Old 04-11-2013, 12:00 PM   #897
OrbitalEllipses
Drives: Attitude
Installed my warranty replacements yesterday. Packing is much improved; however, one strut had a single chip in the exact same place as the strut it replaced. That particular chip (top of the strut housing at the hood attachment bracket, facing the sky when the hood is up) appears to be a weakness in the coating applied at the manufacturer level. The other chips in my original struts were all due to bracket contact, but seeing the exact same chip on two struts is odd. The coating looks weird on that area anyway when compared to the strut that doesn't have a chip there.
Also, I've noticed some surface rust on the nut/flange of the ball that's inserted into the socket.
Old 04-11-2013, 12:18 PM   #898
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
Sorry to hear that you're not completely satisfied, man! Sent you a PM.
GrimmSpeed is offline   Reply With Quote
Old 04-11-2013, 12:44 PM   #899
OrbitalEllipses
Drives: Attitude
Oh, I'm satisfied. Just making my observations for posterity.
Old 04-11-2013, 02:59 PM   #900
GrimmSpeed
GrimmSpeed's Avatar
Good! We do always appreciate the feedback!
Old 04-13-2013, 01:28 PM   #901
Anduz
Anduz's Avatar
Drives: Audi A3
installed my set today, making some observations....
Great product, works well.
Just before full extension, the hydraulics makes a squeaky noise?
In the process of installing, actually broke two bolts, not sure if USA has same bolt as the aussie ones, but the ones that's used to hold the bottom section down, is actually quite fragile...something to be aware of
Black?
Anduz is offline   Reply With Quote
Old 04-13-2013, 08:28 PM   #902
sierra
Drives: Skoda Yeti DSG diesel 4x4
You broke the new bolts that they supplied or the old ones?
sierra is offline   Reply With Quote
Old 04-13-2013, 08:52 PM   #903
Anduz
Anduz's Avatar
Drives: Audi A3
The ones that was on the car
Sent from my Nexus 4 using Tapatalk 2
Black?
Old 04-13-2013, 08:59 PM   #904
sierra
I thought Grimmspeed were supplying replacement bolts for the lower mounts because the original bolts are too short and several others had sheared/stripped them off too?
I had to re-use the old bolts and was super careful because I realised there were only a few threads doing the job and really should replace them.
Old 04-13-2013, 09:27 PM   #905
Anduz
Anduz's Avatar
Drives: Audi A3
Mine only came with 4 bolts
Black?
Old 04-13-2013, 10:35 PM   #906
sierra
Ask them to send the other bolts because they made it clear they were supplying those bolts now and offered to send them to anyone who didn't get them in the earlier kits.
Old 04-13-2013, 11:03 PM   #907
Anduz
Anduz's Avatar
Drives: Audi A3
yea, i just re-read the previous posts and have sent them an email
Black?
Old 04-13-2013, 11:35 PM   #908
sierra
I got mine before the other bolts were available and can't bring myself to ask them to mail me a couple to replace them. I'll look up the specs and source them locally.
Old 07-09-2013, 03:46 AM   #909
Alabang 86
Alabang 86's Avatar
Drives: GT86
Finally installed mine today. took about 10 minutes. wish it took longer.
looks great, works great.
the nuts had spots of rust, permanent marker took care of this.
all in all 4.5 out of 5 highly recommended but find a better nut supplier.
...my turn...
Alabang 86 is offline   Reply With Quote
Old 07-12-2013, 12:30 PM   #910
supra2nv
supra2nv's Avatar
Drives: 10 Series TRD
are the new kits refined and have the bugs been worked out? if so, please pm me a price, I may be interested in this. ty in advance...
"Electrons act like photons. They are both screwy, but in exactly the same way." Richard Feynman
Wave Particle Duality
supra2nv is offline   Reply With Quote
Replacing Struts and Installing Coil Springs DarrenDriven DIY (Do-It-Yourself) Guides 195 04-26-2017 04:15 PM
Stock Springs/Struts FRS jadewbj Brakes, Suspension, Chassis 1 12-18-2012 10:00 AM
WANTED (GA) - Stock FR-S/BRZ struts xwd Brakes, Suspension, Chassis 8 11-07-2012 10:43 AM
performance/aftermarker struts karma003 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-07-2012 11:26 AM
JDM BRZ Struts different than USDM BRZ Struts? switchlanez Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-30-2012 10:21 AM
