any turn and actually gets me faster around any race track (I have proven it and documented it in 6 different race tracks and it is simply due to no low end torque supercharger parasitic losses). I guess all the cooling improvements I did and mentioned in this thread will stay for added capacity except the Mishimoto thermostat that I reverted to factory. I added a swayne coating into the equal length headers and I also had to add a Jackson Racing oil cooler and re-install the factory air box with a K&N filter since these parts were parted when I sold the supercharger kit. Many theories came about my problem but the one that really stuck in my head was that I was told my tune was bad... (Really, 2 different tunes one being dyno developed, I highly doubt it). At the end of the day and the main reason I came back here to tell whomever wants to listen, I could not keep the water as cool as it was in naturally aspirated form and I damn tried. It evolved into very high engine coolant and oil temperatures that in terms contributed to the engine failure. The FA20 is a very strong motor and it takes a lot of abuse to blow it like this. Moral of the story, if you track your car as heavily as I do, think twice blocking the front of your radiator with anything bigger than an oil cooler. If you force induct it, try other means of charge air cooling it but DO NOT BLOCK THE RADIATOR. Think of the WRX and STI from factory. My 2 cents. Last edited by AndyBRZ; 02-22-2017 at 08:12 PM. Reason: CHAIN OF EVENTS |
#42 |
Drives: 2005 Toyota Camry
| HKS Oil Cooler Kit - Keep those oil temps down. - Photos | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 23 | 08-10-2015 03:08 PM |
| Muffler delete pipe = extreme temps at tailpipe?? | twincamRob | Engine, Exhaust, Transmission | 39 | 07-02-2013 08:12 PM |
| summer or all-season tires? freezing temps? | rainmonkey | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 04-07-2013 01:11 PM |
| Normal Engine Coolant Temps? | Dezoris | Engine, Exhaust, Transmission | 1 | 04-05-2013 03:17 PM |
| ECU pulls timing at high oil temps? | brillo | Engine, Exhaust, Transmission | 24 | 03-31-2013 09:10 PM |
