Old 04-11-2013, 04:48 PM   #15
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
Originally Posted by NoFear99 View Post
We are not talking about the same things.
You are refering to the sounds generator, the tube that goes from the intake box to the passenger side firewall to bring noise into the cabin for pleasure. With the Greddy / Takeda intake kit if you want to keep that functionnal, you have to drill a hole into the plastic connector...
Myself I was refering to the front snorkel that is located into the front bumper.
I want to keep the fresh air scoop in conjuction with my new takeda / Greddy intake kit and I'm also planning to drill a hole into the connector pipe to reuse the noise generator like oem.
If you go for aFe takeda you have to remove the air scoop. That is my case.
Old 04-11-2013, 04:51 PM   #16
mike_ekim1024
mike_ekim1024's Avatar
Drives: Argento Scion FR-S
Originally Posted by peace_noel View Post
that is so tough..I have hard time to remove the front bumper too to get my aFe Takeda Instake install.
It require you remove the bolts over the side marker to get into the driver side bumper to be able take the front bumper off.
Luckily I changed my side markers before I bought my Takeda, so learned how to get them out. It helps when you look where the clips are located:
http://www.ft86club.com/forums/showthread.php?t=15560
The manual also doesn't mention the top clip inside the side marker housing that needs to be pulled out. The bumper wasn't too bad, but again, experience from pulling the door panels off gave me an idea of how much force I should apply. You kind of have to gently but firmly pull and get an idea of where the clips are. I got my snorkel out pretty easily, just twisting it then pulling it out. Putting the bumper back on, it wasn't aligning correctly, so I just pulled back and to the right to make sure the clips align. I'm not a car guy, and I didn't have to much of a problem. With doing any of this of course, there is risk. Ask yourself - for any reason, if you break the bumper, will you scream and cuss, or will you just say.. oh well, it was getting dinged and chipped anyway and replace it. If the former, depending on the project it might be good to have someone else do it. For example, I gave up on installing my front sway bar.. it's past my should/can I do this 'threshold'.
Peace,
Mike
mike_ekim1024 is offline   Reply With Quote
Old 04-11-2013, 06:20 PM   #17
NoFear99
NoFear99's Avatar
Drives: FR-S Firestorm
I already have it in my closet into the box.
It just need to be installed but my car is still stored for winter.
How come we have to remove the air scoop ? It wont fit if I let it there ?
- 2013 Scion FR-S Firestorm
- 2007 Lotus Exige S 280 Solar Yellow
- 2007 Honda CBR 600RR
- 2002 Bombardier Legend 800SE
Website : http://nofear99.monchar.com
NoFear99 is offline   Reply With Quote
Old 04-11-2013, 06:25 PM   #18
whataboutbob
AutoX-10/10ths every run
I left the snorkel on with my aFe Dry. Works fine!
Build thread:Here
Old 04-11-2013, 06:28 PM   #19
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
It just won't fit. I can take some picture to show you why. For those who didn't remove the air scoop and had the aFe intaked installed, I don't know how. you might have to ask them.
Old 04-11-2013, 06:34 PM   #20
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
@NoFear99 here are some pic that I took during my install of the aFe Takeda Pro-Dry intake.
Size:  71.7 KBName:  ImageUploadedByTapatalk1365719580.101856.jpg
Size:  108.4 KBName:  ImageUploadedByTapatalk1365719594.251505.jpg
If you look at the second pic, that air scoop is on the way if you try put in the intake. That air scoop have to be romove.
Old 04-11-2013, 06:48 PM   #21
NoFear99
NoFear99's Avatar
Question
How was the connection between the stock front fresh air scoop and the AFE duct in the engine bay for you ???
Old 04-11-2013, 06:53 PM   #22
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
Here's the pic of my stock intake with air scoop that removed from the car. Many thanks to help from @Chen to get that install.Name:  ImageUploadedByTapatalk1365720573.902647.jpg
Old 04-11-2013, 06:59 PM   #23
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
snorkel fits on aFe/Greddy. u can just it leave it alone if you dont want to remove the bumper. snorkel is just a restriction of air, i think. correct me if im wrong.
but for me, i remove the snorkel for my Greddy intake.
itzzmeeken [My Journal]
86 FRS is offline   Reply With Quote
Old 04-11-2013, 07:14 PM   #24
NoFear99
NoFear99's Avatar
This is becoming very confusing about the stock fresh air scoop...
Some say you can install this intake and keep it.
Some say you cannot install it if you dont remove it.
Who is right ?
Old 04-11-2013, 07:21 PM   #25
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
@NoFear99 when are you going install it? You will know when u r actually install the intake.
For those who didn't remove the air scoop and still able install the takeda/greddy intake. Please provide pic to teach me. I am just so curious how does that work.
Old 04-11-2013, 07:26 PM   #26
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
Who is right ?
put it this way, i installed my greddy with my snorkel on. then after 5minutes before i started to tight all the bolts, decided to remove the snorkel. LOL
im not sure why ur aFe doesnt fit with the snorkel, Greddy and aFe is the same intake just a different brand. mine just went in, no issues.
Old 04-11-2013, 07:37 PM   #27
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
take a look.. my aFe intake have the long open from the front.
there is another type of aFe intake..which has the short openning.
if you google the intake..there comes up some short and some long opening...I don't know why either.
Same for the Greddy brand
Long Opening
Short opening
@NoFear99 @86 FRS The ones with short openning...you don't have to remove the air scoop. The long openning ones required.
Old 04-11-2013, 07:39 PM   #28
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
im guessing urs is the 1st aFe intake that came out? what i heard is that, Greddy/aFe made a changes with the intake. not really sure. I have the short opening intake.
maybe the long open have issues with the snorkels.
GReddy intake and SP Elite D1cker Engine, Exhaust, Bolt-Ons 5 04-23-2013 12:12 PM
JDM GREDDY INTAKE pdreams Engine, Exhaust, Transmission 19 10-24-2012 11:16 AM
Greddy Intake? Turdinator Engine, Exhaust, Transmission 15 09-05-2012 08:26 PM
Greddy Air Intake FR-S rikdrt1 Engine, Exhaust, Transmission 17 08-28-2012 08:24 AM
