Old 04-10-2013, 02:58 PM   #29
FR-S Matt
Originally Posted by Foobar View Post
I have a Perrin lightweight pulley and no honking between shifts, so I don't think that's the culprit.
Have the Perrin Pulley installed as well and had it on for 5 days now. No change in sound on shifting or anything.
Old 04-10-2013, 02:58 PM   #30
ST185RC
Drives: White Out FR-S
Originally Posted by ATL BRZ View Post
First the crickets, now ducks quacking....
Brings out the animals in our cars.
ST185RC is offline   Reply With Quote
Old 04-25-2013, 12:02 PM   #31
garf
Great Member
garf's Avatar
Drives: raven, baught 8-29-12, manual
pretty sure its metal on metal rubbing in the transmission, maybe the throwout bearing going bad, i can replicate it now sitting in neutral with the clutch pressed in and reving the engine so im going to toyota fri and see what they say.
garf is offline   Reply With Quote
Old 04-25-2013, 12:22 PM   #32
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Keep us posted!
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 04-25-2013, 03:59 PM   #33
Fenrir
Drives: Mazdaspeed 3
[ame="http://en.wikipedia.org/wiki/Clutch_delay_valve"]Clutch delay valve - Wikipedia, the free encyclopedia[/ame]
There's a few other threads about this. Means you're slipping the clutch and not shifting smoothly
Fenrir is offline   Reply With Quote
Old 04-25-2013, 05:13 PM   #34
Gopherboy6956
I don't understand how that would make a chirping noise though... I can dump the clutch and we're good to go... I can shift nice and we're good to go... sometimes.
But, that inbetween area.... you might be on to something.
Old 04-25-2013, 05:22 PM   #35
Fenrir
The valve is designed to avoid extremely harsh engagement of the clutch. When the clutch is being slipped, there's backpressure being pushed on the valve which causes it to make the quacking or humming noise.
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 06:45 PM
Perrin Pulley ArKiTeCkT Issues | Warranty | Recalls / TSB 12 11-06-2012 11:57 AM
Just changed oil...crickets got but new pulley noise sa1126 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 09-30-2012 05:45 PM
