Old 03-21-2013, 09:45 PM   #29
White64Goat
Only trying to improve am/fm reception, not GPS. I believe the GPS part is inside the base part of the antenna and not the mast.
Old 03-21-2013, 10:28 PM   #30
DNAPoPo
GreddyBRZ meets GreddyFRS
DNAPoPo's Avatar
Drives: SSM Limited BRZ
Actually base part is where the XM is, GPS portion is on the front dash.
CO>CA|Greddy Intake + EVO 3|Enkei Raijin|KW V3|BeatSonic
SoCal 86 OC Club
Tuesday Night Irvine DJ Meet Thread
Irvine FR-S & BRZ Car Meet(FaceBook)
DNAPoPo is offline   Reply With Quote
Old 03-22-2013, 08:42 AM   #31
White64Goat
That's what I meant to put........brain seizure.
Old 03-25-2013, 04:00 PM   #32
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Still hoping for a solution.
Old 03-28-2013, 05:02 PM   #33
White64Goat
Boy, this radio reception will piss you off. I tried the 31" stainless one and it was better, but only when driving in the direction (towards) the radio station (transmitter). When driving away from the station, not so much. I have one more to try (off my Saturn, not sure about thread size yet) and it is also a 31" but has a wire wrapped around the center shaft. After that, maybe the factory radio just isn't that great with pulling and holding a signal?
The Following 3 Users Say Thank You to White64Goat For This Useful Post:
Carlsbad (04-02-2013), EAGLE5 (03-30-2013), ftc~brz (03-28-2013)
Old 04-07-2013, 06:58 PM   #34
WRM
I have had pretty good luck with an 18 inch antenna I bought from ebay. It is much better than the stock antenna to pick up HD radio channels, especially those secondary HD ones.
It is not perfect but that is why you have a USB port and Bluetooth audio.
In the picture below are my items in order of preference.
1. Super small USB drive to play my MP3 collection. I believe this is the smallest size you can get so it is unobtrusive in the USB slot. The rubber USB boot cover from the car hides it pretty well. Since it is so small, it is impossible to accidently knock it out of the slot.
2. Smartphone, in this case an iPhone 4s. I use this to play podcasts and such. I power this to the 12V power in the armrest. Since the USB drive takes the USB slot, I connect this to the radio using Bluetooth audio. If you use apps like Google maps, you can actually hear turn by turn directions from the car speakers.
3. An 18” antenna to listen to HD radio.
The 7” OEM antenna I just store in the trunk.
For those of you who want to see how the 18” antenna looks on the car, here is a pic. I have been using this for a long time so it looks fine to me.
WRM is offline   Reply With Quote
The Following User Says Thank You to WRM For This Useful Post:
rbizzle004 (04-14-2013)
Old 04-07-2013, 08:11 PM   #35
EAGLE5
Dismember
EAGLE5's Avatar
Thanks! I might do just that. Is your car named Elroy Jetson?
Old 04-07-2013, 08:30 PM   #36
jpit
Drives: Subaru BRZ
If I remember correctly FM reception is obtained. best with a 32 inch antenna and AM reception with the longest antenna possible. So best way to improve reception is just by going to a longer one. Does anyone know if the BRZ uses a signal amplifier? Where did you get the 18" antenna?
jpit is offline   Reply With Quote
Old 04-07-2013, 09:13 PM   #37
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Please don't take offense but that made me LOL! Just being honest; I'm sure it's because I'm not used to seeing it as much as you are. If others don't like it while you still do... I'm with ya! Because that's what ownership is all about.
My buddy is bothered by the long stock antenna compared to his stubby Perrin. I'm still sticking to stock since I'm an OEM nut. Only problem I've ever had is the HD radio cuts out when I go into car washes and parking garages.
Old 04-07-2013, 09:22 PM   #38
WRM
While the total length of the antenna is 18", you will notice that the wire is wrapped around the mast. How long would it be if it wasn't wrapped, I don't know. I do know that it picks up FM better than the stock antenna, at least in Los Angeles.
If you type "18 inch fuba antenna" in ebay the first seller should be "raderra". It was only $10.99 with free shipping. The antenna fits just like OEM.
EAGLE5 (04-13-2013)
Old 04-13-2013, 07:54 PM   #39
EAGLE5
Dismember
EAGLE5's Avatar
Ordered one. Hope it works for me too.
Old 04-13-2013, 08:03 PM   #40
jpit
Drives: Subaru BRZ
I bought the one on ebay and it is a definite improvement over stock.
The Following 2 Users Say Thank You to jpit For This Useful Post:
EAGLE5 (04-13-2013), rbizzle004 (04-14-2013)
Old 04-20-2013, 11:51 AM   #41
rbizzle004
I bought the antenna WRM suggested and yes it's an improvement. I always had issues with one local HD channel cutting in and out. It still does but not as often. I also pick up a channel in town that I could only get when I was 10 miles + out of town.
rbizzle004 is offline   Reply With Quote
Old 04-25-2013, 06:10 PM   #42
EAGLE5
Dismember
EAGLE5's Avatar
I've had the one from raderra on for a week. A definite improvement over stock. It's a cheap one, though. Two holes in it from the molding process that should have been plugged. I now get a station in many areas that I almost never got, a 2nd HD channel. It even lasts part way into the canyon. Worth it? Sure. Amazing? No.
20$ Shark Fin Antenna srt4_night_rider Cosmetic Modification (Interior/Exterior/Lighting) 13 05-08-2013 02:13 AM
Shark Fin Antenna geb2391 BRZ First-Gen (2012+) — General Topics 15 09-09-2012 10:05 PM
LT Short Antenna now available for the 86/FR-S/BRZ/GT-86 lordtakuban Exterior Parts - The Rest 1 07-25-2012 08:22 AM
Got my Beats Antenna before my car ;( haloterence Cosmetic Modification (Interior/Exterior/Lighting) 3 06-13-2012 09:55 PM
Does anyone else not like where they put the antenna? MrFRsLa Cosmetic Modification (Interior/Exterior/Lighting) 41 06-04-2012 08:27 AM
