#309 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
I didn't let the header situation keep me down this weekend. I spent Saturday and Sunday with the car on the lift and successfully installed
-RaceComp Engineering hollow front and rear sway bars -Whiteline Com-C top mounts (revised version with better bearings and harder durometer rubber around the bearing, acquired via warranty replacement) -Whiteline rear crossmember insert bushings (KDT922) -Millers Motorsport CRX 75w90 NT Trans & Diff fluid -Millers Racing Brake Fluid 300 Plus (flushed all the OEM fluid) -Project Mu HC+800 Brake Pads (F&R) -Perrin Rear Shifter Bushing No malfunctions, everything installed without a hitch. Test driving the car after doing all of that was FUN! Zero body roll from the bigger, stiffer and hollow RCE sway bars set stiffer in the rear and softer in front for predictable oversteery goodness. I am amazed by how much grippier the stock tires feel when tossing the car around. The bars help the car change direction quicker than I ever thought possible. It's a truly amazing difference in handling compared to the OEM sways. Can't wait to see what kind of cornering speeds these allow on the track soon. Thanks @Racecomp Engineering , you guys rock! Quicker, more responsive turn-in with more negative camber and caster from the WL Com-C top mounts. They are working great with the RCE Yellow springs on the OEM struts. Took the camber bolts out of the strut mounts and went with the stock fat-collared bolts because I'm getting enough negative camber already. No noises when turning or over bumps, no deformation of the rubber around the bearings; they check out and earn a thumbs up. The Whiteline rear subframe bushings also make the car feel much better under load. All the rear subframe slop and play is gone. The chassis responds instantly to the gas pedal and traction is greatly improved everywhere. Coupled with the Perrin rear shifter bushing the car feels more solid overall and the gear changes feel more precise and direct. No additional NVH that I noticed so these bushings get two thumbs up I haven't gotten to threshold test the Millers racing brake fluid yet but I will at the next HPDE at the end of April. The brakes feel awesome, much more progressive bite from the Project Mu HC+800 pads. They feel much more aggressive compared to the StopTech Street performance pads and since they have a much higher MOT and friction coefficient they will hopefully serve me well at the track soon and allow quiet operation year round. The trans and diff fluid are performing great so far. Quieter, smoother shifts and lower operating temps by a significant margin makes me feel good about tracking the car hard this summer. ![]() I didn't get any pics during the install of anything since I was just too focused on getting it all done ASAP, but I did manage to snap a quick one after the test drive after washing and before putting the 944 Turbo S (pictured) and 944 S2 race car back into the garage: ![]() Now for the only bit of bad news... I did not successfully install the Touge Factory Brake Cooling Duct kit. The instructions require drilling and cutting a hole in the factory splash guard right where the control arm sits and removing the calipers, rotors, and hubs to install the backing plates for the hoses. The kit comes with shims to push the washer fluid tank out to create a big enough gap between the tank and the AC condenser and line on the driver's side to route the hoses. With the car on the lift, I removed all the under panels and installed the spacers for the washer tank and made the gap per the instructions and attempted to test fit both of the ducts on either side of the bumper opening to be sure they would work before proceeding with the rest of the install. I was concerned about the differences of the bumper openings on BRZ vs the FR-S. Touge Factory developed the kit on an FR-S and the unique grille mesh and the bigger lower openings near the "fangs" happen to be just right for the ducts to be secured and the hose to be routed properly. I found that the BRZ bumper does not allow proper fitment of the ducts and hoses. I could not find way to properly mount the ducts to the BRZ's bumper. This is mostly an issue on the driver's side. I could not find a way to mount the ducts flush with the bumper opening and zip tie it down securely while allowing the hose to properly flow into the gap between the washer fluid tank and the AC condenser/rad. The FR-S bumper openings are perfectly shaped at the lower extremes to allow the ducts to mount flush and direct the hoses to just the right area to clear the condenser on either side. The mesh design grille on the FR-S also makes it much easier to zip tie and secure the ducts. I decided at that point to not install the kit since I couldn't find a good solution to securely mount the ducts behind the bumper cover openings so I decided not to proceed with installing the backing plates and cutting and drilling the splash guard for the hoses. I will be contacting Touge Factory first to see if they have a solution. Everything else about the kit would have installed fine, but the differences in the bumpers between the two cars may be a deal breaker.
| The Following 3 Users Say Thank You to ATL BRZ For This Useful Post: |
#310 |
Drives: 2013 Asphalt FR-S
Have you seen the APR kit:
http://ft86speedfactory.com/apr-carb...s-frs-637.html looks like it will install without removing the backing plate.. not 100% sure though
~Namaste~ |
#311 | |
I believe this is why Subaru went this route with the RA spec BRZ. ![]() The ducts underneath the bumper look like a replacement for the front under tray on US spec cars and would allow ducting to avoid all that mess above and take less turns to get to the brake rotors. Last edited by ATL BRZ; 04-11-2013 at 12:20 PM. |
#312 |
We prepped a local customer's BRZ with our kit prior to him going out to Carolina Motosports Park last weekend.
Here is how it looks. The angle of the duct was slightly different, other then that everything else was same as the FRS. We'll get those out to you this week.
| The Following 4 Users Say Thank You to Touge Factory For This Useful Post: |
#313 | |
#314 |
I guess the image set on FT86 SPeed factory is misleading then... I assumed it was ~350 for the kit that includes the ducting and the backing plate mount. Difficult for me to tell from the image where the air is directed... i agree it needs to be to the inside of the rotor rather than the rotor face.... too bad we can't combine the two kits for a reasonable price.
~Namaste~ |
#315 |
The reason why we're not offering a kit that would utilize the fog light location is because there is no way you can route a hose from that location to the brakes without removing the windshield washer tank completely.
Even you if you did relocate it, the hose would be have to be routed right back up toward the front of the bumper then back again toward the brakes. The ducts are well hidden. I bet once these are on "Melanie" most people would walk right past the car and not even notice the ducts. Another reason we would rather not use the fog light location is so that we are not creating unnecessary aerodynamic drag by creating more opening on the front of the bumper. |
#316 |
Drives: Toyota 86
Did you use a conical washer with the WL com-c top mount or not?
I'm holding installing it because of a conical washer. |
#317 | |
Also, I do not recommend using camber bolts with the Com-C's. I didn't like the strut geometry they were creating with the new top mounts when pushing the rotors up to get the camber from the bolts. It just didn't look or feel right, so I put the stock fat upper strut mounting bolt back in and it looked right with plenty of negative camber. |
| The Following User Says Thank You to ATL BRZ For This Useful Post: | makinen (05-15-2013) |
#318 |
Drives: Toyota 86
#319 |
Managed to snap one crappy pic of my new WORKS AB-M axleback last evening after installing it and taking it for a quick spin.
![]() It's now unfortunately coated with pollen with the rest of the car and will stay that way for a few weeks unless I can manage to stay outside long enough to hose it off without getting into a sneezing fit. It's a really nice piece, fits perfect on all four hangers and the stainless tips are perfectly centered and have a nice WORKS logo on top. I really like how they don't stick out from the bumper at all. My DC tips on my stock suitcase stuck out a little too far. The sound is just what I was looking for. Not too quiet like the Nameless, not too loud and droney like the Berk dual delete. Zero drone anywhere, just a nice throaty rumble that turns into a controlled but very noticeable roar at high rpm's.
| The Following 7 Users Say Thank You to ATL BRZ For This Useful Post: | AZOOZ_95 (04-27-2013), chanomatik (04-16-2013), JR007 (08-25-2013), ScionFrsFan (04-10-2013), Weasel Soup (05-10-2014), Wheelsoffracing (09-26-2013), WORKS (10-06-2014) |
#320 | |
Drives: 2013 BRZ LTD
| The Following User Says Thank You to Ari PD For This Useful Post: | ATL BRZ (04-16-2013) |
#321 |
#322 |
Damn. Well I'm curious either way how the aerodynamics are effected by replacing the factory muffler on the axelback. At least the ABM version appears to have something to fill that "hole," unlike the non muffler version.
| Tags |
| jdl turbo, mazworx, racecomp engineering, track build, verus engineering |
| Wnt3d's 86 - Turbo E85 Daily/Track Build | wnt3d | Member's Car Journals | 77 | 07-17-2017 03:35 PM |
| No Limit Motorsport Full Blown BRZ Build | No Limit Motorsport | Member's Car Journals | 16 | 07-08-2014 12:46 PM |
