View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 04-08-2013, 08:58 AM   #1555
HunterGreene
Hail Magnet
HunterGreene's Avatar
Its kinda weird, the crickets come and go. Just passed 4200 miles, and I have heard them intermittently, doesn't seem dependent on temperature or which gas I have.
However, I noticed condensation in my taillights the other day, so I guess the gremlin moved from the engine bay to the tail lights.
Old 04-08-2013, 01:16 PM   #1556
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
i only get the sound after spirited/ high rev driving. it will continue until i shut the car off and it cools down. upon restart it sounds normal. even on a regular commute the chirps cant be heard
Old 04-08-2013, 01:28 PM   #1557
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Do you mean you used to have it all the time, but now it's intermittent? If so, then that's what happened to me and it eventually went away.
Old 04-08-2013, 01:37 PM   #1558
HunterGreene
Hail Magnet
Well, its hard to tell--the car was garaged for 4 months. It had the crickets when I parked it, and it still gets them from time to time. I would be happy if they faded.
However, the engineer in me is afraid that the sound of the crickets going away indicates either 1) the o-ring causing the sound has worn down slightly, like when you get new shoes and they squeak at first, just a matter of breaking in
or 2) the part that caused the squeak is on the cusp of imminent failure. That reminds me, I need to buy a car fire extinguisher on the way home.
The Following User Says Thank You to HunterGreene For This Useful Post:
sierra (04-08-2013)
Old 04-08-2013, 07:22 PM   #1559
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Well you can always get it fixed under warranty. I have noticed others with the same tail light issue and they had it replaced under warranty also. Not sure if aftermarket lights leak like the factory ones do.
texasbound972 is offline   Reply With Quote
Old 04-08-2013, 10:01 PM   #1560
Silver86
Silver86's Avatar
Drives: Argento FR-S
After using ethanol free gas I no longer have the chirp.
Silver86 is offline   Reply With Quote
Old 04-09-2013, 12:15 AM   #1561
wdninja
wdninja's Avatar
Drives: 2023 Toyota GR86 Premium
The aftermarket tail lights that come with a gasket sealed to the housing shouldn't leak, but the ones that reuse the stock gasket have the potential to. My Colin tails fogged using the stock gasket, but both the stock and aftermarket sets stopped after replacing the gaskets with better ones. You can PM me or hit the link in my sig if you want a set shipped out, or get them replaced at the dealer. As far as I know, the dealer replacements aren't sealed either.
2023 Toyota GR86 Premium, Neptune Blue Gasket Ninja.
wdninja is offline   Reply With Quote
Old 04-09-2013, 12:16 AM   #1562
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
So I just started to get the idle chirp, but my VIN is after Production Change Effective VIN on the bulletin. Will they not do this work on my car?
Old 04-09-2013, 08:08 AM   #1563
HunterGreene
Hail Magnet
The taillight replacement done by the dealership can work, if they do it correctly.
I believe a few members with higher VINs have had this serviced. Never hurts to take it in and check.
Old 04-09-2013, 11:07 AM   #1564
JFK0424
chirp chirp
I work at Toyota. My frs was not in the vin range for this chirpping noise from the fuel pump. My tech got an ok from Toyota but the only thing is they are nationally back ordered for this part. Regardless of what anyone says, this is not a normal sound if Toyota is changing out the part for you. Its worth taking in to have it looked at and changed. If they say no, just call Toyota yourself and I'm sure they will say yes. If not, come to my dealership and get the work done here.
JFK0424 is offline   Reply With Quote
Old 04-09-2013, 11:24 AM   #1565
5hairpins
5hairpins's Avatar
Drives: 2013 MT Asphalt FR-S
I am nearly a year and 10K miles in and my crickets are my constant companions. I have never seen any error lights or had one iota of trouble due to the crickets. Until I see something that indicates a real problem, I will let the crickets keep me company.
5hairpins is offline   Reply With Quote
Old 04-09-2013, 01:52 PM   #1566
Re~Mix
Re~Mix's Avatar
Drives: 13' Scion FRS MT
There still seems to be mixed opinions regarding this. I took mine in at 5K miles and had a couple components replaced with the new PNs. However, by 8K miles the chirp was back.
I brought it in again at 10K miles and this time the dealer stated that it had the new PN and the noise was deemed to not be causing any harm to the car itself.
C'est la vie. $25K car, bound to be some kinks to work out.
07' Z4M Coupe | KW Clubsports | AFE Intake | Stromung Mufflers | UUC Shortshifter | Advan RS
15' 228i MSport
13' FR-S | TRD CAI | TRD Catback | UEL Header | OFT Stg 1 | Rota Grid-V | RCE Suspension | Hankook |
Re~Mix is offline   Reply With Quote
Old 04-09-2013, 02:26 PM   #1567
FR-S Neck
Drives: FR-S Black Beauty
I feel as if people aren't reading.... Ethanol free gas fixes the problem. If you filled up with "ethanol free gas" and it still makes the noise then you need to read the pump more carefully because you obviously didn't fill up with ethanol free gas. Most gas stations have a pump separate from the others with the ethanol free.
FR-S Neck is offline   Reply With Quote
Old 04-09-2013, 04:09 PM   #1568
sf86
sf86's Avatar
Drives: Red Scion FRS AT
Not here in california bro. The closest ethanol free gas i know is almost 200miles away from where i live.
Sent from my HTC One X using Tapatalk 2
sf86 is offline   Reply With Quote
The Following User Says Thank You to sf86 For This Useful Post:
Re~Mix (04-09-2013)
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
