Old 04-12-2013, 12:45 PM   #1
subaruatheart
Drives: Whiteout FR-S
TCS Issue
Not sure where to put this. I recently had coilovers installed (alignment/corner balance coming soon), everytime for example I take a 45mph freeway roundabout at around 60ish mph my TCS would engage causing a vibration from I beleive one of the rear brakes depending on which direction of turn it is and the TCS light blinking. What could be causing this issue? Could this an an alignment/corner balance issue?
subaruatheart is offline   Reply With Quote
Old 04-12-2013, 12:48 PM   #2
CSG Mike
CSG Mike's Avatar
If it does it in one direction but not the other, then probably a corner balance issue.
If it's consistent in both directions, then its either the driver or the setup (spring rate choice, damper settings, alignment, could be a ton of things)
Old 04-12-2013, 01:42 PM   #3
celica73
something binding/a short shock topping out and picking up the inside back tire?
just throwing out ideas.
Old 04-12-2013, 04:06 PM   #4
Calum
That Guy
Drives: 2013 asphalt FRS MT
Stiff rear bar could be picking that inside tire to.
Old 04-12-2013, 04:33 PM   #5
celica73
Agree, but there is no good reason to run a stiff rear bar on these cars, aside from a desire to ruin the handling.
Now, if you dump the car, and have coilovers with short springs that unload at the first sign of droop, then the stock rear bar will probably pick up the inside tire. If the inside tire comes up, the Torsen turns into an open diff and the unloaded tire spins freely. Then, traction control engages.
Old 04-12-2013, 04:45 PM   #6
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
What coils? Too short droop travel + swaybar = picking up tire = TCS freaking out.
SubieNate is offline   Reply With Quote
Old 04-12-2013, 05:17 PM   #7
Calum
That Guy
Can't argue with any of that, I agree completely. The only reason I mentioned it was because I don't know what the OP has on his car.
Old 04-12-2013, 05:24 PM   #8
subaruatheart
Thanks for the inputs
Coils are Megan Street Series, I've talked to a couple of other users on this forum and they don't have this issue with Megan Sreet Series. Rear bar is stock. I also have SPC's adjustable LCAs installed. Dampers are set pretty stiff right now (7/32). My car isn't slammed, maybe a 1.6 inch drop at the most. I doubt anything is binding as my rim size and tire choice is pretty conservative (17x9 +30 225/45) besides the more aggressive offset. Well see, I have a feeling it's a alignment/corner balance issue which I already have an appointment to do.
Old 04-12-2013, 05:28 PM   #9
Trashed675
Trashed675's Avatar
Drives: 2013 Ultramarine FRS
225 on a 9 seems a little stretched to me
Trashed675 is offline   Reply With Quote
Old 04-12-2013, 05:42 PM   #10
subaruatheart
Just a little, didn't want to run into any rubbing issues with a wider profile tire, but still wanted the concave look on the rims.
Old 04-12-2013, 05:54 PM   #11
Calum
That Guy
You, Sir, get a big plate of cookies. 1 you lowered your car to get the look you wanted without being stupid about it and going too far. 2 you put the rims and tires on that you wanted, but made choices that would keep things safe while still getting the look you wanted. 3 you realized that you were going for a look, not just a performance gain, and that is awesome.
I'm not being sarcastic here, I really appreciate that you didn't try to sell this as a performance only setup and that you're proud of the fact that you got the look you went after.
The Following 2 Users Say Thank You to Calum For This Useful Post:
CSG Mike (04-12-2013), D1cker (04-25-2013)
Old 04-12-2013, 05:57 PM   #12
celica73
Are the springs loose if you jack up the rear (jack under the diff)? Now, jack from the side of the car, do you have a loose spring on the airborne side)?
Old 04-12-2013, 06:03 PM   #13
mad_sb
Drives: 2013 Asphalt FR-S
well, if you feel it start to rotate before the TCS kicks in then it's surely a setup issue (damper setting, alignment, spring rates). If not then the most reasonable explanation seems like lifting the inside rear just enough to open the diff.
I suppose it could also be one of the wheel speed sensors got damaged somehow.
Old 04-12-2013, 06:06 PM   #14
SubieNate
SubieNate's Avatar
Is it possible that your rebound damping in the rear is set too high and when you corner the wheel is slow to react and you're lifting for a short while before the wheel can reconnect with the ground?
If the compression on the outside rear corner is soft and the rebound on the inside is very stiff, the car could lean on the outside and pick up the inside even if the sways are stock. Some suspension setups can even get to the point where repeated hits cause the car to squat down because the rebound damping is so stiff that the wheel can't return to neutral before more hits come.
Nathan
the rev dipping issue pr086 Issues | Warranty | Recalls / TSB 27 05-05-2016 05:30 PM
Mud Guards, got them, put them on, have issue. michaelahess Cosmetic Modification (Interior/Exterior/Lighting) 14 09-11-2012 01:03 PM
Serious issue with FRS!!!!. _F-R-S_ Issues | Warranty | Recalls / TSB 16 08-28-2012 10:08 AM
Cel issue Z06tofrs Issues | Warranty | Recalls / TSB 2 08-27-2012 10:13 AM
Anyone having this issue? zoomzoomers BRZ First-Gen (2012+) — General Topics 11 08-09-2012 11:19 PM
