Old 04-12-2013, 05:36 PM   #1
so26
Drives: Raven FR-S 6MT
ramps + jack stands
So I'm going to change my trans. and diff. oil this weekend but I only have a pair of craftsman jack stands. So I was planing on backing my FR-S up onto my two rhino ramps (engage the e-brake) and then place the front of the car on the two jack stands.
Have any of you guys tried using ramps in conjunction with jack stands before?
so26 is offline   Reply With Quote
Old 04-12-2013, 05:44 PM   #2
Hanakuso
If you do that, make sure you choke the wheels. Someone on the s2ki forum died from a similar incident. I never did it, but I believe you roll your front on the ramps with wheel chokes and use stands on the rear. Not sure if there's a difference in direction tho.
Actually sorry, I just read you're doing the trans/diff fluid swap. That's a bad idea because you want the surface to be close to being flat as possible, so use 4 jack stands.
Hanakuso is offline   Reply With Quote
Old 04-12-2013, 05:49 PM   #3
fender9530
fender9530's Avatar
Drives: Asphalt FR-S
I've done it but was always very cautious. Just go buy 2 more jack stands.
fender9530 is offline   Reply With Quote
Old 04-12-2013, 06:15 PM   #4
cnk
Drives: '13 DGM BRZ Limited
I don't back the rear on ramps. I drive up on ramps on the front and jack the rear. If you back up the rear, you won't have enough room to get the jack under the front bumper with the angle. My ramps have a little ledge to prevent the tire from rolling backwards and I'm on level ground, but I would still stick a wheel chock under it on the ramps just in case.
Old 04-12-2013, 06:32 PM   #5
mrk1
Drives: Sterling BRZ Ltd
Always work on level ground. I drive the front onto ramps and then jack on the rear on to wheel cribs. I put chocks behind both front wheels and always use the parking brake and in gear.
Check out Race Ramps for some cool solutions, I use there stuff and they are great because they are super light weight so they are easy to move around and dont get in the way.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 04-12-2013, 07:16 PM   #6
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
[ame="http://www.youtube.com/watch?v=8Op2OgS8HBw"]Race Ramps - Using Your Ramps - YouTube[/ame]
The Following User Says Thank You to SloS14 For This Useful Post:
ftc~brz (04-12-2013)
Old 04-12-2013, 10:30 PM   #7
xwd
I'd just get another set of jack stands, thy aren't that expensive. Driving a RWD car up a set of ramps in front and jacking up the rear isn't a great idea.
Old 04-12-2013, 10:41 PM   #8
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
since we're on the topic of ramps, are those any good?
http://www.harborfreight.com/magnum-...ock-67722.html
I'm looking for a set of ramps but don't want to spend too much.
chenshuo is offline   Reply With Quote
Old 04-12-2013, 10:48 PM   #9
so26
Good point, didn't think about that.
I guess I'll just pick up another pair tomorrow (especially since they're on sale)
http://www.sears.com/craftsman-2-1-4...&blockType=G10
Old 04-12-2013, 10:55 PM   #10
so26
I agree that's way I thought about using the ramps on the rear but it looks like that wouldn't work either.
Old 04-13-2013, 01:51 AM   #11
cnk
For $5 more you can get these: http://www.sears.com/craftsman-3-ton...6&blockType=G6
I have them and they work great, plus there is a notch for the pinch weld to help you center it on the stand.
Old 04-15-2013, 01:30 AM   #12
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
This is not true, I've done this while changing my exhaust. You can put your car on rhino ramps and then jack the car up using a low profile racing jack.
I have a racing jack from harbor freight. it's great -- and you get clearance. Though I admit the clearance is EXTREMELY minimal, so be careful when you lower your car
CamryDS is offline   Reply With Quote
Old 04-15-2013, 02:21 AM   #13
cnk
Good to know although most people don't have low profile racing jacks. It would also depend on which Rhino Ramps you have as they do have different height ramps available. In the end, it's safer just to use 4 jack stands if you need to get the entire car in the air.
Old 04-15-2013, 12:22 PM   #14
CamryDS
That's true, though I guess I'm just lucky at that time.
$10 Jack Buddies blalor DIY (Do-It-Yourself) Guides 24 10-20-2017 08:16 PM
Recommended Car Ramps for the BRZ/FRS? mechaghost Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 49 09-01-2017 01:41 AM
Free Shipping on ALL Race Ramps Products @ JWM JWMotoring Mechanical Maintenance and Tools 5 10-04-2012 06:22 PM
The S in September stands for Suspension! Lots of Sales! KronosPerformance Brakes, Suspension, Chassis 8 09-13-2012 03:08 PM
Where ti jack car up at? skatery1989 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 08-13-2012 02:53 AM
